Who is interested in the Injected Performance turbo kit?
Old Jan 7, 2006 | 06:31 AM
chimmike's Avatar
chimmike
Originally Posted by UnderPressure
Ok time for some clarification.
Greg's car is a 4.3 AEBS stroker motor, hence the GT4202. Sized for the 4.3l. A kit for the 3.5l would be a sized accordingly for daily driving vs dyno queen.
Greg's car is not running UTEC.
Larger exhaust piping than what's currently on his car for extended use.
and I still say that doesn't justify needing a GT42R on the street.
a GT40R would still make 1000whp and for basically useless power on the street (unless he drives around on slicks every day)
Old Jan 7, 2006 | 08:26 AM
mraturbo's Avatar
mraturbo
Originally Posted by USN HM 350Z
obviously not going to be much of an everyday street car.
Looks cool regardless. What aAir/Fuel, Voltage and Timing control does the system have?
Thanks
Old Jan 7, 2006 | 12:45 PM
z33boi's Avatar
z33boi
thanks for the clarification. i meant to change that..they are using a standalone but i forget what..UTEC is what i wanted to use if i could
Old Jan 7, 2006 | 12:47 PM
z33boi's Avatar
z33boi
Thanks
no clue, greg could prolly answer that one for ya. you can email him at
greg@injectedperformance.com
Old Jan 7, 2006 | 03:53 PM
UnderPressure's Avatar
UnderPressure
The GT4202 was selected to achieve a given goal. There was a number that this car is designed to hit. Not there yet but should be soon enough.
Old Jan 7, 2006 | 06:13 PM
mraturbo's Avatar
mraturbo
Thanks,
I will.
M
Old Jan 13, 2006 | 08:14 PM
Soundeffects's Avatar
Soundeffects
Im coming from the Honda world so I may have a different view but... We run GT40 and GT42 all the time in BIG boost street cars. GT40 will make 700whp+ GT42R is considerably more. Reving to 9-10k rpm but still only 2.0ltr low compression. You have to put a HP goal out there in order to pick a turbo, also you need to know how much boost you plan to run as these turbos are not efficent at low levels.
I'm interested in maybe a high quality single turbo kit with GT technology..I'm still thinking it would be best to run a intake manifold that goes straight forward towards the front of the car and have the piping connect form the IC there. Save on piping (literally none). Not sure on what to do with the exhaust manifold situation...Thats still up in the air for best flow
Old Feb 19, 2006 | 07:48 PM
AParshall04's Avatar
AParshall04
Like the Jun 3.0L 350z?
