TOTAL cost of vortech
Old Nov 29, 2005 | 09:33 AM
03_Track_Z's Avatar
03_Track_Z
Default TOTAL cost of vortech
Okay so I'm looking for a number that covers EVERYTHING I will need to have my Z supercharged. I'm talking about kit price, (install will be DIY so ignore that), and other parts that I might need like fuel pump, injectors, and i dont even know what else. Can someone give me a complete rundown? Thanks.
Old Nov 29, 2005 | 09:36 AM
Gman2004's Avatar
Gman2004
The vortech kits comes with everything you need to run it out of the box. It cost about $4300. You could buy extra parts, like a fuel return, fuel pump, and larger injectors to ditch the FMU that comes with the kit, but it is not needed. I recommend you look into the Turbonetics ST. It costs about the same and is more upgradeable if you want more power.
the only additional cost you should be looking at our supplemental mods like exhuast, test pipes, gauges.
Old Nov 29, 2005 | 11:34 AM
03_Track_Z's Avatar
03_Track_Z
where are you finding it for $4300??
Old Nov 29, 2005 | 11:43 AM
jpc350z's Avatar
jpc350z
As Gmann says the kit is inclusive. Install and drive, however if you want a little more margin of safety then you might consider: larger injectors 440cc (approx $400.0) walbro fuel pump (approx $150.0), gages ( fuel, boost, $350.0 depending on what style you like) and most importantly since the kit is rich in A/F a dyno is highly recommended about $450.0 and you'll also pick up additional power..Also, for some additional power either a manifold plenum spacer or new plenum before the dyno..( $250.0- $400.0)
Gman2004's Avatar
Gman2004
Contact www.forgedinternals.com, www.cprace.com, or www.avalonracing.net. Shop around....there are always deals on the vortech kit.
Old Nov 29, 2005 | 11:45 AM
03_Track_Z's Avatar
03_Track_Z
hey jpc i go to columbia all the time, im a hopkins student but i go climbing at earth treks in columbia pretty often. anyways how safe is the vortech kit with your new pulley on stock internals? and how much (and where) did you get your vortech kit from?
Old Nov 29, 2005 | 01:30 PM
eltness350's Avatar
eltness350
The Untouchable
i did procharger...same price...comes with fuel pump and you dont have to drill into the oilpan...procharger's oil is held internal. ..
Old Nov 29, 2005 | 02:09 PM
teh215's Avatar
teh215
Yes, and it needs changed regularly. I still do not see why everyone is down on the oil pan drilling thing.... my 2¢
Old Nov 29, 2005 | 02:39 PM
hndumafia's Avatar
hndumafia
isnt it possible to drill an oil pan spacer anyway, and i'm pretty sure the jwt isn't too expensive.
Old Nov 29, 2005 | 02:45 PM
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
www.superchargers4less.com
Old Nov 29, 2005 | 02:52 PM
teh215's Avatar
teh215
I would NOT do it that way. The SC drain is designed to be above the oil in the pan. The spacer places it below the oil level in the pan.
Old Nov 29, 2005 | 03:02 PM
hndumafia's Avatar
hndumafia
what would be the harm in having the drain under the oil in the pan. Sure there would be some oil always in the drain line, but the oil would flow out of the drain line fine i believe. It's been long since i've taken any sort of chem class but wouldn't the oil level just find some equilibrium so there is only oil a small way up the drain line?
Old Nov 29, 2005 | 03:14 PM
teh215's Avatar
teh215
I have never found any definitive answer on eway or the other. My feeling is the longer the oil is in the SC, the more likely it is to burn. Considering the consequences, I will stick with the Vortech design.
Old Nov 29, 2005 | 03:43 PM
eltness350's Avatar
eltness350
The Untouchable
its easier to change blower oil then your cars oil!! very cheap and every 9k for blower oil...my 2cents! also another hour of install for your drilled oil pan!$$$$$$$$
Old Nov 29, 2005 | 06:35 PM
LiNks's Avatar
LiNks
bought a used vortech and with gauges, the kit, harness, oil spacer, installed and tuned i spent just over $5000.00 i think it was like $5120......... been driving it for 5k miles and its been treating me perfect, can really beat a complete FI setup maitnence free for that price
Old Nov 30, 2005 | 04:38 AM
jpc350z's Avatar
jpc350z
Bought it last x-mas (on sale) from Avalon Racing for $4,000.0.. I find it to be very safe..Would recommend it for nice kick *** performance..However as many have previously stated you get use to the performance pretty quickly and you might just might look for more and that's where the "should of got a Turbo" instead argument comes into play.. Frankly, I find the performance well above what I had hoped to achieve and at times wonder why do folks want more when you consider engine reliability and driver safety...Now if you plan on making it into a race car no doubt a TT or T is the way to go..
Old Nov 30, 2005 | 01:55 PM
LiNks's Avatar
LiNks
jpc350z-------i agree completely with you about
"However as many have previously stated you get use to the performance pretty quickly and you might just might look for more and that's where the "should of got a Turbo" instead argument comes into play..
What reminds you that you dont need a TT is when you race a Vette or M5 and pull on them.... that straightens you out real quick and you feel you dont need that TT anymore
350Z_Al
Oct 29, 2020 07:44 PM
Alexreyes
Sep 30, 2015 11:30 PM
