Some JWT TT info from an FI master.
Old Feb 12, 2006 | 11:51 AM
taurran's Avatar
taurran
Default Some JWT TT info from an FI master.
[15:22] azivman3: I forgot more about FI on a Z than you know
[15:22] azivman3: you want to discuss
[15:22] azivman3: get the ball rollin
[15:23] taurran2004: well, although I would love to hear about your APS TT and how great it is. I've already heard enough
[15:23] azivman3: you haven't heard much
[15:23] azivman3: lots more to discuss
[15:23] azivman3: what you think of the JWT TT setup?
[15:24] taurran2004: what do I think?
[15:24] taurran2004: I think its a great kit. Lots of potential
[15:24] azivman3: HP potential?
[15:24] taurran2004: although it might not include a mandatory fuel return system, like the all powerfull aps tt, its still nice
[15:24] taurran2004: not that I really care, I've already made my choice
[15:25] azivman3: mandatory
[15:25] azivman3: I am not talking APS
[15:25] azivman3: I am talking other setups
[15:25] azivman3: what do you think about their fuel system since you brought it up
[15:25] taurran2004: yes, but your reference to other setups is ALWAYS a comparison to the APS TT
[15:25] azivman3: ?
[15:25] azivman3: no comparison
[15:26] azivman3: You want some real info on the kit?
[15:26] taurran2004: whats that?
[15:26] azivman3: the turbos they use spool too quickly
[15:26] taurran2004: and?
[15:26] azivman3: the engine can have trouble consuming the amout of air they produce in the lower RPMS
[15:26] azivman3: results in compressor surge
[15:27] azivman3: VRT boys haven't seen it yet
[15:27] azivman3: because most are running cams
[15:27] azivman3: not as prone to show up with cams
[15:27] azivman3: also they might not be looking for it
[15:28] taurran2004: same can be said with the PE TT, but as you stated that can be compensated for
[15:28] azivman3: PE is garbage
[15:28] azivman3: not even in the same league as greddy or jwt
[15:28] taurran2004: instant power delivery is key ion the track
[15:28] azivman3: instant power is one thing
[15:28] taurran2004: not that it really matters for the average user who doesn't compete
[15:28] azivman3: too much abrupt power is another
[15:29] azivman3: the power comes on too abruptly with the JWT setup
[15:29] azivman3: resutls in excessive wheel spin
[15:29] azivman3: broken axels
[15:29] azivman3: trannies
[15:29] azivman3: etc
[15:29] taurran2004: well in time perhaps that will come to light
Can it be true? Thoughts?
Old Feb 12, 2006 | 12:04 PM
maximumsportZ's Avatar
maximumsportZ
APS for life!
Old Feb 12, 2006 | 12:15 PM
WA2GOOD's Avatar
WA2GOOD
Hahaha....... ..Well, almost two years now (20,000+hard miles) with this JWT TT kit with lots of hard track days. No tranny, axel, drivetrain problems, and with a 305-315 mm tire in the back no real traction problems. The fuel system seems to be more than adequate for me and all of the VRT (happy) customers. So Hmmmmm, go figure....
Its cool though, sceptisism will always be there...........
Old Feb 12, 2006 | 12:46 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Wow...Ziv should have made you sign an NDA. But now that this is out in the open, this statement is untrue:
An engine will not have trouble eating up the air produced by the turbos at low RPM. The valves are open longer, and the air will find its way into the cylinders without any problems. The result, is more cylinder pressure at low RPM, and gobs of mid range trq. Compression surge is not related to the turbo spooling quickly. The BOV will do its job, regardless of how quickly the turbo spools.
Old Feb 12, 2006 | 12:55 PM
zrausch's Avatar
zrausch
Sharif is there anything you dont know?
Old Feb 12, 2006 | 01:38 PM
MIAPLAYA's Avatar
MIAPLAYA
I hate to add fuel to the flames but where on earth did you get this crap about surge from? Thats about as far off base as you can get. Surge happens for two reasons, air being trapped in the charge piping has no where to go when the throttle plate closes and as a result if there is not BOV it reverse direction and causes surge in the compressor. The second would be if you were operating a turbo at such limits that the air was not able to enter the engine even with the throttle plate full open and it caused reversion and surged the compressors. Neither of which are going to happen on this motor with those turbos... The whole assesment is as far off as it gets...
