Boosting in 6th?
Old Mar 11, 2006 | 04:45 PM
Jason333's Avatar
Jason333
hi
Default Boosting in 6th?
When i first put my kit in, the car ran the same in every gear, after a tune/UTEC, if i boost in 6th it gets FATTT. By fat i mean 8 on the AF, and runs very On/Off for about 10-20 seconds until it leans back out. Is that normal? Sharif told me boosting in 6th wasn't a good diea, but it never acted up before. The reason it's an issue for me is i do a lot of interstate driving (300 miles a week), and i usually end up in boost passing cars.
Old Mar 11, 2006 | 04:47 PM
failsafe306's Avatar
failsafe306
No that's not normal.
Old Mar 11, 2006 | 07:20 PM
Ant830's Avatar
Ant830
I realized that too after I got my greddy TT installed. 6th gear feels sluggish for a bit and then leans out......but it used to just be lean and take off before the TT install.......is it really normal?
I didn't think it was....
Old Mar 12, 2006 | 06:06 AM
Jason333's Avatar
Jason333
hi
Mine was normal with the reflash from TN, now after the UTEC/Tune it just gets really really really fat after i boost. If i give thottle with it that fat, it doesnt respond like it should I have to press the throttle kinda far then it comes on all at once like a surge.
Old Mar 12, 2006 | 06:14 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Usually Ive noticed cars in 6th gear run slightly richer than say in 5th. You def should not beso lean and be dropping from the 11's A/F to the 8's. Id like for Sharif to chime in on why your car does that, and why you shouldnt boost in 6th Ive never heard that. I dont see anything wrong with that unless your realy lugging the motos at very low rpm's and putting load on it and trying to bost, in that case downshift a gear or two...
Old Mar 12, 2006 | 06:35 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
If you are familiar with tuning, this will make much more sense...as you boost in a higher gear, there is a greater load resisting the pull forward...this can shift the portion of the map that you are currently operating in...usually, even if you were in a lower line in the map, in a group of different cells, it wouldn't richen up that drastically...unless the cells are dramatically different compared to the cells that you drive in when boosting in the other gears...does it stay rich in 6th..or just early in the gear/late in the gear...or the entire time?
I never even boosted in 5th until I had a true dual 3" exhaust made...I was so paranoid during the melting piston era (it's like a timeline of vq35 evolutionary understanding)...Now, I can boost all the way through 5th gear, into 6th...another thing to be weary about when boosting in such a high gear- monitor your coolant temps (not with the factory gauge)- through an aftermarket, more sensitive coolant temp gauge, or through emanage ultimate..this will give you an idea how hot things are getting..heat is the enemy!
Old Mar 12, 2006 | 07:58 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
350zDKalb summed it up nicely. I didnt tell Jason that he shouldnt boost in 6th gear. I advised him not to boost in very low RPM in 6th. Flooring the accerator in 6th gear at 2500rpm, for instance, puts a tremendous amount of load on the engine, and you will generate a lot of cylinder pressure at very low RPM. This is not good for the health of an engine.
If we had one more day to tune with the car, I could have worked out the 6th gear WOT richness, but it really is something that everyone should avoid. Lugging the engine with high load and boost at low RPM is a dangerous practice. I would prefer that the customer downshift into 5th gear when passing, to put the engine above 3000rpm or so.
Are you planning to attend ZDAYZ;s. I would be happy to adjust it for you, since I know you live about 10 hours from Charlotte.
Old Mar 12, 2006 | 08:15 AM
Jason333's Avatar
Jason333
hi
I'm going to try to get up there man. It's just a crazy tome for us. BTW got the door piece in and it popped right on..thnx bud
Old Mar 12, 2006 | 08:24 AM
Sharif@Forged
Forged Performance
Noice! I wish you lived closer to us..for the follow up treatments.
Old Mar 12, 2006 | 08:55 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
sharif, you got my name wrong again, you are starting to hurt my feelings
350z----D C----alb
350z= self explanatory
DC=doctor of chiropractic
alb=albuquerque
Old Mar 12, 2006 | 10:58 AM
failsafe306
350z----D C----alb
alb=albuquerque
For the longest time after I first joined, I thought your name was Caleb
Old Mar 12, 2006 | 12:26 PM
ChunKy350Z's Avatar
ChunKy350Z
lol @ failsasfe306
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
