Denso Injectors
Old Feb 28, 2006 | 02:12 AM
MR RIZK's Avatar
MR RIZK
Default Denso Injectors
Searching through the threads it would appear that the PE 510cc injectors are re-badge denso units. Anyone know where I can get the denso's from as the PE's are just overpriced. I looked into the RC's but do not want to chop up my loom.
Cheers,
Michael
Old Feb 28, 2006 | 05:09 AM
theking's Avatar
theking
Pink Subaru STI injectors
Old Feb 28, 2006 | 06:02 AM
MIAPLAYA's Avatar
MIAPLAYA
Denso does not have aftermarket distribution here. You can order some from a Subaru dealer or get one from a wrecked STI.
Old Feb 28, 2006 | 07:25 AM
theking's Avatar
theking
Just go on Nasioc.com and you will find tons of them also.
Old Feb 28, 2006 | 11:22 AM
D350Z10's Avatar
D350Z10
Expensive
Old Feb 28, 2006 | 12:55 PM
Chebosto's Avatar
Chebosto
i just got my Pink JDM STI topfeed injectors off the NASIOC forums.
the only diffrence is the bottom of the injector there is a collar that must be fitted.. if you have an existing PE injector you can swap them over, if you're getting them fresh off the bat, you'll have to find a collar for it to fit..
i'll post picts on my STI injector thread later ...:
https://my350z.com/forum/forced-induction/173187-sti-pink-injectors-550cc-pe-510cc.html
Four used injectors are $200-$250.. new, four are $3xx.. 6 of them is less than 600...
Old Feb 28, 2006 | 01:47 PM
MR RIZK's Avatar
MR RIZK
Cool. So the STi's are drop ins and will use the same harness? Just need to additional spacer to fit.
Chebosto if put up some pictures it would be great
Old Feb 28, 2006 | 03:00 PM
bsp's Avatar
bsp
Brainstorm Performance
For the record, these are not OEM 04-05 STI injectors. The 04-05 STI switched to a side-feed config. For those of you that want to use the 565cc pink STI injectors, make sure you specify that these are JDM STI injectors. These are top-feed as Chebosto said.
