GoVRT and JWT / And Another One...
Old Feb 10, 2006 | 05:42 PM
mraturbo's Avatar
mraturbo
Default GoVRT and JWT / And Another One...
Thought you would enjoy this new car we just finished.
Warmly,
M
Old Feb 10, 2006 | 05:43 PM
JimRHIT's Avatar
JimRHIT
very nice
Old Feb 10, 2006 | 05:44 PM
speedlimits's Avatar
speedlimits
wow
Old Feb 10, 2006 | 05:46 PM
bacalhau16's Avatar
bacalhau16
wow, that car is a beast. Love the torque #'s.
Old Feb 10, 2006 | 05:53 PM
SinCity350Z's Avatar
SinCity350Z
Track Whore
Your army is growing VRT!!!!
Old Feb 10, 2006 | 06:00 PM
bacalhau16's Avatar
bacalhau16
that video you have on your website reminds me why i work so many extra hours...trying to afford the JWT twin turbo setup, oh ya!!!
Old Feb 10, 2006 | 06:26 PM
mraturbo's Avatar
mraturbo
We are trying...Have a Red Z, Lemans Sunset Z, and a G35C Auto coming soon.
M
Old Feb 11, 2006 | 11:25 AM
Eagle1's Avatar
Eagle1
Car will be fully track tested this week, then at the DUB Magazine show at the LA convention center on Sunday the 19th, and the Performance Nissan show on Feb 25 at Citrus College.
The car was tuned by Jim Wolf and Clark on a dynapak at their facility in El Cajon. Many of the mods below were previously done, but this is the current package with the VRT engine build.
Engine/drivetrain modifications:
JWT TT using modified T-28 Garret ball bearing turbos, CP pistons at 8.5 to 1 static compression ratio, Pauter rods, Jim Wolf S2 cams, high flow intercooler
Thermal coating to inside and outside of exhaust manifolds and turbo housing using TurboX, and to piping using CermaKrome, both metallic-ceramic.
Motordyne iso-thermal plenum spacer with aramid gasket
JWT aluminum oil pan spacer
Koyo aluminum radiator, Redline Water Wetter, Peak coolant-water mix
Samco hoses
Amsoil pre-oiler and BMK-13 bypass filter, 10+ quarts amsoil 0-30W oil.
Stillen oil cooler
Nismo Power steering cooler
Odyssey lightweight dry battery
Fluidamper harmonic crankshaft balancer/pulley
ATS lightweight flywheel and triple disc carbon clutch
Nismo lsd with redline differential oil and MOC lubricant
HKS dual exhaust, crawford high flow catalytic converters
Handling Modifications:
VRT strut tower brace front, Stillen strut tower brace rear
Stillen sway bars front/rear
Nismo bushings
Tein Flex coilover dampers with 12kg springs
Tein Electronic Damping Force Control unit
Performance Nissan adjustable front upper control arms
Stillen rear camber links
Stop Tech 14.1" big brake kit with Motul 600 RBF, Pagid Orange brake pads
Enkei NT03 +M wheels powder coated black
Nitto NT-01 tires 275/35/18 F and 315/30/18 R
Corner balanced
Miscellaneous:
Rogue short shifter with Nismo rubber GT ****
Autovation drilled pedals
Custom welded six point roll bar with quick release harness bar
Vis vented carbon fiber hood (painted oem ivory pearl)
Sparco Milano front seats with pull down harnesses
Full array of electronic warning gauges and meters, electronic boost controller, etc
Old Feb 11, 2006 | 12:45 PM
mraturbo's Avatar
mraturbo
Thanks Big ER!
Here is the car.
VRT/JWT 2003 G35C
Samco hoses
Stillen oil cooler
Nismo bushings
Corner balanced
Miscellaneous:
Old Feb 11, 2006 | 12:57 PM
tig488's Avatar
tig488
i would like to see more pictures please!
from what i can see, it looks nice, and should do very well at the track.
have you had it weighed yet, id like to know how much it weighs.
