Is anyone near 700whp yet?
Originally Posted by mrtomcat
currently I'm on 100% stock suspension, first thing is obviously the Camber kit.
Is getting a tein flex kit overkill? Do I need it or would it hurt.
The main goal of course is a compromise since I don't want a tank as a daily driver
Also who makes traction bars? That's something new to me
A Tein flex coilover kit is definitely more "handling" oriented then you want. The springs are too stiff to perform well in drag racing. Stock suspension isn't bad...but if you want to make the car handle better and not lose straight line traction, then go with a good set of sway bars and leave the rest of the suspension stock to aid in weight transfer at the strip.
The thing is...with a compromising setup you will always be giving something up. As you are right now. So I really don't see how you could make your straight line traction any better than it is right now without losing handling.
As for the traction bars....here's a link..you can probably find them cheaper.
http://www.modacar.com/products/Niss...ctionbars.html
Originally Posted by D350Z10
Could you please list the perfect setup for both maximum handling and straight line?
Originally Posted by IceY2K1Max
Did you have ARP head studs when you started having lifting issues at 600+whp?
Sharif,
So are you saying the combination of ARP head studs, Cometic headgasket and Darton MID sleeves resolves the lifting issues above 700 rwp? That is good to hear as last I noticed people were saying there was no resolution for the lifting issue even with the Cometic gasket.
The AAM Stage II fuel system is nice, it is pretty quiet and looks good/ fits real well. I am not pushing the HP envelope yet, so I will leave that to you Sharif for verification. One of these days we will finish this engine build....
Sharif what did you torque them down to? Does ARP recommend 78ft/lbs? I think once you go to closed deck then ~90ft/lbs is more like it.
Originally Posted by Sharif@Forged
Yes, the ARP studs, stock cylinder walls, and stock head gaskets. We did runs with C116 fuel so detonation was defiantely not a contributing factor.
ARP recomends 65ft/lbs with AL block, but we''re trqing them down to 72ft/lbs. The closed deck with Darton sleeves doesnt mean you can trq the studs down more. The trq numbers are established at 75% yield strength of the stud. This provides a comfort zone for expansion, so you dont yield your stud (fuke it up) under high heat/load.
If the stud was made from a different material, then you coud trq them down to greater levels. As it sits, you have 14,000 lbs of clamping load at 65/ft lbs.
that brings us back to what is the best suspension option for a 500+ whp car...because it does need to be able to handle both straight and curved runs. I liked the idea behind the tein flex because you can have different settings based on the type of run you do but based on your statement it probably won't be good enough.
This is quite challenging I must say
I guess something like a well tuned Racelogic Traction control might still be the best option
Thanks Mike for contacting me today.
Looking forward to seeing what your car can do with those 15 inch rear slicks and 18 PSI plus...
Please PM me to let me know how your car dynos and tunes...We can help for sure. Leave your email!
M
M
is that the same as the camber arms that are part of the Stillen Camber Kit?
Originally Posted by failsafe306
I know next to nothing about how suspension works, but what it be a good idea to keep the stock springs but swap in some adjustable shocks to control dampening for different driving conditions?
Some adjustable shocks could definitely help you without breaking your bank account like a full coilover set will. Also pick on a sway bar set if you don't already have one. They do amazing things without changing the ride or straight line traction of the car.
no
It is challenging and honestly the best thing you can do is just get some really good rubber...that will help more than suspension work anyday. The racelogic could be good, but I'd assume it would be pretty expensive. You could also get a gear specific boost controller so that you can have the peak boost lower in lower gears.
Gear specific boost controller won't help when breaking out. I always figured a stiffer suspension would help keep the car in check more.
and you know I'm running et streets already...but they didn't do crap once my baby took me for a ride sideways at 100mph...
One thing that I am saving up/looking for is a good racing class that deals with how to to handle your car when you loose traction, I haven't found anything like that though and the regular classes deal more with driving when everything goes well...
actually the entire racelogic package is about $1800 + install which should not be too bad...I'm getting that in about 3 weeks, so basically the same as the tein flex with edfc.
Sudden loss of traction and control while running a high power level and slicks just happens. There's not really anything you can do to prevent it. It's just one of those things. I see high powered cars on a bias ply tires get sideways frequently at the track. The problem isn't really traction it's the inability of the soft wall bias ply slicks to cope with sudden yaw motions.
I thought your whole thing was about more traction on a street tire...but a slick is a whole different story.
Mid OH has racing classes, not sure on what they tailor to but i am sure that they have smart instructors that could explain high speed control in a semi-safe enviroment.
Originally Posted by MI 35th
Sideways at a 100! Thats sweet!
If lowering the negative camber settings to a point that helps at the drag strip but doesn't kill my handling on the streets that would be another compromise.
I dont think that any coilovers you find are going to help your situation. The type of spring rates and dampening/rebound etc that you need are the exact opposite of the direction you are headed with any currently available aftermarket suspension parts that I know of.
Pretty much anytime you put in a part that is going to make your car handle better, its going to drag race worse.
I was going to call Tein and see if I could get some custom rear springs for drag racing since its so easy to just change the springs out in the back of this car. and then I was going to use my JIC camber rods and just count the turns and go to as close as I can to straight or even a little positive camber (for when i plan to drag), and then count the turns and go back to my regular settings (for standard use). At least this was what I was gonna try out for this year... not sure how much room I have to work in those JIC arms.
Hope it works!
We ARE going to see you on a road coarse this year, aren't we?
EDIT: Have you thought about running a stiffer RR spring to counteract ring gear induced chassis torque? Drag racers of old used to do this........
