ATTN: Voretch Owners HELP Needed
Old Feb 26, 2006 | 09:35 PM
sja177's Avatar
sja177
Default ATTN: Voretch Owners HELP Needed
My buddy and I finally finished installing the vortech kit tonite.
We installed RC 440 injectors, walbro 255 fuel pump and the vortech tuner kit.
We start the car, and there is an EAR PIERCING SQUEAL. It sounds as if it it would be a belt, so we disconnected the supercharger belt, so there was just the main belt, and the car still made the squeal. Also, the engine bay smells like fuel but I am pretty sure there is no leak. The injectors seemed like they were well seated, and the fuel rail was on @ss tight, and there is no fuel leaking from what I can see. Maybe the smell is there because I just installed everything? Or becuase the car is untuned?
The squeal is incredibly loud, like there is no way it could be a belt. I talked to a mechanic I know and he cant figure it out.
What could the noise possibly be?
I looked all over the place, and the belt is tight, and doesn't rub anything that I can see. PLZ HELP guys!! TIA
Old Feb 27, 2006 | 02:01 AM
booger's Avatar
booger
Normally the squeel will go away in a few sec's if the serp belt is to loose . I would start by checking the alignment of the bracket . Then I would check to see that no IC pipe is resting up against the AC pulley , jackshft cog pulley , and in front of the motor , on any of the pulleys up there
Old Feb 27, 2006 | 09:18 AM
sja177's Avatar
sja177
Ok,
I rechecked the pully, and absolutly nothing comes anywhere near it, it wasnt rubbing. I decided to take it off and the squeal was gone, thank god.
I can fix that by playing with the alignment and/or tightening it.
Now about the fuel smell. Will this go away? Im getting worried because I dont want anything to catch fire
I know the car will run rich with them, esp at cold start, but damn it smells like there could be a leak. Is this normal for new fuel setup guys? Thanks
Old Feb 27, 2006 | 11:24 AM
booger's Avatar
booger
Mine smelt like gas also . Found it was the rubber o-ring gasket , for the gas tank cover . Did you buy a new one ? When it gets gas on it , it expands and will not go back in the slot . Besides that , just check all your fuel line connections
Old Feb 27, 2006 | 12:35 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yeah, if you got fuel on the rubber o-ring on the top of the fuel bucket it expanded and won't seal back in there properly.
Old Feb 27, 2006 | 01:22 PM
backagain's Avatar
backagain
there are 2 belts that can be adjusted. one driver side and one passenger side. i had the belt squeel as well. i adjusted the adjuster on the driver side and it did nothing, then found out there is a way to adjust another belt from the front of the car between the engine and radiator. more on the passenger side. be sure to losen the bolt in the middle of the pulley and you can tighten it up by turning it clockwide. then tighten up the bolt in the middle of the pulley again. be sure to losen this bolt first or you'll bend the adjuster system and have to buy a new one.
Old Feb 27, 2006 | 02:06 PM
sja177's Avatar
sja177
Exactly how tight should i make it?, it was pretty tight before, im guessing the loud as squeal was from a loose belt?
Old Feb 27, 2006 | 02:12 PM
backagain's Avatar
backagain
yes, well, atleast my squeel was from that. doenst squeel anymore.
Old Feb 27, 2006 | 02:22 PM
sja177's Avatar
sja177
backagain,
Can you tell me how loud your squeal was? Mine was loud enough that if I left the car on for more than 5-10 seconds someone would most likely call the cops
Old Feb 27, 2006 | 02:31 PM
booger's Avatar
booger
Originally Posted by sja177
backagain,
If its that loud with the cog belt off . Make sur your pullies on the jackshaft are not grinding on the jackshaft it self , More so the serp pulley on the Jackshaft . You may even have put one of the pulleys on backwards . If thats so it would more than likely would be the cog pulley on backwards .
You can put that cog pulley on and not even know you have it on backwards . Well come to think about it , if you put the cog on backwards and tightened the bolt tight [ with the belt off ] you wouldnt be able to turn the cog pulley or it would be very hard to
Old Feb 27, 2006 | 10:03 PM
sja177's Avatar
sja177
Ok, I got everything running great now. In case anyone else has this problem, the belt was a tad loose and now its very tight to where I can barely bend the belt to the side (45-90 degrees or so)
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
SharX59
Sep 27, 2015 09:23 AM
