Vortech Drama (rattle..rattle) Continues.....need advice
Old Jan 12, 2006 | 06:26 AM
g8tor20's Avatar
g8tor20
Default Vortech Drama (rattle..rattle) Continues.....need advice
Hey guys. I posted a video awhile back of my horrible rattle noise coming from my Vortech Blower. Easily, most people said it was not normal and something was wrong. So...I took it to a shop to get diagnosed. The car stethascope thing located the noise in the blower. And taking the cog offf shut it up. So...I took it to Lokey Infiniti Performance Division and they too said it was the blower. So...I paid them to take it off and send it back to Vortech. Vortech said they found absolutley nothing wrong with it. They replaced the bearings and seals anyways. So...I get it back yesterday and have it put back on the car. NOISE IS STILL F'IN THERE!!
So...I just spent $400 bucks, downtime on the car and a day off of work for nothing. I call Vortech and they tell me the other possibility is the jackshaft but I have to send them my whole bracket assembly.
Here is the kicker though...both shops said the noise was coming from the blower. Should I pay more money to ship out the bracket assembly to see its the jackshaft? Should I just have TS raise the idle to 1100 (where it eventually shuts up), live with it or just end the Vortech headache and take it off? I don't know what to do and I hate throwing good money after bad. Just figured I'd get some of your thoughts on this. TIA
Jason
Old Jan 12, 2006 | 06:28 AM
g8tor20's Avatar
g8tor20
Here is the original link for the people who didn't hear it the first time
https://my350z.com/forum/showthread....ghlight=rattle
Old Jan 12, 2006 | 06:30 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Did you send the video to Vortech? Id want their opinion after having them hear it. But if I was in your shoes, Id prolly just raise the idle and forget it. No use spending more money and down time on the jackshaft-something that might not even fix the problem. Good luck to you.
Old Jan 12, 2006 | 06:32 AM
g8tor20's Avatar
g8tor20
Yes...i sent that link to Vortech and they said it was 'normal' noise. Riiiiiiight. I have heard many other Vortech G/Z and mine is not normal. So...I bucked up and shipped it out hoping it would fix it and they said nothing was wrong. So...rattle is still there. Big headache....
Old Jan 12, 2006 | 06:37 AM
Gman2004's Avatar
Gman2004
I am sorry to hear your troubles continue, but based on the number of people that have posted that they have the same noise (including me when I had the vortech), it is pretty safe to say it is normal. Maybe yours is a little louder than most, but I agree with Alberto. Just raise the idle and be done with it. Good luck!
Old Jan 12, 2006 | 06:53 AM
g8tor20's Avatar
g8tor20
Thats looking the way I might go. I may give the bracket thing a shot if the labor wont kill me.
Old Jan 12, 2006 | 07:04 AM
PoWeRtRiP's Avatar
PoWeRtRiP
Jason
I think i might know your car. is it being worked on in jax fl? i know of a guy with a nice black z getting a problem like this looked at by my buddy's shop.
Old Jan 12, 2006 | 07:13 AM
g8tor20's Avatar
g8tor20
No...it was being worked on in Tampa.
It seems to be a universal issue with this unit. Mine just happens to be super loud. Let me know what you buddy's shop says. Also...would your buddy's shop be interested in doing the labor if I get the new bracket assembly if I do go that route? Lemme know. Thanks
Old Jan 12, 2006 | 07:38 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Damn, I can't believe your still having problems, sorry to here.
Old Jan 12, 2006 | 09:08 AM
dimebagdolf's Avatar
dimebagdolf
Man,
Sorry to hear about the problem.
I know Vortech's make some funny noises, but that really doesn't sound normal to me.
I'll fire mine up and give a comparison listen when I get home tonight.
Old Jan 12, 2006 | 10:05 AM
PoWeRtRiP's Avatar
PoWeRtRiP
the owner of that car had sent the blower back to vortech but was told its fine. he then took it to another shop and had the bearings replaced. needless to say it still made noises so he took it to my friends shop, theyve had it for almost 3 weeks now trying out different stuff to make it go away.
the noise is described by my buddy as loud bearing noise at idle and under operation. im surprised vortech didnt fix it while they had it.
Old Jan 12, 2006 | 10:08 AM
g8tor20's Avatar
g8tor20
Sounds like the same problem. Well..I think I'll try the bracket (jackshaft) swap and if that doesnt fix it...raise the idle. I'm determined to drive this car without a rattle. I have spent way too much money to give up now.
Old Jan 12, 2006 | 10:16 AM
rxtrom's Avatar
rxtrom
On the second video posted in the link above it looks like the belt jumps everytime a "rattle" noise is made. Maybe it could be the jackshaft, or maybe simple as some ribs broken in the belt. Keep us posted
Old Jan 12, 2006 | 10:33 AM
g8tor20's Avatar
g8tor20
It only jumps b/c i loosed the cog belt a little. It used to be tight (last video posted) and it made a worse noise. Loosening the cog quites it down a bit but it does look like its flopping around but the cog still spins smoothly (no slipping or anything).
Old Jan 12, 2006 | 10:42 AM
PoWeRtRiP's Avatar
PoWeRtRiP
ill ask him if they ever fixed it. if so ill let u know and give u his contact info. best of luck with your s/c. its frustrating to spend that much money for a pos sounding blower.
Old Jan 12, 2006 | 10:55 AM
Zquicksilver's Avatar
Zquicksilver
That does suck... I'm still considering the VORTECH for late spring...
O'well, I'll just have the installer tighten up the belt and increase the idle to 1k+ if I do have this problem. I can stand a whine, but not sounds similar to a bike with cards in the spokes.
Zquicksilver
Old Jan 12, 2006 | 11:22 AM
350Zenophile's Avatar
350Zenophile
Sorry you're having to go through that...you might also want to calling Sam at Coastal. He's done a lot of Vortech installs on G35s and Z's.
They are just off 75 in Brandon.
Old Jan 12, 2006 | 12:58 PM
OldManZ350's Avatar
OldManZ350
Hi Jason,
Sorry to here about your problems. I've had the Vortech on my "Z" for 30,000 Miles. When I first installed it - I thought that there was a problem with it. Way to much gear noise. I played the the tension on the cog belt and that helped. If you would like to here my car, I'm in Spring Hill, florida.
Timrod
Old Jan 12, 2006 | 01:03 PM
booger's Avatar
booger
Yes...they all make this noise . Yours does seem very loud . Ive gotten mine to stop only a few times . By adjusting the cog belt and getting it just right . Its hard to find that sweet spot . I dont have my car here to go out and see , but see if you can get a straight edge on the bracket . To see if it straight . It may get pulled to the front from having the serp belt really tight.
And DAM that Street Fire is getting bad , Takes for every to play the vid
Old Jan 12, 2006 | 03:34 PM
neffster's Avatar
neffster
Jason, Timrod is Danny's bud that helped me when my pulley broke. Since you're over at SFLG35's house so much, why not let him check out your set up?
+1 on the rpm increase. Maybe you can get it increased enough so you don't lock yourself out of your car any more... KPTech mods rule!!!
