Octane Booster
Old Jan 3, 2006 | 09:32 AM
jy535's Avatar
jy535
Default Octane Booster
What is the deal with octane booster, does it work, do people use it and is it, or can it be harmaful.....?
Old Jan 3, 2006 | 09:34 AM
D350Z10's Avatar
D350Z10
My buddy used it on his Z and said it was fine... 91 octane is to low I feel and some places thats all they have so I would use it!
Old Jan 3, 2006 | 10:02 AM
barthelb's Avatar
barthelb
Master
I was told to only use it in emergencies as most of them leave residue on the spark plugs or something like that.
jy535's Avatar
jy535
i usually use 93, i think im gonna try the octane booster, its prolly like using racing gas
jy535's Avatar
jy535
but what is an emergency to use it......?
Old Jan 3, 2006 | 11:12 AM
ht4's Avatar
ht4
I think that is only the ones that contain lead. Lead based octane boosters are IMO the best and cheapest, but if used too much, it will destroy catalytic converters and will leave deposits in your engine. Some claim that these deposits will actually EXTEND engine life as they tend to cushion valve seats (in fact, old engines did not have hardened valve seats because they DEPENDED on lead deposits). However, I would imagine that such deposits, much like carbon build-up, would be a good place for detonation to start so it should be avoided in FI cars.
Old Jan 3, 2006 | 11:17 AM
jy535's Avatar
jy535
so u would not recomend putting octane booster in supercharged 350, not even one time, and do u think it will drive and performe better... if it doesn't then there is no sense
Old Jan 3, 2006 | 11:20 AM
D350Z10's Avatar
D350Z10
When there is only 91 ocatane gas... I always use Sunoco 94 octane and some places don't have it so I always carry some around for the DRAGON!!!
Old Jan 3, 2006 | 11:49 AM
booger's Avatar
booger
I read an article in a tuner mag a while back .They did a test on some of the best octane boosters . They said most octane boosters you buy at the parts store are garbage . They may raise octane...by maybe 0.1 Thats point [1] Not [1] point . I cant remember the mag or the boosters they said were the best . They aslo compared the boosters to toulene
Old Jan 3, 2006 | 01:15 PM
mrtomcat's Avatar
mrtomcat
Nitrous Express makes a very nice and safe Octane Booster called Chemical X. They have have one for FI, Nitrous and NA....I used to use the Nitrous one when I was still spraying and it really worked
Old Jan 3, 2006 | 02:58 PM
barthelb's Avatar
barthelb
Master
Exactly, only when 93 or better is not avaliable and being FI in Cali I don't recommend running 91 all the time as the difference in quality between batches can be bad for your 91 tune. I believe the gas is very important and you should stick to the same station if possible.
Old Jan 3, 2006 | 05:39 PM
overZealous1's Avatar
overZealous1
ya if you read the very fine print on the can of whatever octane booster you grab, and it says it bumps octane 7 points. that is 0.7 of one point, not turning 91 octane into 98!! after i saw that, i figured not even worth the money at all, plus leaving deposits in the motor.
Old Jan 3, 2006 | 07:21 PM
ht4's Avatar
ht4
I think you are wrong. The boosters that leave deposits (i.e. lead based) give your octane more of a jump than that. I read the bottles of a whole bunch of them when I was in pep boys once and that one really stood out.
Old Jan 3, 2006 | 07:24 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
mix 3 gallons of touline with a full of gas. its available at your local paint store. look on yahoo for it. youll be impressed
Old Jan 3, 2006 | 07:36 PM
overZealous1
i was hoping for the best also. i grabbed the most expensive one, and the one that had the highest octane boost rating, and that is what it said. 7 full points, which would make you think 91 to 98, nope, in the finer print, it said only 0.7 of one point. not worth the money for $10 a pint or more imo.
Old Jan 3, 2006 | 09:55 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
The article in Sport Compact Car tested a few, only two really worked and they both got 91 up to 92.7 or something like that.
Chris
Old Jan 4, 2006 | 08:49 PM
jy535's Avatar
jy535
well thats horrible...... 91 to 92.7....... better off rollin with sunoco 94 around my block....
Old Jan 4, 2006 | 09:05 PM
Bboy Hustler's Avatar
Bboy Hustler
i have used octane boost in my old r33 before, for me it didnt really do much.. couldn't tell...
wadd3456
May 27, 2004 03:20 AM
ATI ProCharger
Mar 9, 2004 07:30 AM
Daytona Blue Z in Bo
Sep 24, 2003 07:40 PM
turkish_eyebrow
Southern California
Mar 17, 2003 07:00 AM
