Fuel Regulator question
Old Mar 11, 2006 | 05:55 PM
bverschage's Avatar
bverschage
Default Fuel Regulator question
I have a question about Fuel Regulators; I just put the AAM Fuel Return system on my car with the Turbonetics Turbo setup. The car will run fine for a while then the car will die, and when I restart the car my Fuel presser gauge is at 4 bars. When I turn the key off and on a few times it goes back to normal for a little while and then does it again. Is the Fuel Regulator bad? Is there a way to check?
Old Mar 11, 2006 | 08:26 PM
overZealous1's Avatar
overZealous1
the regulator is bad or you could have plumbed it incorrectly. meaning, wrong direction of flow through it. what pressure do you have it set for? possible restriction or pinching in the return line?
Old Mar 11, 2006 | 08:53 PM
bverschage's Avatar
bverschage
I have it set for 2.9, we check all the lines and they seem to be good. we also checked the fuel filter, and pulled a bunch of stuff out of the filter bag. I don't think that it was plumbed wrong as it was installed at SGP when they built the motor. With the regulator set at 2.9 should it hold at 2.9 or fluctuate up and down? Is there a way to check the regulator?
Old Mar 11, 2006 | 08:58 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Which fuel pressure regulator is currently installed? Is it a red aeromotive unit, or a silver looking reg.
At idle, the pressure should be pretty steady and consistent. You might noticed some small changes in pressure, due to temp, or electrical voltage on your system....both of which can change slightly.
Old Mar 11, 2006 | 09:01 PM
bverschage's Avatar
bverschage
I have the red aeromotive. If the regulator is bad, can it cause the car to shut off due to too fuel in the system?
Old Mar 11, 2006 | 09:19 PM
Sharif@Forged
Forged Performance
4 bar is nearly 60psi. That would not be enough to shut the car down while cruising, but might be enough to stall it at idle..but honestly...probably not.
We have tuned some cars at 58psi of differential fuel pressure, and they idle just fine. In fact, the APS TT kit runs 58psi of differential fuel pressure.
Old Mar 11, 2006 | 09:27 PM
bverschage's Avatar
bverschage
the car runs fine crusing, it is when i put in the clutch that it stalls. the rest of the time it runs between 2.7 and 2.8. does this sound like a bad regulator?
Old Mar 11, 2006 | 09:34 PM
Sharif@Forged
Forged Performance
No it doesnt. What size injectors are you running?
Do you have a fuel pressure gauge inside the cabin, so you can observe?
What RPM does your engine idle at?
Old Mar 11, 2006 | 09:41 PM
bverschage's Avatar
bverschage
750cc
Old Mar 12, 2006 | 07:38 AM
bverschage's Avatar
bverschage
any other thoughts?
Old Mar 12, 2006 | 07:48 AM
Sharif@Forged
Forged Performance
Originally Posted by bverschage
750cc
750cc injectors can give people some stalling and idle problems. Have you had your idle increased? We usually run the larger injectors with 900-1000rpm idles, and they idle just fine.
Old Mar 12, 2006 | 08:09 AM
bverschage's Avatar
bverschage
the idle was set at 1000 rpm, and seems to run fine. the only time that the idle changes is if you rev the motor, then the idle drops down to 600rpm for a second then comes back.
what i don't understand is that the car runs fine, till you put in the clutch to stop then the car stalls. the car does not studer or shack it just shuts off.
Old Mar 12, 2006 | 09:27 AM
Sharif@Forged
Forged Performance
Was a throttle body reset done on this ECU?
Old Mar 12, 2006 | 09:31 AM
bverschage's Avatar
bverschage
No, but the throttle body has had work done to it, and I am running the e-manage ultimate.
Old Mar 12, 2006 | 09:46 AM
bverschage's Avatar
bverschage
I am also running step 6 plugs, would it help if i ran 7's?
Old Mar 12, 2006 | 12:13 PM
Sharif@Forged
Forged Performance
The plugs wont help you.
Try doing the full array of ECU reset procedures, and see if that fixes the issue.
I would also double check your engine for vaccum leaks. What is your vaccum at idle on your boost gauge?
Old Mar 12, 2006 | 12:28 PM
overZealous1
what has been done to the throttle body? is there a rise in fuel pressure when the clutch is pushed in? it should drop a little pressure at idle/high vacuum. sounds like it is an issue with the throttle body. has it always done this? how was the idle raised?
Old Mar 12, 2006 | 12:41 PM
dynamic6er's Avatar
dynamic6er
What kind of clutch is it?
Old Mar 12, 2006 | 05:31 PM
bverschage's Avatar
bverschage
Not sure what was done to the throtle body, as that was done at SGP. When at idle the boost is at 0.6, but now whenever I start the car the fuel pressure goes to 4 and stays there.
the clutch that I am running is the RPS Max Street
I think that the idle was changed through the E-manage
Old Mar 12, 2006 | 07:43 PM
overZealous1
you got some weird stuff going on man, lol. idle can't be upped on the emanage. the fuel pressure should go up and down with the boost/vacuum. you must have a couple other symptoms that are related. just need more and exact symptoms to help further.
so it was running correctly before though, right? any check engine codes?
