60MM pillar gauge pod??!!?!?
Old Feb 6, 2006 | 08:46 PM
veilside350zTT's Avatar
veilside350zTT
Default 60MM pillar gauge pod??!!?!?
Ok guys im going with the defi BF series gauges. But they come in 60mm. the problem is that i cant find any damn triple gauge pods for the pillar in 60mm they are all for 52mm..
Any Ideas?
Old Feb 7, 2006 | 02:55 AM
Mike Wazowski's Avatar
Mike Wazowski
Most 52mm gauge pods work for the 60mm gauges also. You just have to trim the openings to make them bigger.
Old Feb 7, 2006 | 03:58 AM
huducks's Avatar
huducks
http://i-m-racing.com/induortrfuap.html
Old Feb 7, 2006 | 05:57 AM
Noah@AAM's Avatar
Noah@AAM
When we install 60m guages in an A-pillar such as autometer we dremel it out. The DEFI guages WILL NOT fit perfectly flush because of the trim ring but you would have to stick your head behind the steering wheel to notice it. If you have any questions please feel free to give me a call.
Old Feb 7, 2006 | 07:59 AM
Nitrouz's Avatar
Nitrouz
Back to Z
yup. I had one and just dremelled around it. I have 3 BF gauges and a triple gauge pod for sale in the classified section if you are interested.
Old Feb 7, 2006 | 08:25 AM
barthelb's Avatar
barthelb
Master
I recommend seeing a triple guage pod with 3 60mm guages. The guages aren't the smallest and a 3rd would be mainly for looks. Youd have to lean your head way back to look at it, unless your hella tall and have the seat all the way back.
Here's mine with 2 of them. I think its still clean and not overdone. And this is where i mounted the Link
Attached Thumbnails 60MM pillar gauge pod??!!?!?-boostegt-guages.jpg   60MM pillar gauge pod??!!?!?-cockpit.jpg   60MM pillar gauge pod??!!?!?-019.jpg
Old Feb 7, 2006 | 08:46 AM
Zivman's Avatar
Zivman
I agree that a 60mm is a big gauge, but adding a third gauge wouldn't be mainly for looks, nor would a person have to lean back or be very tall to see them.
Old Feb 7, 2006 | 08:49 AM
MIAPLAYA's Avatar
MIAPLAYA
Someone call hell and ask how cold it is cause I actually agree with you here. Granted I have 5 52mm gauges but all of mine serve a purpose. Especially if you track the car...
Old Feb 7, 2006 | 10:09 AM
barthelb's Avatar
barthelb
Master
3 52mm on the pillar isn't bad, i exaggerated a lil with the lean the head back thing but a friend of mine has a G35 with 3 60mm and it seems like that top one is just way out there. The 52's look good tho.
Old Feb 7, 2006 | 12:22 PM
huducks's Avatar
huducks
60 mm works for me.
Old Apr 23, 2009 | 01:42 PM
xzotklr's Avatar
xzotklr
Any Ideas?
I finally got around to fiting my 60mm defi's in my Autometer triple pillar gauge pod. I was inspired by some of the posts here.
Thought it would be impossible without damaging the pod, but it was really easy to do.
As mentioned I used a Dremel with a sandpaper attachment. I removed the lip by sanding the inside until the lip was gone, then slowly kept widening the hole making sure to constantly test fit until ..voila!!! Took me about an hour.
Old Apr 25, 2009 | 12:04 PM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by huducks
60 mm works for me.
Very, very nice setup. Very clean. I like it.
I also have a Willow Interior and the same gauge pod. All of my sensors are HKS and wired into my F-CON, but by the time I got around to ordering the gauges, the ones I needed were no longer available. I guess since introducing the CAMP II, HKS does not feel it needs to offer gauges anymore. As for me, I would rather look at traditional gauges than an LCD display. All of the data is displayed in the Navigator, but displaying anything more than two readings on the small display is a waste because you can't read them quick enough while running on the track.
I am debating between adding a CAMP II or buying Defi gauges and sensors. It seems a waste to have two sensors each measuring the same readings, though, and I already have the HKS sensors.
Old Apr 25, 2009 | 12:14 PM
ttg35fort's Avatar
ttg35fort
Professional
If anyone has matching 52mm or 60mm HKS Fuel Pressure, Oil Pressure and Oil Temperature gauges for sale, I am interested in buying these.
If you only have one or two of the gauges I need, I am NOT interested unless you know where I can get the other one(s) that match and they also are available.
If you have these, please PM me a price.
bcoffee20
Nov 19, 2015 06:39 PM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
Calinismo350z
Sep 14, 2015 04:04 PM
