Headlift -- sleeved and non-sleeved engines
Old Feb 27, 2008 | 09:46 PM
  #181
G35cTT's Avatar
G35cTT
Originally Posted by Philthy
I'm not sure if it was mentioned already, but you may also want to try jacking the front of the car up - it'll speed up the process!
How much faster if you jack up the front end?
Old Feb 28, 2008 | 11:50 AM
  #182
G35cTT's Avatar
G35cTT
Got another question, after purging my car sat there and sucked up all the coolant from the overflow. Would I have to purge again if air got sucked back in the radiator? Or good to go w/ just one purging?
Old Feb 28, 2008 | 12:25 PM
  #183
06Track's Avatar
06Track
Yes if it took all your overflow..as when that was empty it would
have sucked in some air. Probably not much, but it doesn't take
much air to screw up the flow.
Old Feb 28, 2008 | 07:58 PM
  #184
G35cTT's Avatar
G35cTT
Had to purge again but this time I put extra coolant in the overflow in case it sucks it back again. The only problem with this new funnel is the cap that goes on the radiator doesn't have a gasket so I had alot of coolant/water leaking from the cap, which is probably why I had to add so much since it was leaking out alot off the top. Did the same happen to you Sharif? Probaly have to put some sort of gasket to make it a spill free funnel kit. In any case this info was very useful. thanks!
Old Mar 8, 2008 | 05:03 PM
  #185
94ttz32's Avatar
94ttz32
Ok I read the whole thread and wondering if anyone had a final fix to the headlift issue? SOrry for the old bump to the top
Old Mar 9, 2008 | 12:18 AM
  #186
accordfreak's Avatar
accordfreak
talk to thawk408
https://my350z.com/forum/forced-induction/336752-what-about-just-upgading-the-rods-and-pistons-3.html
Old Mar 9, 2008 | 09:43 AM
  #187
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Weird...I have never had leaks at all. Do you push the funnel down firmly?
Several people on the forums use these type of funnels, so maybe they can comment if they made any mods to their spill funnel.
My spill funnel makes 27whp without tuning..BTW.
Old Mar 10, 2008 | 10:05 AM
  #188
G35cTT's Avatar
G35cTT
I think it's because the cap that goes on the radiator doesn't have a gasket on mine. Does anyone elses leak off the cap like mine, just seeing what others did if so. I just got a rubber washer to try to make a tight seal so going to try again later today.
Old May 11, 2008 | 06:06 PM
  #189
G35cTT's Avatar
G35cTT
Finally no more over heating issues since there hasn't been any post people must of solved their problems as well. I got the coolant bypass mod, upgraded PWR radiator, GTM Fan upgrade, and Nismo thermostat. No more coolant squirting out the overflow and no heat issues when I get it. Allows me to run Lo and Hi boost no problem. Just wanted to say thanks for the advice of many members here.
Old May 11, 2008 | 06:08 PM
  #190
G35cTT's Avatar
G35cTT
And the reason why my non spill funnel was spilling is because the pressure from my overflow was pushing coolant off the top, so the non spill funnel works proper now.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
