Quirky bump in Dyno Sheet...
Old Mar 20, 2006 | 04:58 PM
JoeDirtPharmD's Avatar
JoeDirtPharmD
Default Quirky bump in Dyno Sheet...
NOPI judges are retarded, I'll just get that out of the way right now...
Anyways, they had a mobile dyno there, decided to let them pull the car a couple times. Peak result ended up being 421hp/505tq.
Now oddly, when the car was tuned about 3 weeks ago, the tuner stated that the car was apparently pulling some timing around 5k rpm for reasons unknown. After doing whatever tuners do, he managed to smooth out the curves, and we left it at that. When I got the Dyno sheets back from yesterday's NOPI event, there's an odd dip reflected in both the HP and TQ curves (on a second printout where the numbers are listed in 100-rpm increments, the loss occurs between 5,000 and 5,100 rpms).
I haven't noticed any driveability concerns - still running 91 pump gas. Boost is continuous (peaks at 12, tapers to 7.5 at redline, no observable hiccups). Any ideas? Should I be concerned?
Pulled in 4th, 4th and 5th gear(s)
Old Mar 20, 2006 | 05:04 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
what type of engine management?
Old Mar 20, 2006 | 05:07 PM
JoeDirtPharmD
UniChip (came with APS ST setup)
EDIT: Interesting to see the differences in Dynos.
Dyno1: Dyno Dynamics (load based): 401hp/435tq
Dyno2: DynoJet #1: 436hp/446tq
Dyno3: DynoJet #2: 421hp/505tq
Given no remarkable change in gas quality, temperature, humidity, elevation, etc., its interesting to see the differences between different dynos. Or, maybe the car is out of whack?
Old Mar 20, 2006 | 05:22 PM
taurran's Avatar
taurran
I've been told that dip is due to the Variable Valve Timing Control system on these cars.
Old Mar 20, 2006 | 05:47 PM
tig488's Avatar
tig488
damn nice numbers, you gained 60fttq?
thats tapering down to 7.5 still? i thought that was fixed? hows the ticking thing going?
Old Mar 20, 2006 | 05:57 PM
Julian@MRC's Avatar
Julian@MRC
You have been told wrong my friend...That dip you see is one of two things, a rich spot in the Fuel table, or the ECU picking up knock and pulling some timing....I can not make out the A/F chart, what is your A/F ratio at the dip?
Old Mar 20, 2006 | 06:04 PM
JoeDirtPharmD
Sadly - tapering issue still exists for reasons unknown... not too worried about that.
The AFR reads at 11.6 at 5100 rpms.
So... likely some knock? Highest octane avail around here is 91 There's a spot about 40mi. away that sells 100. Gonna hafta' start making a home brew of Xylene and MMO... lol
Old Mar 20, 2006 | 06:10 PM
tig488's Avatar
tig488
joe you got PM
Old Mar 20, 2006 | 06:24 PM
Julian@MRC's Avatar
Julian@MRC
What is your timing at that dip?Try pulling a bit more timing, or adding a bit more fuel.Keep in mind the dip is in the peak TQ range..So Im gonna say its some knock..
Old Mar 20, 2006 | 07:10 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
That's a pretty wave line...especially for a dyno jet. I agree, somethings is up with the timing. 91 octane is a bear to tune with, and my guess is that you have a knock feedback related issue. Stock ECU detects knock (you might not even hear it), and it starts vascilating the timing downward. The UNICHIP is pretty poor at controlling timing, since it doesnt read or act on the stock knock sensor, nor does it allow you to actually "Set" the timing.
I'd put a UTEC on this car, and your control over the engine will improve 10 fold.
To determine if its knock, the easiest thing to do, is to fill up with 100octane+ fuel, and hit the rollers again.
Old Mar 20, 2006 | 07:20 PM
JoeDirtPharmD
My concern with the UTEC is that I don't know of anyone in the PHX area that I would trust to tune it. The shop that tweaks the UniChip, I don't believe, has any experience, or limited experience with UTEC. I could take it somewhere to CA as we discussed before...
I'm going to hold off on mgm't upgrades until I determine the ticking concern. If it comes to be that I'm on board with a new engine, then I'll def. consider an alternative management. In the meantime, I'll load up on 100+ and run the car again.
Old Mar 20, 2006 | 07:31 PM
Julian@MRC's Avatar
Julian@MRC
I would most likely want to know why my motor was "ticking" before I put it back on the dyno...
Old Mar 20, 2006 | 07:39 PM
JoeDirtPharmD
Agreed
Pulley came today - install tomorrow
Old Mar 20, 2006 | 07:40 PM
plumpzz's Avatar
plumpzz
Add some ethanol :-D Ethanol (pure) is 118 octane i think. or 108... anyway, like said earlier, i'd find out why my engine is ticking before i find out why its not making power..maybe its hanging on a string? or a rod..
Old Mar 21, 2006 | 02:08 PM
dynamic6er's Avatar
dynamic6er
That looks like some misfiring. With the smoothing at 3 is should not jump around like that. What plugs? What gap? Is your motor built?
Old Mar 21, 2006 | 05:22 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
does intense have a dyno or tune? there in phoenix
Old Mar 21, 2006 | 05:26 PM
JoeDirtPharmD
They did, but they recently moved, and are now closed to the public. AZDynoChip has a DynoJet - going there Friday morning to see if its an octane-related issue.
Motor is stock, plugs are NGK one-step-colder plugs and gapped at whatever the instructions were per APS install (0.035? I think...?)
Now that the ticking is gone and it purrs, going to load up on some 100 and run it on a DynoJet again, hoping to see if I have a different outcome. If it resolves the quirk, then I know I simply need to find a local source for octane > 91, or turn down the boost a bit...
Old Mar 21, 2006 | 05:33 PM
tig488's Avatar
tig488
are you running the 91 map?
Old Mar 21, 2006 | 05:47 PM
sentry65's Avatar
sentry65
the burninator
hey keith at AZDynoChip is a cool guy, but when I went there 3x, he had me actually drive on the dyno - not sure why, but that's his way. It seemed to run about 10whp lower than at intense motorsports dynojet.
Old Mar 21, 2006 | 05:55 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Subscribing.. Let us know what happens.
