Installing 3.12 Pulley
Old Jan 4, 2006 | 04:50 PM
MCopare's Avatar
MCopare
Default Installing 3.12 Pulley
Does anyone have step-by-step directions of changing out 3.33 pulley with 3.12? I have searched but my incompetence is showing!!! Thanks in advance.
Old Jan 4, 2006 | 04:57 PM
booger's Avatar
booger
There are 2 ways...the right way and the way I did it . The right way , would be to unbolt the blower , Let it drop down so you will be able to slide the pulley off . I just loosened up the top 3 bolts and pryed the blower over just enough to slide the pulley off . Make sure you put anti sieze on the shaft before reinstalling the new pulley
Old Jan 4, 2006 | 05:05 PM
MCopare's Avatar
MCopare
I thought I could do it that way but just wanted to see if anyone accomplished it. Which type of anti-seize did you use?
Old Jan 4, 2006 | 05:06 PM
booger's Avatar
booger
Dont know the brand...just got it a parts store
You can get at the 4th bolt easier though the fender well . While your there , clean your oil sprayer
Old Jan 4, 2006 | 05:27 PM
MCopare's Avatar
MCopare
Good call and advice....looks like tomorrow's project while I am still on leave!!
Old Jan 4, 2006 | 05:32 PM
MCopare's Avatar
MCopare
Default belts....
Will the 93.5 belt work with the 3.12 or will I need a smaller belt? Also, I do not have a compressor...would a can of keyboard cleaner work or some sort of bottled air?
Old Jan 4, 2006 | 06:02 PM
booger's Avatar
booger
I think its the 93inch belt . Been to long and Im old...lol . When you pull the oil sprayer off . You should be able to see though it . But the bottled air might work
Old Jan 4, 2006 | 06:05 PM
booger's Avatar
booger
Found the sleeve for the NAPA belt..... Micro V #060930
Fixxxercask
Nov 9, 2015 11:10 AM
