Ready for Turbonetics What do I need??
Old Nov 29, 2005 | 08:58 AM
RED HOT Z's Avatar
RED HOT Z
Default Ready for Turbonetics What do I need??
Alright guys I am ready for my early Christmas present. What exactly do I need in order to turbo my car besides just the turbonetics kit? Can someone please give me a list I dont want to forget anything.
Thanks Guys
Gilbert
Old Nov 29, 2005 | 09:00 AM
dirtroad's Avatar
dirtroad
about $10k
gauges
JWT clutch
Old Nov 29, 2005 | 09:03 AM
DBZ33's Avatar
DBZ33
Originally Posted by dirtroad
about $10k
gauges
JWT clutch
Where do you come up with $10K? Its more like 7 - 8K total.
Old Nov 29, 2005 | 09:04 AM
nissansource's Avatar
nissansource
Well considering I am currently on the install progress of my kit you will need the following.
1. Rachet wrenches
2. High Temp Red RTV sealent
3. Nissan OEM Intank Gasket ring
4. Drill Sidestep one
5. 1/8 drill bit
6. 3/8 drill bit
7. some other drill bit cant remember just get a whole buncha bits in a kit oh yah 9/16 for the oil drain that was scarry!*!*!* that area of block is soo thin
8. Gauges if you want BOOST, Wideband Inovative LM1 and gauge
9. If you need it a clutch. Stock should hold enough if you have some left in it
10. Lots of beer
Air tools with extensions is a must unless you like wrenching your own just get some extensions lots of deep sockets and standard size sockets
btw when you get to the section of having to move the ps cooler dont keep it up front its soo much easier then moving it
Attached Thumbnails Ready for Turbonetics What do I need??-t520051119181027271.jpg
Old Nov 29, 2005 | 09:11 AM
MIAPLAYA's Avatar
MIAPLAYA
1. Rachet wrenches
5. 1/8 drill bit
6. 3/8 drill bit
10. Lots of beer
I have the install instructions here: http://members.***.net/turbonetics35...icsinstman.pdf
For other stuff RTV sealant and a factory fuel pump assy o -ring. Boost gauge, wideband would be nice.
RTV Sealant: $10
Fuel pump assy o ring: $10
Boost gauge $40-190
Wideband $375 from www.forgedinternals.com
Beer...priceless
Old Nov 29, 2005 | 09:13 AM
nissansource
Beer is a must on any install.... if you want to be cool sapporo is good makes ya feel jdm
Attached Thumbnails Ready for Turbonetics What do I need??-sapporo_reserve_new.jpg
Old Nov 29, 2005 | 10:00 AM
RED HOT Z's Avatar
RED HOT Z
The money is no problem and I already have a JWT clutch/flywheel.
One more thing all the mods I have I did myself I know my way around any car pretty good do you think I could install the kit myself?
I understand that the kit does not need tuning because of the flash correct?
Old Nov 29, 2005 | 12:13 PM
MIAPLAYA's Avatar
MIAPLAYA
That is correct. Turn key is the name of the game Anyone with decent mechanical ability shoud be able to install it. Make sure you have a good mechanical friend to check your work though.
Old Nov 29, 2005 | 12:54 PM
redline350ZZ's Avatar
redline350ZZ
Heat wrap....
Wrap everything u can get ur hands on......so worth it.....
Old Nov 29, 2005 | 12:56 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by redline350ZZ
Heat wrap....
Good call...thank you...
Old Nov 29, 2005 | 02:21 PM
nissansource
yah you can install this sucker if you know your way around and are mechanicaly inclined. if ya need help pm me im not far from you ill come up and verify your install
Old Nov 29, 2005 | 03:08 PM
RED HOT Z's Avatar
RED HOT Z
awesome thanks guys I will attempt to do the install myself hopefully this coming week.
If I need help I will definately call you^^^
Old Nov 29, 2005 | 03:40 PM
nissansource
do you even have the kit already??????? these things arnt always instock since they sell soo many from what i hear
Old Nov 29, 2005 | 03:55 PM
RED HOT Z's Avatar
RED HOT Z
i will be purchasing it from MIke at Altered Atmosphere
Old Nov 29, 2005 | 07:17 PM
Tekwon-V's Avatar
Tekwon-V
i've skimmed through the turbonetics direction and did not see this part. maybe i have to look harder?
what's the part number on this o-ring?
Old Nov 29, 2005 | 11:00 PM
trinig35's Avatar
trinig35
X2
Old Nov 30, 2005 | 08:32 AM
MIAPLAYA's Avatar
MIAPLAYA
Its not in the install insturctions. Heres the deal. The fuel pump assy has an o ring that seals it in the tank. If you get gas on it when you are removing the assy it will swell up and won't seal right again when you try to re-install the pump assy. Some people have put it in their freezer in that case and it shrunk back and worked fine. A lot of people buy a new one just in case. You can get them at the Nissan dealership near you for about $10.
Old Nov 30, 2005 | 08:52 AM
nissansource
but the area it is in its hard not to get gas on so best get another or freeze it
Old Nov 30, 2005 | 11:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What is that? Good post guys, reminded me to get the fuel pump o-ring and some other things.
I am getting ready for my Turbonetics install hopefully shortly after X-mas and before New Years. I just ordered a JIC Spartan Full Ti 3" single exhaust, still need 3 guages and the oil pan spacer (I shouldnt have to tap the block correct? As the other oil line gets t'd off with the oil pressure sending unit right-MIA double check me please).
I already bought my JWT clutch/FW, guage pod, Nismo front to show off the IC, and I have a Varis air duct waiting for me for X-mas Where do you get the steel wire to secure the turbo heat shield? Home Depot? BTW "nissansource" have any more info on keeping the PS cooler up front?
Old Nov 30, 2005 | 11:15 AM
sq40's Avatar
sq40
Some Good Quality Even pressure Hose Clamps are a nice, cheap addition.
Got mine at hightempsilicone.com Heck.. You might even want to color match all of your couplers & hose while your at it.
