eManage Ultimate 2-Step Video...finally!
Old Dec 15, 2005 | 07:16 AM
taurran's Avatar
taurran
Nice! That would be great for doing 100yd burnouts.
Old Dec 15, 2005 | 07:32 AM
Jaki's Avatar
Jaki
Pretty sweet video. Lets see one you doing a launch (exterior and interior view)
Old Dec 15, 2005 | 08:17 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by 002-M-P
Its based off throttle and speed input. When the speed is 0 and throttle is put to more than 50% (can be changed between 50% and 100%), then it engages that rev limit. Then when you release the clutch and the car starts moving it disengages that rev-limit until you are at a complete stop again. It is basically always armed, but you really have to commit to the throttle to get it to engage.
Couldnt have said it better myself. It releases the lower rev limit as soon as it picks up speed signal input. Since clutch launch points can vary, the speed signal is the best approach for two-step deactivation.
Old Dec 15, 2005 | 09:17 AM
Jergens's Avatar
Jergens
That is so freaking cool.... gah!
Old Dec 15, 2005 | 09:31 AM
BLN350Z's Avatar
BLN350Z
I am confused as to the purpose of this "2-Step"......... Does it help with Launching the car ?
Old Dec 15, 2005 | 10:26 AM
Sharif@Forged
Forged Performance
Yes it does. The thing with launching, is you want consistency, first, and then the ability to build boost when staging the car. With a turbo car, you arent going ot build boost untill there is load on the motor, which means the car usually has to be moving. For instance, if you free rev the car to 4000rpm and hold it there normally, you will see tons of vaccum, rather than boost.
With 2-Step, you can set a lower launch point, but still floor the accerator. This initiates ignition cut at the desire launch RPM, and allows you to build boost while remaining stationary. You should experiment with different launch RPM's, until you get your best 60ft times.
Old Dec 15, 2005 | 11:26 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Awesome, Id love to see a launch from outside the car.
Old Dec 15, 2005 | 11:28 AM
Nismo.Z's Avatar
Nismo.Z
Originally Posted by overZealous1
my friend was walking behind my car and i did the 2 step to scare him. it worked, he jumped then it blew smoke on him, hahhaa. the 2 step was just dropping spark in a sequence to spit fuel into the exhaust then ignite with the explosion spinning the turbos faster thus creating the boost at bairily any load.
so in which part of the exhast does the explosion occur? also, wouldn't this create damage to the exhaust?
Old Dec 15, 2005 | 12:34 PM
overZealous1's Avatar
overZealous1
the explosions are small enough to not do any damage. all that is igniting is the spent fuel from the cylinder that didn't fire and the other firing cylinder ignites it. it happens before the turbo. like little mini backfires.
Old Dec 15, 2005 | 01:42 PM
dynamic6er's Avatar
dynamic6er
Nice Sharif! I should warn everyone though. Don't use this for more then a few seconds on the line. Maybe ~30 at most (even thats a long time - personally I don't go for more then 15 seconds). Also, this will casue damage to the turbos over the long term. Essentially unburnt fuel (which explodes in the manifold) and ultra hot gases are being expelled at the end of each cycle (exhaust stroke). This causes tiny shock waves that help to spool the turbo but can also lead to long term bearing and wheel damage as well as valve damage due to the high amounts of heat if used for extended periods.
Old Dec 15, 2005 | 01:45 PM
nissansource's Avatar
nissansource
His EGTS looked low in the vid that was one thing i was watching
Old Dec 15, 2005 | 02:25 PM
Sharif@Forged
Forged Performance
Thanks for the reminder. I posted that warning on the other thread. I usually dont do this for more than 10 seconds or so at most. You also want to watch your EGT's, becuase sustained use of 2-step can cause EGT's to really skyrocket.
Old Dec 15, 2005 | 02:52 PM
BLN350Z's Avatar
BLN350Z
ok so now i understand Sharif. I guess being S/C'd it's not for me .
Old Dec 15, 2005 | 03:30 PM
tig488's Avatar
tig488
sounds like a high hp supra hitting the limiter, sounds great.
Old Dec 16, 2005 | 07:55 AM
Jergens's Avatar
Jergens
Idiot question... is this an electronic add on to the GReddy E manage Ultimate 2? Or is this something that is meant for the ultimate 2 that works with the car's stock ECU? In other words (Not that I would get it.) would this work with an APS unit and the software they supply? Or is this a programming option with the U2 piggyback?
~Josh
Old Dec 16, 2005 | 08:28 AM
Sharif@Forged
Forged Performance
~Josh
Hey Josh,
This is part of the standard programming inside the eManage Ultimate box. It is not seperate module, so you would need the EU in order to do the 2-Step function.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Depravity
Oct 1, 2015 04:49 PM
z33z_nutz
Sep 23, 2015 07:22 PM
torchkc
Sep 11, 2015 08:26 PM
Aloharacing
Apr 16, 2003 04:16 PM