Old Feb 11, 2006 | 01:10 PM
Eagle1's Avatar
Eagle1
It weighs 3564 lbs, all in and with fuel, but without driver. The car was corner balanced with 190 pounds in the driver seat to simulate driver and his gear, such as helmet etc.
The build has been chronicled at FA in four chapters so far, with lots of pictures. It is the sticky thread of Conversion from SC to TT.
Here is the link to the fourth and most current chapter. There are also many embedded links to various parts used in the build.
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Old Feb 11, 2006 | 01:33 PM
tig488's Avatar
tig488
eagle1, i did not know that was your car, i havent been to FA in a while. the car has come a LONG way since the SC. very nice job, it looks great and will be a dominator on the track im sure.
congrats on the baddest G!
my car weighed in at 3480 with no driver. of course, i dont have near as much hp and tq as you.
Old Feb 11, 2006 | 01:44 PM
G352NV's Avatar
G352NV
Nice car!!
Old Feb 11, 2006 | 01:47 PM
bsp's Avatar
bsp
Brainstorm Performance
Those are some pretty nice results. Congrats to the owner
Old Feb 11, 2006 | 03:26 PM
Zilvia's Avatar
Zilvia
566ftlbs.........crazy
Old Feb 11, 2006 | 03:32 PM
2 low Z's Avatar
2 low Z
Nice... Should be fun at the track with all that torque. Not trying to hijack, but did you notice at all if the HKS dual is restrictive at 12 psi?
Old Feb 11, 2006 | 05:09 PM
Eagle1's Avatar
Eagle1
I was 150 miles away with a head cold and could not attend the dyno tune (sobs and sniffles). So I think Mike or Scott will have to give you their impression. The HKS is to my reading one of the very least restrictive and free flowing units at 2.5". (also one of the louder ones, which could be a problem at Laguna Seca with the 92 db noise limit). Having said that, we all know that one of the indicia of a restrictive exhaust is the presence of a high torque and lower horsepower readout. A larger 3" diameter pipe might arguably be called for to free up horsepower "trapped" by restrictive exhaust.
But.....there are other factors at work here, not the least of which is that we have deliberately chosen smaller turbos for faster spool up and earlier power, with little to no lag. We have then attempted to enhance that even further with the thermal coatings. Trapping heat inside the manifold and turbo housings should cause higher gas velocities, as should the coating surface itself being smooth and reducing tumbling, making for faster spooling and earlier and more power...plus the reduction in ambient engine compartment temp should be 100 degrees F or more! That means more power too. And we are trying to get a result that is in fact high torque over an extended band so that we have "launch" on turn exits...it is high end torque that gets us moving from 75mph to 140mph...that is exactly what we are after! Within at least two full alternative gearing choices. And we are getting it. This was carefully planned out with the gents at VRT in advance, so I could not be happier with the outcome. This is not a couple of quick pulls "dyno queen" set up for producing a chart. This is a track b&%^* that will run the distance lap after lap without heat soak causing the performance to fade. As the song goes, this car has Betty Davis eyes and will "roll you like dice".
Old Feb 11, 2006 | 06:31 PM
WA2GOOD's Avatar
WA2GOOD
+1 on that one Ed.
I love the way your car feels already. This car is NOTHING short of a complete car. It is the best feeling, most well rounded G35 I have ever seen or driven. (and that's saying ALOT )
I can't wait to track test this thing. With this car I am actually excited (and honored) to drive it. Come Tuesday I am going to miss it.. But I hope to have a few (track day) visitation rights.
Old Feb 11, 2006 | 06:32 PM
tig488's Avatar
tig488
can you quit rubbing it in already! jees!
Old Feb 11, 2006 | 07:34 PM
Mike Wazowski's Avatar
Mike Wazowski
Very nice indeed! Good work guys.
