What's a quiet, free-flowing exhaust for TT ?
Old Dec 8, 2005 | 05:23 PM
marluci7's Avatar
marluci7
I did have the jwt flywheel also but scott performance took it out a few thousands miles ago... now its a stock one..
Old Dec 8, 2005 | 05:30 PM
MIAPLAYA's Avatar
MIAPLAYA
Because of noise?
Old Dec 8, 2005 | 05:34 PM
marluci7's Avatar
marluci7
Originally Posted by MIAPLAYA
Because of noise?
not really the noise.. but the vibrations.... with high boost its very important that the flywheel is balanced...
Old Dec 8, 2005 | 05:44 PM
MIAPLAYA's Avatar
MIAPLAYA
Gotcha...I plan to run the Jun flywheel myself....gotta love that ChomeMoly
Old Dec 8, 2005 | 05:57 PM
LOU's Avatar
LOU
Originally Posted by slay2k
Yeah I met Marin, his car's on the lift getting 10 billion RWHP put in, or something
Tomorrow Ted's gonna put in longer 24" resonators. Apparently I have 18" ones right now. He says that should tone the loudness down like 40%. That would be about perfect -- we'll see.
That's definitely cheaper than buying a whole new exhaust. Hopefully it works out for you. My car is so loud I got a ticket on the FREEWAY for having a loud exhaust. Superchargers don't muffle any sound like turbos do.
But, I like loud cars, so it doesn't bother me.
Old Oct 16, 2007 | 06:37 AM
rcdash's Avatar
rcdash
Bumping this old thread because my FastIntentions 2.5" true dual *may* be limiting my TT (700bb) hp output. Is moving to a dual 3" worth a 20 whp gain (which is all I would surmise I could gain - on a DD dyno).
I love the FI relatively quiet exhaust note. No such thing as a quiet dual 3" exhaust is there? (I am running the APS 3.5" test pipe right off the turbos). On the fence if I should go with the APS 3" dual exhaust - it's just that I'm so close to my goal - ha - probably not worth it...
Old Oct 16, 2007 | 06:56 AM
BrianLG35C's Avatar
BrianLG35C
I'd go with the EVO TT. I was concerned as well with the noise of a larger exhaust going from my Nismo to this exhaust but I'm glad I did. It was a little louder but not by much. But I have 2.5" TPs instead of the 3.5". Is the cost worth the potential hp gain, that's another question I can't answer.
Old Oct 16, 2007 | 07:36 AM
Zivman's Avatar
Zivman
If you have any concerns about the exhaust being too loud, I wouldn't get it. How is the exhaust limiting you? You litterely can't up the boost a 1 lb or two and make the power goal.
The 3" APS is a nice exhaust, but crazy loud. I would recommend to ride in a car equiped with one for a while and see if you can handle it.
IMHO, it isn't worth switching it out for 20hp. I would just find a dyno that reads a tad higher, run your car on it, get a dyno sheet reading that 20 hp higher and call it a day.
Old Oct 16, 2007 | 07:52 AM
rcdash's Avatar
rcdash
Ha ha - you are a smart man. The dyno in question isn't called the heartbreaker for nothing. I will do as you say and just be happy with what I've got.
Old Oct 16, 2007 | 07:54 AM
Zivman's Avatar
Zivman
So what is your goal?
My goal was to get something around 500 that idled perfect and didn't blow up.
500 - check
idle - check
didn't blow up - check, but only 1800 miles on it
Old Oct 16, 2007 | 07:59 AM
genegoesfast's Avatar
genegoesfast
another vote for the evott....f'n incredible
Old Oct 16, 2007 | 08:23 AM
rcdash's Avatar
rcdash
500 - check
idle - check
My goal was similar. I am at a bit of a disadvantage with a 5AT though. I'm in the ballpark and like you said, I could go to a Dynojet and call it a day -it's just a damn #. I have yet to drive the car - this Sunday is the day!!! Will post something up after I have my baby back and a few hours on the road .
As in incredibly loud? Or incredibly quiet? Cause I can't take no drone
Old Oct 16, 2007 | 08:31 AM
Madelinot's Avatar
Madelinot
Here are some videos of the APS TT + APS true-duals:
http://videos.streetfire.net/video/8...15f38d0014.htm
http://videos.streetfire.net/video/8...83cd0fa882.htm
http://videos.streetfire.net/video/9...c576fc5d9b.htm
Old Oct 16, 2007 | 08:48 AM
rcdash's Avatar
rcdash
Thanks for the clips - I like the APS 2.5 - it's the 3" one that I'm considering (well was considering) but worried about the noise. Those are the 2.5, right?
Old Oct 16, 2007 | 03:08 PM
Madelinot's Avatar
Madelinot
Yes, 2.5" TD APS exhaust... Good luck!
Old Oct 16, 2007 | 08:10 PM
Escobar's Avatar
Escobar
Do you think the HKS hi-power would work ok with a TT set up? I really love that exhaust and plan on going FI in the distant future.
Old Oct 16, 2007 | 08:19 PM
rr_z33's Avatar
rr_z33
AAM 3" Titanium True Dual for the win ;-)
only gets loud when you make it. even at wot its not that bad.
Old Oct 17, 2007 | 07:22 AM
  #38
Zivman's Avatar
Zivman
it can be used, but there are better exhausts
Old Oct 17, 2007 | 07:26 AM
  #39
THE ROADSTER's Avatar
THE ROADSTER
I got over 500whp and got Greddy EvoTT. It's very quiet.
Old Oct 17, 2007 | 07:36 AM
  #40
Zivman's Avatar
Zivman
just keep in mind with the evoTT, that the exhaust tapers at the point it meets up with the cats/test pipes. You will want to have that section cut out and replaced to remove the bottle kneck
