TURBONECTICS KIT blows my vq@8psI
Old Mar 8, 2006 | 09:24 AM
  #41
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by RedLeader
Miaplaya-
What kind of power should he be able to make with the Turbonetics kit on a built motor(with appropriate engine mgt.)?
Bruce
The turbo in the kit should flow out to low 500s easily...
Old Mar 8, 2006 | 09:43 AM
  #42
RB26DETT-Z33's Avatar
RB26DETT-Z33
Originally Posted by chimmike
once again I'll say:
motors don't throw rods for no reason.
if anything, from the power, your pistons would have been the first casualties.
I think you missed an oil change somewhere, or ran low on oil, and that starvation caused you to throw the rods. Other than that, it doesn't just decide to throw a rod when you're driving normally if you didn't screw anything up.
longevity isn't the argument here. I could go on all day on how you can treat a motor right, boost it, still maintain it properly, and not have one issue with it. Issues come up when normal maintenance is ignored.
Well let me see boss like I said before I babied my z, oil changes twice a month checked the oil more then twice a day checked as much as I could. this is not my first turbo car. I think you can reframe from lecturing me on basic need to do maintenance. go ahead and do normal maintenance on your boosted z if you think that's all you need. and when something goes wrong I promise it was more then just your oil change.
Old Mar 8, 2006 | 09:47 AM
  #43
chimmike's Avatar
chimmike
if you know so much, why are you letting him charge you like this ?
Nismo Fuel regurater US$270.00
If you knew so much, you'd know you can buy 2 nismo FPRs from almost anyone for like $210.
Just an example.
You changed your oil TWICE a MONTH??
  #44
RB26DETT-Z33
MIAPLAYA YOUR RIGHT LOW 500'S JUST WITH UPPING THE BOOST AND TUNING. THAT'S WHY iM THROWING CUSTOM CAMS FOR A LITTLE MORE THEN THAT.
Old Mar 8, 2006 | 09:56 AM
  #45
BoOsTedz33TT's Avatar
BoOsTedz33TT
Ive benn on stock internals for so long now, i think its a dream. Personally i think your kit was installed wrong, who did it, and are they doing your rebuild??
Old Mar 8, 2006 | 10:06 AM
  #46
sq40's Avatar
sq40
This is a Rich man's game isn't it..
Old Mar 8, 2006 | 10:26 AM
  #47
RA11325's Avatar
RA11325
Maybe you got a bad batch of 109 octane?
Old Mar 8, 2006 | 10:48 AM
  #48
bboypuertoroc's Avatar
bboypuertoroc
Whatever the case, good luck with the rebuild. I'll be going the T-netics route also (stage 1.5... when's it coming MIA?!) and eventually doing internals. Let us know how it goes.
P.S. That guy is RAPING YOU on those prices man! Shop around.
Old Mar 8, 2006 | 10:52 AM
  #49
JimRHIT's Avatar
JimRHIT
apparently he doesn't care about the pricing?
After all ... a cool japanese guy with an r32 is building it... so the prices are worth it
Old Mar 8, 2006 | 11:20 AM
  #50
Sam405's Avatar
Sam405
Ouchs thats alotta money.. hopefully their not the ones that installed the kit. GoodLuck man.. You should shop around for parts first.
Old Mar 8, 2006 | 11:53 AM
  #51
RB26DETT-Z33
Default Turbonetics And The Vq35de
They did not do the install it was kimo at mossy nissan.
Old Mar 8, 2006 | 12:13 PM
  #52
tekk's Avatar
tekk
can we see a complete list of the modifications on the car at the time of death?
Old Mar 8, 2006 | 12:27 PM
  #53
MI 35th's Avatar
MI 35th
OGPremierMafia
Miaplaya-
Bruce
wait and get the stage II with your built motor 550hp and tunable ems outta the box with return fuel system
Old Mar 8, 2006 | 01:18 PM
  #54
Gman2004's Avatar
Gman2004
Originally Posted by Zivman
Saying you won't have issues may not be realistic, but with a great tune you are less likely to have issues. Everyone has their thoughts on a reflash vs a custom tuned tunable EMS and I would think the consensus would be in favor of running a custom tune via tunable EMS over a somewhat generic reflash.
Even with an EMS and a the best tune it doesn't mean chit. I have the EU with all harnesses and bs needed to run the system safely. My car was tuned by one of the best VQ shops in the United States, SGP. The car was tuned in TX and it ran like a monster and felt like it came like that from Infiniti. When I got back to Miami the almost 40 degree increase in temps fuked up my tuned. No more POS piggy back engine managent systems for me......12 more days till I go HKS V-Pro!
