[B]Help with install, turbonetics single turbo[/B]
Old Dec 18, 2005 | 04:33 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Originally Posted by MIAPLAYA
Well if you are going to get the Tuner kit you might as well just get the Stage 1.5 full kit. it has injectors big enough for low to mid 500s and an EMS to tune with...Plus it will probably be cheaper then buying the same parts piecemeal.
Touche
Old Dec 18, 2005 | 04:41 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by jdm3fiddyZ
Touche
YOu already have the extra parts so for you the Tuner kit is perfect...
Old Dec 18, 2005 | 05:24 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
True. well, ima try to break 500 w/ this turbo, but we'll see what happens down at altered....ill keep you guys posted....
Old Dec 18, 2005 | 05:26 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Pics and videos please, dynos, kills, whatever, I would personally love to see any if not all , I will be making a couple of mine after the install is complete.
Old Dec 18, 2005 | 05:28 PM
MIAPLAYA's Avatar
MIAPLAYA
Absoutely...get whatever stuff you can posted...
Old Dec 18, 2005 | 05:45 PM
craigo'sznprgrs
Hey mia, in the last PM you sent me, you said to be carefull when tapping, don't use a drill right, also roughly how much to upgrade the turbos to the 62-1 with all the right stuff to make it work w/o labor, just parts? Would it be wise to build the engine first? Short block or go all out headwork, etc?
Old Dec 18, 2005 | 05:51 PM
MIAPLAYA's Avatar
MIAPLAYA
Right...when you run the taps into the oil pressure sensor port and into the upper oil pan for the oil return don't use a drill. Run them in by hand. As for the 62-1 it will drop right in if you use the Stage V turbine side again. I can't say for sure what you would gain from it. And if it tells you anything Turbonetics is going to use a T61 or T66 for Stage II. Before you do any of that I would HIGHLy recommend AT LEAST getting some forged pistons and rods with ARP hardware.
Old Dec 18, 2005 | 05:56 PM
craigo'sznprgrs
I will do that in about 6-8 months. thanks again
Old Dec 18, 2005 | 08:22 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Do it now! its Christmas! Get yourself a present...a near 500whp present...lol...I did
