SFR twin plenum intake manifold
Old Jan 7, 2006 | 07:16 PM
  #121
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
That 300ZX intake is bad ***.Here is a pic of the new twin plenum we are working on for the VQ35.We should have a finished product this week to do some testing on.I will post some pictures with the Single TB.Basically it will have a pipe that comes off the inlet of the plenums which make their way around the timing chain cover and into a single flange for the TB which will be right in the center of the timing cover(very similiar to the Halvoline G35 except that this will fit with a stock hood).It is a very symetrical set-up and we have built plenums like this in the past that flow excellent so this should provide big horsepower and torque gains.If you want to run twin TB's, you should be able to keep the drive by wire.We have to do a little more reasearch on this before we will know for sure.
Old Jan 7, 2006 | 07:53 PM
  #122
Ep3's Avatar
Ep3
i appreciate your company's research and product development even if i dont have the $ for this for another year.. Good Stuff
Old Jan 7, 2006 | 11:35 PM
  #123
ChromiumBlue's Avatar
ChromiumBlue
that looks... cool? weird, but cool.
Old Jan 8, 2006 | 05:03 AM
  #124
Fairlady_z33's Avatar
Fairlady_z33
Thats going to look nice
Old Jan 8, 2006 | 07:41 AM
  #125
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Looks nice, and expensive. Any ideas on the gains? I assume you can use this in an N/A setup, would you be offering an option with an intake and filter?
Old Jan 8, 2006 | 09:01 AM
  #126
TurboTim's Avatar
TurboTim
Actually, it is not going to be as expensive as you think The gains depend on the application.With this style plenum on a turbocharged 4 banger we have seen as much as 40WHP gain at 20 psi of boost.On an inline 6 at 30 psi we have seen over 100WHP. On a VQ35 N/A application with cams,long tube headers,etc.....20 WHP should be possible.We will have to do some testing so these numbers really mean nothing at this time.
Old Jan 8, 2006 | 09:35 AM
  #127
Vq.turbo.DremZ
That sounds great. Would you test the manifold on mutiple setups?(i.e. stock 287hp motor, 300hp rev-up, Minor boltons, F/I, etc.) Also do you have any ideas when the release would occur.
Old Jan 8, 2006 | 09:46 AM
  #128
TurboTim's Avatar
TurboTim
We will be testing it on alot of different set-ups.Release date will be sometime in February.The orignal intake set us back a month.Oh well, live and learn.
Old Jan 8, 2006 | 09:51 AM
  #129
captj3's Avatar
captj3
Please test it 9.5 psi. I would like to know what the gains would be over just a plenum. Will this work with APS TT?
Old Jan 8, 2006 | 10:23 AM
  #130
Vq.turbo.DremZ
February? Thats not to bad, but again what will you do with the N/A setups? Will you have an intake and filter to go along with the manifold as an option? Since you are going to relocate the throttle body to the front of the engine bay, most aftermarket intakes would not work. I Know its just a pipe and a filter but in terms of fit & finish it might be a good idea. idk just a thought.
Sorry for all the questions but what about the stock sturt bar? Will it be retained? BTW thanks for all the info and contributions you do to this forum
Old Jan 8, 2006 | 12:39 PM
  #131
shaun_walsh's Avatar
shaun_walsh
If you want to try a Greddy TT, I am local to OC and would be willing to try.
Shaun
Old Jan 8, 2006 | 01:31 PM
  #132
Quamen's Avatar
Quamen
Hmmm. This could be very interesting.
Old Jan 8, 2006 | 03:01 PM
  #133
Julian@MRC's Avatar
Julian@MRC
Tim,
Put us down for one of the first ones finished so we could do some testing on our beast from the east...LOL
Old Jan 9, 2006 | 07:26 PM
  #134
Quamen's Avatar
Quamen
Here is my questions regarding this manifold and my specific turbo setup. I have a single turbo mounted up near the timing chain cover (check www.putfile.com/quamen ). I am looking to run this manifold possibly in the future, but I would need to use the twin throttle body setup becuase of my turbo location which I do not see as being a problem (using the intercooler in the picture I attached that had a inlet on the top of the intercooler and two outlets on the bottom.). The only problem I see is could this cause un even mainfold pressures between the two banks. I will be able to get the inlet to be directly in the center of the intercooler and for the pipes from the intercooler to the TB to be the exact same lengths so I dont see a problem there. Is there anything I am overlooking that could cause problems with manifold pressure?
Old Jan 9, 2006 | 07:28 PM
  #135
Quamen's Avatar
Quamen
Attached Thumbnails SFR twin plenum intake manifold-layout4performance2_07.jpg
Old Jan 9, 2006 | 07:29 PM
  #136
Quamen's Avatar
Quamen
ok that picture didnt show up. Check out www.activeperformancecooling.com in the intercooler section
Old Jan 10, 2006 | 08:21 AM
  #137
TurboTim's Avatar
TurboTim
The plenum is mounted with the stock stut bar in the newest picture.For production, I dont think we are going to build these to fit with the stock strut bar.It is a very tight fit so we will probably make our own strut bar or you can use a Stillen bar or something to that nature.We will be offering a few different intake pipe set-ups for N/A guys as well as turbo guys.
Old Jan 10, 2006 | 11:38 AM
  #138
Vq.turbo.DremZ
Tims the MANN!?! That thing looks pretty sick, I Def. want one. I wonder if you can use the motordyne gasket with that intake manifold
Old Jan 10, 2006 | 02:27 PM
  #139
Fairlady_z33
How much will it be
Old Jan 10, 2006 | 03:43 PM
  #140
XBS's Avatar
XBS
Veteran
Estiamted price is suppose to be around $1 million USD, send paypal to xbs1@comcast.net