Old Mar 8, 2006 | 01:23 PM
  #55
Gman2004's Avatar
Gman2004
Originally Posted by RB26DETT-Z33
Short Block assy 1 4595.73
Metal Head gasket 1 main Bearings 4
F-tune CP Forged piston kit 6
F-tune Calliro Connectingrods 6
ARP stud Head 1
ARP stud Main
Metal Head gasket 1 US$234.00
Highlift camshaft intake 66 1 US$832.00
Reimax Highlift camshaft exhaust 64 US$832.00
Nismo main Bearings 4 US$341.25
Nismo connectingrod bearings US$273.78
Nismo lowtemp thermo 1 US$132.30
Nismo Racing plug 6 US$317.52
Oil cooler 1 US$900.00
Genuine parts 1 US$500.00
Engine oil 1 US$50.00
Short parts 1 US$60.oo
bore & hone cylinder block with TP 1 US$578.00
dynamic balance crankshaft 1 US$135.00
polish journal 1 US$200.00
surface cylinder head and lap 1 US$160.00
Engine install 1 US$1,000.00
Dyno test & setting 1 US$1,000.00
Oil cooler install 1 US$600.00
engine overhaul 1 US$2,000.00
porting
These prices are kinda high. Check out SGP. They just recently built a 350z that has over 800whp.
http://store.yahoo.com/sgpracing-store/sgpravqmo.html
Basic short block: $3000 + $2200 core - Good up to 550 Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
Eagle rods
ARP Rod Studs
New Rod and Main bearings
Wiseco Pistons .020 over(8.5:1 or 11.5:1)
Upgraded Shortblock: $3900 + $2200 core - Good up to 650 Rwhp
Block redecked
Crank balanced
New Main and Rod bearings w/*ceramic coating
*Pauter Rods
ARP Rod Bolts
*CP Pistons .020 over(8.5:1 or 11.5:1)
Ultimate short block: $7800 + $2200 core - Good for 850+ Rwhp
Block redecked
Block Bored and Honed using a Torque Plate / Billet Dummy Head
Crank balanced
*Darton MID Sleeves
*COMETIC Metal head Gaskets
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
*Custom : SGP Racing / CP Pistons Up to 98mm(8.5:1 or 11.5:1)
*Ceramic coating on Piston skirts and tops
*ARP Main Studs
Basic Long Block: $4700 + $3500 core - Good up to 550 Rwhp
Block redecked
Crank balanced
Eagle rods
ARP Rod Studs
New bearing and rings
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
3 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Upgraded Long Block #1: $6900 + $3500 Core - Good up to 650 Rwhp
Block redecked
Crank balanced
Eagle rods
ARP Rod Bolts
Heads redecked
*JWT Upgraded Cams
*JWT HD Valve Springs
*5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Upgraded Long Block #2: $6700 + $3500 Core - Good up to 750 Rwhp
Block redecked
Crank balanced
*Pauter Rods
ARP Rod Bolts
*ARP Main Studs
*ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Upgraded Long Block #3: $8300 + $3500 Core - Good up to 750 Rwhp
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
*JWT Upgraded Cams
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Ultimate Long Block: $11,500 + $3500 Core - Good to 850+ Rwhp
Block redecked
Block Bored and Honed using a Torque Plate / Billet Head
Crank balanced
*Darton MID Sleeves
*COMETIC Metal Head gaskets
Pauter Rods
ARP Rod Bolts
* Custom SGP Racing / CP Pistons Up to 98mm Bore(8.5:1 or 11.5:1)
ARP Main Studs
ARP Head Studs
Heads redecked
*Tomei Upgraded Cams
*Ferrera 1mm Over Valve Train
5 angle valve job
Cold Clearance set
New Nissan Valve Seats
New Nissan Head gaskets / Big Bore COMETIC Metal Gaskets
New Nissan Oil Pump
Old Mar 8, 2006 | 03:10 PM
  #56
Zivman's Avatar
Zivman
Obviously a poor tune
Old Mar 8, 2006 | 03:55 PM
  #57
Gman2004's Avatar
Gman2004
Dude you're a dumb ****. Drive your car from MN and it's 43 degree wheather into Miami's 90 degree wheather and see how your beloved Unichip handles your current tune. ***NEWS FLASH*** Hotter temps make your car run rich *** face. We are not talking about a 10 degree increase in my case.....it's was a 49 degrees in Houston and it's 90 degrees in Miami. That''s why my car is running like chit. It is so rich at certain loads it bogs. The EU does not compensate for temp changes and neither does the Unchip. If SGP poorly tuned cars they wouldn't be a "GOD ALL MIGHTY" APS authorized shop. you're such a tool.
Old Mar 8, 2006 | 03:59 PM
  #58
Zivman's Avatar
Zivman
thanks for the kind words. You obviously had an improper tune.
Old Mar 8, 2006 | 04:01 PM
  #59
Gman2004's Avatar
Gman2004
Wow I guess you better go cry to Peter and tell them that SGP does not know how to tune car. They should remove SGP as an APS authorized dealer immediately. Also I guess APS doesn't know how to tune cars either. I have read about APS owners going lean with the out of the box tune in colder wheather......obviously a poor tune.
Old Mar 8, 2006 | 04:05 PM
  #60
Zivman's Avatar
Zivman
I didn't say SGP didn't know how to tune. what I am saying is, your tune was not adequate for your setup. You're tuner should have accounted for the difference in temps and tuned accordingly.
A proper custom tune is preferred to a somewhat generic reflash or out of box tune
