Is this Vortech Rattle Normal (video)??
Old Nov 13, 2005 | 08:49 AM
g8tor20's Avatar
g8tor20
Default Is this Vortech Rattle Normal (video)??
As some may know...I have been complaining about the rattle my Vortech has at idle. I uploaded a video. Everyone says its normal. Can you Vortech guys listen to this and tell me if this is the rattle. And is it this loud on yours?
http://videos.streetfire.net/player....7-C3389AF646B0
http://videos.streetfire.net/player....0-F1D5DBC4F515
Old Nov 13, 2005 | 08:55 AM
BLN350Z's Avatar
BLN350Z
I don't have the Vortech, but something sure doesn't sound right about that noise to me.
Can you hear it get louder under accelerationor or is the sound absent inside the cabin?
James
Old Nov 13, 2005 | 08:57 AM
g8tor20's Avatar
g8tor20
Ohh you can hear it in the cabin. It goes away above 1000rpms. It makes for fun stoplights.
Old Nov 13, 2005 | 09:10 AM
g8tor20's Avatar
g8tor20
Here is another video from inside the cabin.
http://videos.streetfire.net/player....3-52235AD7440E
This can't be normal!!
Old Nov 13, 2005 | 09:27 AM
Barzten1's Avatar
Barzten1
Is the surface your car is on a angel. Mine doesn't rattle like that but has a wierd rattle only on my angeled driveway but goes away when the rpm's are raised. Make sure your oil return lines aren't crimped. I would get that checked.
Old Nov 13, 2005 | 09:30 AM
g356gear's Avatar
g356gear
That would drive me nuts!! Does not sound normal....especially being intermittent like that.
Old Nov 13, 2005 | 09:31 AM
g8tor20's Avatar
g8tor20
I want to but I live nowhere near a reputable shop (and I had CP Race install it and if I didn't live 4 states away...I would drive there again in a heartbeat).
I'm thinking of going to Z Fever in Tampa. (1.5 hrs away)
But thats why I posted this...I need other people with Z/G Vortechs to tell me if this is that 'normal' rattle
And yes...it happens at every angle. Stoplights are a b!tch
Old Nov 13, 2005 | 09:32 AM
g8tor20's Avatar
g8tor20
You have no idea man.
Old Nov 13, 2005 | 09:37 AM
Barzten1's Avatar
Barzten1
I definately would get it checked. It's worth the drive to make sure the impeller blades are not overheating or rubbing.
Old Nov 13, 2005 | 09:39 AM
Gman2004's Avatar
Gman2004
that's the same sound mine used to make. just bump up the idle to 1000 and you will be fine.
Old Nov 13, 2005 | 09:44 AM
g8tor20's Avatar
g8tor20
That would seem like the solution but thatll cost me abother $450 bucks plus...when I part the car and return her to stock....she'll have an abnormally high idle.
Old Nov 13, 2005 | 09:55 AM
Gman2004's Avatar
Gman2004
do you have the l-spec TS flash already?
Old Nov 13, 2005 | 09:57 AM
g8tor20's Avatar
g8tor20
Yeah. I have the L-Spec but idle is included in the F-Spec. They told me $300 since I already have the L-Spec...but i have to ship it there and back. Overnighting from Florida to Cali ain't cheap
Old Nov 13, 2005 | 10:19 AM
BLN350Z's Avatar
BLN350Z
That sure sounds like a Band-aid on a more serious problem IMO.
Old Nov 13, 2005 | 10:24 AM
g8tor20's Avatar
g8tor20
I'm hoping that Matt from CP Racing comments on this. If there is an underlying serious problem...I hope they can figure out whats wrong and fix it.
USMC-Z's Avatar
USMC-Z
Z Veteran
On the second video, the belt doesn't look to be turning evenly. It looks like one of the pulley's is loose. Just an observation, as I don't have a SC.
Old Nov 13, 2005 | 10:26 AM
g8tor20's Avatar
g8tor20
I noticed that too but that is a toothed cog belt so I dont know if it being loose affetcs it at all. That belt has about an inch of play on the bottom side. From earlier posts...this is where that "sweet" spot seems to be.
Old Nov 13, 2005 | 10:28 AM
g8tor20's Avatar
g8tor20
And I emailed this thread to Vortech themselves. We'll see what they have to say.
Old Nov 13, 2005 | 10:29 AM
BLN350Z's Avatar
BLN350Z
I sure hope you get it figured out and I would definitly check with CP before just raising the RPM at idle.
Not trying to step on your toes Gman, I am just making a different suggestion.
Old Nov 13, 2005 | 11:06 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Wow. Morse Code!
I know the Vortec can clatter but thats absolutely nuts. Ask Vortec to exchange the head for you.
It sounds like the gear box has a lot of backlash. The backlash isn't overcome until the compressor has some load on it...
Even if its not a problem for reliability, it would be humiliating sitting at a stop light with that. Its time to double limo tint your windows or raise the idle or get Vortec involved.
