aps tt #'s
Old Mar 9, 2006 | 08:39 PM
georgec's Avatar
georgec
Originally Posted by Jason@MRC
After tuning.. I ran a 11.60 @ 120 with 10lbs of boost on drag radials.... and i still ran a 12.1 on my 19" street tires @120
Now your ET and MPH make a lot of sense to me Jason. You ran ran an 11.60@120 with 10 psi whereas the APS TT car I saw run at the strip ran an 11.20 something @ 127 MPH at 12 PSI. By the way when you you plan to run your Z again at the strip?
George
Old Mar 13, 2006 | 01:34 PM
FastTrackZ's Avatar
FastTrackZ
jason-what do you mean "when traction is available"? suspension and wider tires?...i definately still want street tires of some kind no dr's...thanks
Old Mar 13, 2006 | 01:36 PM
chimmike's Avatar
chimmike
you don't have the faintest clue, do you, of what kind of power that is when you're making almost double the power to the wheels that you did stock.
you're not going to get any traction in at least the first two gears with street tires, that's a fact.
Old Mar 13, 2006 | 02:12 PM
FastTrackZ's Avatar
FastTrackZ
o alright i didnt really understand that some drag radials are streetable, so i wouldnt mind using dr's then. what dr's do you recommend and what kind of suspension setup? i wanna be able to hook up off the line as well as possible. and i really dont have a clue; im just getting into all this, you have to learn sometime.
thanks
Old Mar 13, 2006 | 02:28 PM
JimRHIT's Avatar
JimRHIT
Mickey Thompson Street Radials mounted on 16" Weld Pro-Star XPs are your best bet .... next in line would be the same tires on a set of Pontiac Gram-Am/Prix wheels w/ some spacers
This is the best you'll do in a street radial, dot legal, street racing setup
if you want to lower the car ... invest the $250 in the SPC camber and toe kit. Set the camber to -1.0 or less and run ~0.05 of toe just to keep it comfy (I found 0.00 toe to be squirrely) ... you'll hook, I promise
good luck,
jim
Old Mar 14, 2006 | 06:40 AM
13THL's Avatar
13THL
Originally Posted by NOBI
I would look at the JWT too before you buy APS. I looked at them very hard but elected to spend my money on other things at the time. The major turn off being the fact that they are in Australia and the authroized dealers are not exactly everywhere if something should go wrong with the kit.
Just clicked that APS was in australia, lol.
And here i was thinkin it was a hella expensive kit (from US to AU conversion) and i had to get it shipped.
Old Mar 14, 2006 | 08:34 PM
georgec's Avatar
georgec
I'd recommend you have a good look for sure. That way you will see that the APS twin turbo system has the more complete fuel system, bigger GT series ball bearing turbos, larger air to air intercooler and a thoroughly engineered plug and play engine management system.
Old Mar 14, 2006 | 09:48 PM
NOBI's Avatar
NOBI
if i were you george i would totally go aps! =) (melbourne)
Old Mar 14, 2006 | 10:08 PM
ActionJackson's Avatar
ActionJackson
If you really don't have a clue, and really haven't experienced what 450-500 whp feelsl like, I'd stay off a TT kit altogether and get off the attitude of trying to race faster STIs and VWs. You don't sound mature enough to handle a TT'd car and seriously we don't need another dead person on these forums, nor do we need more dead innocent bystanders.
thanks
Old Mar 14, 2006 | 10:10 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
While I haven't driven my car on anything other than Drag Radials with the turbos..I got a chance to drive GRD's shop car that's making just over 500whp @ 11lbs of boost and is running a 285 BFG KDW tire on the back. in 80 degree weather the car got slight spin in first and hooked completely in second gear, so traction on street tires in a twin turbo Z is definitely attainable with the right setup.
Old Mar 14, 2006 | 10:19 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Alberto
I dont agree with you now. Ill use Briguymax as my example (and Im in no way downing him). He ran 13.6 basically stock, 13.3 with a few bolt-ons, would prolly have hit very low 13's or 12's NA if it wasnt for his axle mishap. Id consider him a good driver-more than I can say for most on these boards. He now has a 460rwhp APS TT car-with 430rwhp he cut a 1.7 60ft on slicks, and ran 11.7 @ 120mph. Very impressive indeed, but not mid to low 11's. Im not saying its nt possible for an APS T Tcar to run mid to low 11's on a stock block and 93 oct-just that I havent seen it, and it is very unlikely, like I said before if somebody pulled it off they are 99.5 percentile, do you disagree? If you do, you just $hit on 99% of the members of this forum...
My ears were ringing....
I'm not going to make any predictions about what I will run this spring with my current setup...but it should be a bit better than my old time, for more reasons than just power. My goal is to beat Jason@MRC to the 10s on a stock motor, pump gas, daily driven 350Z, but I'm going to need more than 460whp...
bcoffee20
Nov 19, 2015 06:39 PM
foxsmp26
Sep 25, 2015 09:48 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
ZZZ-35
Dec 30, 2004 05:56 PM
ZZZ-35
Australia/New Zealand
31
Aug 31, 2004 02:53 AM
