Greddy TT W/OEM Motor
Old Dec 4, 2005 | 06:41 PM
G2FAST's Avatar
G2FAST
Default Greddy TT W/OEM Motor
I have some questions for you guys:
1. How many miles with the Greddy?
2. Whats your whp? PSI?
3. Did you upgrade the radiator?
4. Fuel return?
5. Stock or upgraded clutch?
6. What braking system, stock, brembo, stoptech?
Thank you.
Old Dec 4, 2005 | 06:44 PM
westpak's Avatar
westpak
SFZCC
1. How many miles with the Greddy? 17K
2. Whats your whp? PSI? 401 8 psi
3. Did you upgrade the radiator? No
4. Fuel return? Fuel pump
5. Stock or upgraded clutch? stock for 10k ACT Street for last 7k
6. What braking system, stock, brembo, stoptech? Brembo with EBC Red pads
Old Dec 4, 2005 | 06:59 PM
002-M-P's Avatar
002-M-P
1. How many miles with the Greddy? 20k
2. Whats your whp? PSI? 424rwhp @ 7.5psi
4. Fuel return? Yes...AAM
5. Stock or upgraded clutch? Upraded...RPS Max 6-Puck Single
6. What braking system, stock, brembo, stoptech? Stock non-brembo, Hawk HPS Pads, SS Lines, ATE fluid
Old Dec 4, 2005 | 07:31 PM
nexstage350's Avatar
nexstage350
good thread, well for me at least
Old Dec 4, 2005 | 07:50 PM
G352NV's Avatar
G352NV
Me also. I want to know whats going to make the greddy kit safe for a stock block. Keep em comin!
Old Dec 5, 2005 | 01:59 PM
G2FAST's Avatar
G2FAST
+1 I'm buying a TT soon and want to make sure I ask my question now and not later, Greddy owners please keep posting.
Old Dec 5, 2005 | 02:07 PM
Jaki's Avatar
Jaki
1. How many miles with the Greddy? Around 7K
2. Whats your whp? PSI? 395 @ 7.5 psi (tunned it myself)
3. Did you upgrade the radiator? KOYO Racing Radiator
4. Fuel return? Just Walbro Fuel pump for now, but will be installing the CJM Stage 2 in late january
5. Stock or upgraded clutch? JWT Clutch
6. What braking system, stock, brembo, stoptech? Stock with Hawks HPS pads
Old Dec 5, 2005 | 06:52 PM
G2FAST's Avatar
G2FAST
How is everyones temp.? Thats why I ask if anyone changed there radiator. For those running different maps what settings?
Old Dec 5, 2005 | 06:57 PM
westpak's Avatar
westpak
SFZCC
Temps are fine but if I was to track the car again I woul definetly get the Koyo.
As for MAPS just one, if it is tuned for all boost levels you only need one MAP but you need to use boost not MAF to run the emanage. Then just have hi and lo boost settings in the e01 but I gave up on using lo setting and just use hi setting.
Old Dec 5, 2005 | 06:58 PM
nexstage350
Old Dec 5, 2005 | 06:59 PM
BamBam's Avatar
BamBam
1. How many miles with the Greddy? 3 - 4k
2. Whats your whp? PSI? 377@7psi & 425@9.5psi
3. Did you upgrade the radiator? Upgrading to Koyo now, had intercooler from start
4. Fuel return? Yes AAM
5. Stock or upgraded clutch? ATS Twin disk Carbon Clutch w/flywheel
6. What braking system, stock, brembo, stoptech? Stock to start upgraded last week to AP racing
Never had problems with temps, but did not race car. Had problems with oil & powersteering temps though. Upgraded both Oil and PS coolers and now Radiator for the future engine build.
I am running 2 maps, one for each boost level.
Moving to built engine and 600 + whp this winter.
Old Dec 5, 2005 | 07:21 PM
shaun_walsh's Avatar
shaun_walsh
1. How many miles with the Greddy? 65K
2. Whats your whp? PSI? 352 RWHP 5.6 P.S.I.
3. Did you upgrade the radiator? FMIC
4. Fuel return? Greddy
5. Stock or upgraded clutch? Stock
Getting ready to do a build up and shoot for 500 RWHP.
Shaun
Old Dec 5, 2005 | 07:57 PM
nexstage350
keep it coming
thanks
Old Dec 5, 2005 | 08:05 PM
Aloharacing's Avatar
Aloharacing
Old Dec 5, 2005 | 08:14 PM
nexstage350
Originally Posted by Aloharacing
1. How many miles with the Greddy? 10K
2. Whats your whp? PSI? ~400 @ 8psi
4. Fuel return? No, just walbro
5. Stock or upgraded clutch? ATS clutch/flywheel
6. What braking system, stock, brembo, stoptech? Stock (touring)
did u have any heating issues?
Old Dec 5, 2005 | 08:47 PM
Aloharacing
None.
Old Dec 6, 2005 | 09:30 AM
G2FAST's Avatar
G2FAST
Great info building here, keep posting!!!
Old Dec 6, 2005 | 12:57 PM
Tantrum Z33's Avatar
Tantrum Z33
1. How many miles with the Greddy? 3500
2. Whats your whp? PSI? 428whp @ 9PSI
3. Did you upgrade the radiator? Yes...Found out that coolant is leaking from the stock radiator under hard runs. (Signs of coolant leakage around the stock radiator and around the pipings near the under tray.)
4. Fuel return? AAM
6. What braking system, stock, brembo, stoptech? Brembo w/ Hawk HPS & Brembo rotors
Old Dec 6, 2005 | 02:41 PM
roncfpz's Avatar
roncfpz
I think I answered this on 350zmotoring, but I'll also post it here.
1. How many miles with the Greddy? 1,200
2. Whats your whp? PSI? 401whp @ 8psi
4. Fuel return? AAM/Walbro
5. Stock or upgraded clutch? Stock 5AT
6. What braking system, stock, brembo, stoptech? GREX
Old Dec 6, 2005 | 04:46 PM
Beer Goggles's Avatar
Beer Goggles
G2fast, once i get mine back you can come check out the stock setting of 5.5 and see how it feels.
