Keep an eye on Power Enterprise in 2006
Old Dec 15, 2005 | 06:42 AM
vq35carel's Avatar
vq35carel
Default Keep an eye on Power Enterprise in 2006
Big things to come.
Old Dec 15, 2005 | 06:46 AM
nissansource's Avatar
nissansource
yawn like what? =)
Old Dec 15, 2005 | 06:59 AM
symalik's Avatar
symalik
poops
Old Dec 15, 2005 | 07:05 AM
theking's Avatar
theking
Thanks for the heads up. Oh, and nice sig. Did you miss anything?
Old Dec 15, 2005 | 07:13 AM
taurran's Avatar
taurran
Hey guys, he is right. I hear they are building a flux capacitor for the 350z in 2006.
Roads? Where we're going, we don't need roads!
Old Dec 15, 2005 | 07:52 AM
nissansource
I got a flux capacitor also
Old Dec 15, 2005 | 09:07 AM
vq35carel's Avatar
vq35carel
Default we will see ya on the other side of 700hp
Stage 2 turbo kit bigger turbos
Old Dec 15, 2005 | 10:45 AM
vq35carel's Avatar
vq35carel
Talking know what
Flux that
Old Dec 15, 2005 | 11:54 AM
theking's Avatar
theking
The turbos in all these kits haven't been what's keeping us on this side of 700whp(if that's what you're talking about). It's always been the engine.
Old Dec 16, 2005 | 05:45 AM
vq35carel's Avatar
vq35carel
SGP RACING Ultimate Long Block: $9800 + $2000 Core - Good to 1000+ Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
*Darton MID Sleeves
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons/Arias Ultimate..your choice(8.5:1 or 11.5:1)
Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*Tomei Upgraded Cams
*Ferrera 1mm Over Valve Train
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Old Dec 16, 2005 | 07:44 AM
theking's Avatar
theking
But where does the Power Enterprise kit fit into all this. My point was there are already kits that will take you to 1000whp(Twin 60-1 hifi's anyone). So who really cares about the PE kit!!!!!
Old Dec 16, 2005 | 09:54 AM
vq35carel's Avatar
vq35carel
Not true my friend, What is the max boost your Greddy turbos can put out w/ your 9.0 compression on 91 octane probably not much in that your compression is at 9.0. Im just curious if you can even run 91 octane past 9lbs of boost if at all. My expectations of running a 1000 hp car is that it would also need to be a daly driver. The PE kit max out around 16-17 psi the stage 2 kit will be worth well over 2 bars.Now what about trans mission and rear end? SGP has addressed both .And XS engineering custom push/ pull fuel return system.
Old Dec 16, 2005 | 10:14 AM
MoodDude's Avatar
MoodDude
Us in the South have access to 93 octane and your friend lives in the south.
Plus - are you expecting us totally rebuild our interals to run 17psi? That sounds like a lot of money to take my engine to a 8.3:1 compression ratio! I like my stock compression ratio with 9psi!
Old Dec 16, 2005 | 10:40 AM
Philthy's Avatar
Philthy
Boost Junkie
A lot more people have the Greddy kits than PE and have dumped a whole lot more money and parts into those Greddy kits to produce the gains that you see... All of the kits are on par +/- out of the box, and likewise, they all require additional parts to take things to the next level.
Has anyone done a head to head - non bias - comparisson of the turbos used in the Greddy, PE, etc...?
Old Dec 16, 2005 | 11:56 AM
theking's Avatar
theking
I know the Greddy 18g's can't make 1000whp but some of the other kits on the market can. You obviously know what you are talking about. Best of luck.
Old Dec 16, 2005 | 12:06 PM
KTaylor's Avatar
KTaylor
You sure bout this? I havnt peronally boosted that high yet but have been told from other people that have that they could take more then that. Im not saying your not right its just not what i had heard.
Old Dec 17, 2005 | 01:27 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
So Whats the point of this thread? Is it Just to tell us what PE might come out with or is it to tell us what you plan on getting for your car? Oh, and 2 bar is a hell of alot of boost. Has there even been any daily driven turbo Z's that have even gone past 20 psi yet?
Old Dec 17, 2005 | 02:18 PM
mistaboosta's Avatar
mistaboosta
i dunno 'bout da lvl 2 turbo kit but i'll be receiving some PE bearings and forged internals for my VQ35de next Jan
Old Dec 17, 2005 | 04:11 PM
Zilvia's Avatar
Zilvia
if the PE didnt cost enough already
non the least this will be interesting
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