Old Feb 12, 2006 | 01:40 PM
Jaki's Avatar
Jaki
Thats highely unlikely lol
Old Feb 12, 2006 | 01:46 PM
chimmike's Avatar
chimmike
wow LOLZ....he forgot more about FI than you know Craig. Which uh, I have to disagree with completely.
the JWT kit wasn't meant to be a max HP kit....you can call JWT and ask them that point blank. It was meant to act like a stock turbo system would on the Z, no noticeable lag and good solid power.
LOL@ zivman and his APS>everything attitude. Just because it doesn't use a standalone and a full fuel return system doesn't mean it HAS to.
btw, I'd be willing to put money on the fact that Clark at JWT could own you in most aspects of technical knowledge.........same with Jim.
Old Feb 12, 2006 | 02:06 PM
ActionJackson's Avatar
ActionJackson
Seriously, its like APS has ziv brainwashed into thinking all kits have to be designed around needing a fuel return system. JWT designed their TT kit to be like a stock turbo out of the factory, which is also why they're trying to get their kit carb certified. To be carb certified in all states including the hardest one of them all "California" you have to keep all engine components stock so yes that even means stock fuel return system. I don't think its impossible to design a TT kit that does not need to upgrade the stock fuel return system if your design criteria is set right.
Old Feb 12, 2006 | 02:36 PM
Zivman's Avatar
Zivman
I prefer being called a "FI master" vs:
Originally Posted by taurran
a fking tool...
I think it is fair to say
And Sharif I am aware of the info you posted:
Old Feb 12, 2006 | 04:14 PM
theking's Avatar
theking
LOL.
Old Feb 12, 2006 | 04:28 PM
georgec's Avatar
georgec
Twin turbos that are very small/responsive can certainly suffer from compressor surge on the VQ engine at low rpm/partial throttle conditions - that is the engine cannot consume the amount of mass air flow that the turbos are producing in that particular throttle/rpm/engine load condition.
Old Feb 12, 2006 | 04:37 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Not true at all. In a compressor surge situation the BOV will not relieve pressure in the intake tract simply because it needs to see a sudden vacuum change (significant decrease in throttle) to activate.
Old Feb 12, 2006 | 05:02 PM
turismo's Avatar
turismo
PE rules!
Old Feb 12, 2006 | 06:00 PM
Sharif@Forged
Forged Performance
You are refering to two different conditions. At WOT, the BOV has nothing to do with compressor surge, as compressor surge is not going to occur at WOT, during the normal operation of the VQ motor. When the throttle plate is closed, the BOV will perform its function, assuming the BOV is properly sized, in order to vent sufficient air to prevent compressor surge.
Old Feb 12, 2006 | 06:11 PM
MIAPLAYA's Avatar
MIAPLAYA
Jim Wolf's car (Roadster he owns) does not have cams and there was no hint of compressor surge that I have heard of. I was present for the turbo shootout when his car dyno'd. Surge is typically audible and there was no audilbe surge occuring even without cams... although it may have been surging with no one being able to hear it. I'm sure Jim is well aware of the surge limit of those compressors.
Old Feb 12, 2006 | 06:32 PM
failsafe306's Avatar
failsafe306
What does compressor surge sound like?
Old Feb 12, 2006 | 07:31 PM
mraturbo's Avatar
mraturbo
Anyone in Southern Cali want to drive one, let me know!
M
Old Feb 12, 2006 | 07:44 PM
georgec's Avatar
georgec
If you get the engine load and rpm conditions right up a small hill or on a load based dyno it sounds like air rythmically pulsing back through the air cleaners quietly from side to side. Not easy to describe best I can do is a subtle air noise from each air cleaner under light engine load.
Old Feb 12, 2006 | 07:47 PM
failsafe306
Ah okay. Mine does that sometimes, I'm assuming it's harmless if it's not under aggressive driving conditions?
