Water Temp Gauge
Old Mar 23, 2006 | 04:01 PM
G3.5T's Avatar
G3.5T
Default Water Temp Gauge
Where is the bestplace to tap for a mechanical water temp gauge? The probe seems rather large and I am wondering if one of the coolant hoses is the best place to tap into?
Old Mar 23, 2006 | 05:01 PM
G3.5T's Avatar
G3.5T
Anyone have pics of their set-up?
Old Mar 23, 2006 | 06:15 PM
EnthuZ's Avatar
EnthuZ
Most manufacturers & racers install the temp gauge thermocouple JUST below the thermostat. But don't ask me where an easy place around that area is on our VQ's. If you find an answer, I'd be very thankful, as the OEM gauge is way over dampened.
Old Mar 24, 2006 | 02:54 AM
G3.5T's Avatar
G3.5T
Does it need to go near the thermostat? I thought it could go on any coolant hose. I was thinking of the coolant hose on top of the engine that goes to the throttle body. Is this a bad placeto put it?
Old Mar 24, 2006 | 02:58 AM
Mike Wazowski's Avatar
Mike Wazowski
I sure wouldn't tap into the hose itself.
Old Mar 24, 2006 | 03:08 AM
G3.5T's Avatar
G3.5T
No, I was thinking of cutting the hose and using a "T" fitting.
Old Mar 24, 2006 | 04:03 AM
jpc350z's Avatar
jpc350z
I have an electrical gauge installed on the A pillar that is fed by a temp probe that is installed in the engine outlet to radiator inlet hose..You want to measure the temp coming out of the engine if you want to use it as an engine health/status measurement...Had to use a special mount/fitting made by Greddy I believe to mount the probe into the line...
Old Mar 24, 2006 | 04:11 AM
G3.5T's Avatar
G3.5T
Do you have pics? I have a mechanical gauge and the probe nut is 1/2". Where on the motor is the outlet hose?
MoodDude's Avatar
MoodDude
I would first look at your radiator before cutting the hose. The temperature difference between the radiator and the thermastat should be negliable. Not sure if a tapped hole already exists. If it doesn't than look at the hose option.
Old Mar 24, 2006 | 04:43 AM
jpc350z's Avatar
jpc350z
Sorry no pics.. The inlet to radiator (about 2 in hose) is on the passenger side and it goes into the top of the radiator..You cant miss it..
Old Mar 24, 2006 | 04:32 PM
MIAPLAYA's Avatar
MIAPLAYA
Blitz makes a return coolant hose with a bung already there for a water temp sensor. Thats where mine is...
Old Mar 24, 2006 | 04:52 PM
eat rice z33's Avatar
eat rice z33
hey bud, you can buy the hardware fitting for the upper radiator hose. at www.splparts.com click fairlady z then hardware then fittings! ENjoy
Old Mar 24, 2006 | 04:58 PM
G352NV's Avatar
G352NV
Thanks for the link!!!!
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
