Vortech Drama (rattle..rattle) Continues.....need advice
Old Jan 13, 2006 | 10:39 AM
k3silk's Avatar
k3silk
just raise the idle i know what you mean tho you spend all that money and you just want you car done right that is the manin reason why i didnt get the that or the pro charger because of the noise it put out. so now im stuck with getting the stillen or ST and with ST there goes my warr.
Old Jan 13, 2006 | 12:31 PM
Mr_pharmD's Avatar
Mr_pharmD
you will lose your warrenty no matter what. I talked with my dealership and they said if they see my car with the sc they will not cover anything even if the sc wasnt the cause of the problem
Old Jan 14, 2006 | 01:15 PM
acg's Avatar
acg
That is not true for all dealerships as I just had my rear axle clicking fixed about 2 months ago and the fuel fill up issue fixed by my dealership. They took one look at my SC and said "ohh very nice piece of work you got there"
Old Feb 14, 2006 | 11:41 AM
Gman2004's Avatar
Gman2004
Jason,
check out this thread. Maybe this is your problem.
https://my350z.com/forum/forced-induction/171748-vortech-owners-might-want-to-check-this.html
Old Feb 14, 2006 | 11:52 AM
g8tor20's Avatar
g8tor20
Jorge...thanks for still thinking of me. Mine was installed right. But I am gonna continue with my battle....
Old Feb 14, 2006 | 01:24 PM
SungNamZ's Avatar
SungNamZ
g8tor20...I hope you find your problem! I am assuming, given that you sent the unit to Vortech, but did you check the cog? In addition to the tension pulley problem I posted in a thread, several sections of COG on the belt were gone as a result of my pulley problem. Sounded like: rocks in a can or cooling system overheating and hearing the boiling.
Old Feb 14, 2006 | 01:36 PM
KraftG35's Avatar
KraftG35
g8tor20 - I actually thought of your situation when I read sungnamz's thread. Hope you find the problem. My situation is similar to yours, however, described similar in sound to sungnam's. "Hopefully" mine was installed incorrectly as well.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
