Headlift -- sleeved and non-sleeved engines
Originally Posted by Yancy
I always run Sunoco 94 or higher gas. What is the safest thing to do at this point - sleeve if there is still time to do it or not sleeve? Is the headlift issue more likely to occur on a 600 hp sleeved engine or a 600 hp nonsleeved engine? Is this something unique to our engines, because I know guys that have turbo mustangs and crazy Cobras with after market SC that don't have this issue. Thanks in advance.
http://www.theexperience.com/engine.htm
Everyone was a great help right away and I was able to add the sleeves to my package before the block was sent to be machined. It's getting sleeved in Texas by a shop that has a CNC machine and has done at least 4 other sleeve jobs on the VQ. Thanks to Gman, Shariff and everyone else.
Originally Posted by mjedens
Who can tell me a fool proof (I'm the fool) way of knowing this is happening?
Originally Posted by Sharif@Forged
The first signs are air in your cooling system, no heat in the cabin, and an overflowing coolant resevoir, followed by engine overheating.
By the way, I understand Gurgen just graduated and is moving back to So Calif.
Thanks Sharif for clarifining those symtoms... I'm glad to hear that Yancy was able to hook it up..
Cheers Amy
Could the boiling over of the coolant just be that the cooling system is not adequate enough? I haven't had any coolant spew out of my overflow tank, but it has been filled up after hard runs. This only happens on repeated abuse at 16psi. When I repeatedly beat on the car at 16psi not only does the overflow tank fill, but my water temp goes up to 230 degrees.
Today it was kinda of hot and at 10psi the water temp went up to 230 degrees. I haven't heard of anyone experiencing "head lift" @ 10 psi which is why it has me thinking could it just be that our cooling system is not adequate enough. If we had a cooling system that could hold more volume would it take care of this?
Originally Posted by failsafe306
It couldn't hurt. Supposedly, someone is working on a new setup that would almost double the capacity of our stock cooling systems, and would involve a custom radiator.
Today it was kinda of hot and at 10psi the water temp went up to 230 degrees.. I haven't heard of anyone experiencing "head lift" 10 psi which is why it has me thinking could it just be that our cooling system is not adequate enough. If we had a cooling system that could hold more volume would it take care of this?
I can't remember for sure, but don't you have a PE upgraded radiator and thermostat? You raise a good question - what else other than an upgraded radiator and maybe water wetter can we do to keep a high FI Z cool?
Hey Gman,
I have the PE radiator, nismo thermostat, and greddy breather tank. After seeing my water temps go up today at only 10 psi it made me think if this "head lift" issue isn't really just an inadequate cooling system issue.
well for me there is no question. mine is getting so bad now i can get on it and watch the fluid hit my windshield, hahaha. i have 2 cars now to finish before i have room in my shop for mine. i can't wait to see what the head gasket looks like.
WAIT A MINUTE. just had a light bulb go off over my head!!!! now this is a slight stretch, but worth saying in the open. now, the cooling passages around the cylinder and head are kind small. what are the chances that the water around the cylinders goes into a near instant boil during hard throttle and that is the reason for puking out fluid. hopefully that is not the outcome, as that will be nearly impossible to rectify.
Maybe not with a sleeved motor with revised coolant passages and a different material around the combustion chamber. Maybe???
what fans are you running? Believe it or not, these can play a big part as well. a pair of high cfm fans can make a big difference.
Seems to me that using 1/2" head studs would do a better job at preventing this than sleeving the block.
I mean, my mother's 03 Altima has the same symptoms, air in the cooling system, thus making the heat work improperly and such. I'm not going to assume it's head lift, it was just a radiator cap that the Nissan dealership claimed was a POS.
I can't wait till Scott rips apart that block so we can try to determine the real cause of headlift. To me it seems like it's something wrong with the coolant system. If its not I'd look to more clamping force using larger head studs.
