SFR twin plenum intake manifold
Old Jan 12, 2006 | 03:54 PM
  #161
Bubble's Avatar
Bubble
-REPLICA ARMY-
Originally Posted by TurboTim
the design look too busy with too many corners. Thinking about have some cleaner design? I would rather buy the Kinetic SSV over this design.
Old Jan 12, 2006 | 04:01 PM
  #162
sentry65's Avatar
sentry65
the burninator
stock strut bar is strong as hell. Stronger than most aftermarket bars
Old Jan 12, 2006 | 04:24 PM
  #163
Ep3's Avatar
Ep3
it does look busy.. but it looks mad pimp too all that said i dont care how it looks if it makes powa
Old Jan 12, 2006 | 04:35 PM
  #164
eat rice z33's Avatar
eat rice z33
100% correct, stock bar doesnt haev vertical pivot points, so indeed it is the strongest strut bar out there right now for the 350z
Old Jan 12, 2006 | 04:41 PM
  #165
thawk408's Avatar
thawk408
Where's the maf go?
Old Jan 12, 2006 | 05:24 PM
  #166
dgz32's Avatar
dgz32
Looks nice. Reminds me a little of the Z32. Single intake sitting inside bumper, then the MAF, pipe split, then runs into dual TBs. Can't wait to see some numbers...
Old Jan 12, 2006 | 06:29 PM
  #167
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Originally Posted by thawk408
Where's the maf go?
Somewhere before the TB We will be making pipes with a flange for the MAF hotwire for all kinds of different set-ups.On our turbo kit there will be a 3" pipe that feeds the TB, which sits underneath the drivers side pipe that feeds the drivers side plenum. The MAF will be on this pipe then the blow-off and then a quick turn towards the front of the car to my intercooler.This will be the same set-up for the APS TT kit.
Old Jan 12, 2006 | 06:31 PM
  #168
TurboTim's Avatar
TurboTim
It is not all about looks.It is about performance.We think this will perform better then anything out there but we need to test it to know for sure.I personally think it looks sick.It is very symetrical and it will fill up the engine bay with lots of polished goodness
Old Jan 12, 2006 | 07:13 PM
  #169
overZealous1's Avatar
overZealous1
i too think it looks pretty bad ***. do the runners have a horn on them in the plenum area? hopefully you can get the air traveling straight by the time it goes through the throttle body. if it does you should get good distribution. atleast you figured out a way to move the maf and get around the timing chain cover. can't wait to see the finished prototype.
Old Jan 12, 2006 | 08:52 PM
  #170
ZON's Avatar
ZON
Speaking of...How can a strut tower work/fit with this new two plenum design???
Old Jan 13, 2006 | 07:46 AM
  #171
TurboTim's Avatar
TurboTim
The runners have horns on them right at the plenum.Nothing was sacrificed on this intake.I will take some pictures of the inside when I find the charger for my digital camera
Old Jan 13, 2006 | 07:53 AM
  #172
TurboTim's Avatar
TurboTim
The stock strut bar fits with this plenum.I will take some pics of it.The only problem is that we are not sure if we can get it to fit with every intake because everything is so close and if each intake is not exactly identical to the prototype,then it wont fit.The big problem with making completely identical parts is each plenum is pressed in a fixture on a 40 ton press and there is a little variance from one part to another.So we will probably advertise it as not working with the stock strut bar.We will see though
Old Jan 13, 2006 | 08:57 AM
  #173
350z-900whp's Avatar
350z-900whp
it looks power-full and smooth,
Would it fit on any bolt-on turbo-kit or just your own turbos, cause the throttle-body in the middle and the piping for any bolt-on turbo is located in the upper left side of the engine. so, do we have to custom our own pipe if we want to get this intake manifold.
what the expectancy that this manifold will gain (HP)
Old Jan 13, 2006 | 09:42 AM
  #174
eat rice z33
ok turbo tim, its that time, slap this ***** on your NA car and slap that ***** to the dyno, then after that slap some utec or emanage ultimate and tuen that ***** and then let us know!!! MUST DYNO NOW!!!!!!!!
Old Jan 13, 2006 | 10:11 AM
  #175
LOU's Avatar
LOU
Looks great! Too bad it won't with a Vortech...
Old Jan 13, 2006 | 10:18 AM
  #176
OldManZ350's Avatar
OldManZ350
Turbo Tim,
Sharp looking Intake.........
I have a Vortech Supercharger.
How about making it work for me?
Timrod
Old Jan 14, 2006 | 12:00 PM
  #177
acg's Avatar
acg
Ahh Tim I said you could have my car for testing this on a Vortech system on the G35driver forum, now you tell us it won't work for us guys
Old Jan 14, 2006 | 02:19 PM
  #178
captj3's Avatar
captj3
Tim will a upgraded radiator fit with this and TT's with the throttle body in the front?
Old Jan 14, 2006 | 03:28 PM
  #179
Julian@MRC's Avatar
Julian@MRC
So you would rather pay for a chrome plated paper weight? The Kinetix plenum has not proven to make a sinlge HP to dat,at least not on any legitimate independant dyno I have seen..Form follows function remember that..
Old Jan 14, 2006 | 08:10 PM
  #180
Z350Lover's Avatar
Z350Lover
Tim,
this is gonna be the best looking plenum setup for the z that I have ever seen and i am sure it will work as well as it looks.... nice job guys and cannot wait to see the final product!!! Keep us posted please!
cheers
richie
