What have you broken as a result of going FI?
I'm about to get on the FI bandwagon but I would like to know what long term costs I'm up for.
Now that some of you guys have had your FI set up for a good period of time, I would like to know what things have broken as a result of the increase HP/TQ (gearbox, axles, etc)?
Thanks.
Thanks.
broke a flywheel bolt which in return ruined the clutch and flywheel. It's the debatable if it was due to FI or faulty install or a combination but it did break...
I've been going through wheel studs from changing tires constantly and because my local track wouldn't let me run on stock wheel studs...
Other than that the car is running amazingly well and I hop it will continure to do so
Originally Posted by 002-M-P
Traction...
I can't wait for the new wheels/tires to get here.
That was on Micky Thomson ET Drag Radials, not the slicks..
1 $1600 APS clutch. It only lasted 38 days.
I didn't abuse it either.
You will go through tires like a hot knife through butter.
If you keep it under 400 whp you should be ok with just a large sum of money in a clutch and tire expense account.
Respect
JET
Respect
JET
Respect
JET
Respect
JET
aps makes clutches?
Originally Posted by Jokestrap
Para, didn't you get your car back already?
