Rod bearings after 20K miles of FI torture. :)
Old Mar 26, 2006 | 02:53 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by booger
Your track must not have a 12 sec rule.....any thing under 12 sec...you need a roll cage
They tend to be a little bit lax at Rockingham Dragway. Plus, it took me about 8 passes to just get into the 11's, so my series of mediocre low 12's probably lulled them into complacency.
Old Mar 26, 2006 | 03:00 PM
Sharif@Forged
Forged Performance
Come to think of it, I think Rockingham requires a cage for sub 11's, but maybe someone can let me know. Either way, there were lots of cars in the 11's, and none of them had cages. So either they were not inforcing it, or the rule does not apply at the open track events. That would be some information to have though.
Old Mar 26, 2006 | 03:14 PM
Royal_T's Avatar
Royal_T
that's great to here that every thing is in top shape after 20k miles.
so sharif will you be selling this meth kit on your website once you'll get it put together?
keep up the great work, can't wait to see what you have up your sleeves
Old Mar 26, 2006 | 03:16 PM
palmerwmd's Avatar
palmerwmd
So these are stock bearings?
Mobil1 in 15w-50 (only) has a HTHS of 5.1 centpoise if memory serves.
That will go a long way to help protect bearings.
Those of you using 30 weight oils are on your own.
even the best syn 30 weight,s are only in the low 3's for HTHS.
Mobil1 often at the lower end of thisd scale, since their syn 30 weights ( 0w-30,5w-30 and 10w-30) are among the lowest in this regard as they run the thin side of 30 weight (which makes OEM approvals easier, as it helps corporate fleet mpg but makes it harder to get good hitemp/highshear values)
Even in my relatively mild SC set-up, I run Redline 10w-40 (HTHS in the 4's I believe) and for hi summer will likely go M1 15w-50.
This may be a stupid question , still wondering if those bearings are bone stock?
Fred..
Old Mar 26, 2006 | 03:18 PM
trefling's Avatar
trefling
Can't wait to see what #'s you'll get when your project is finished.
Old Mar 26, 2006 | 03:53 PM
Sharif@Forged
Forged Performance
Yes we will.
Yes, they are OEM Nissan bearings, without any coatings on them.
Thanks man..seeya soon!
Old Mar 26, 2006 | 04:34 PM
trefling's Avatar
trefling
Damn......I must say I'm totally envious of what you are doing. What kind of #'s are you shooting for? I know your keeping wraps on everything but I'm sure you can give all us poor low HP/TQ guys a preview
Old Mar 26, 2006 | 04:38 PM
Sharif@Forged
Forged Performance
Once my heads, and turbo upgrade arrive, I'll post plenty of pics, and more details of what I am doing.
Old Mar 26, 2006 | 06:36 PM
mojo powered's Avatar
mojo powered
Sharif, can't wait to see your new upgrades
also, according to the new rules, the cage requirement is for below 11.5 in the quarter so if you run 11.5 or slower, you're ok.. 11.49 and no cage, you're kicked out.
Old Mar 26, 2006 | 06:49 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow, very impressive Sharif 25 passes down the 1/4 I didnt know you ran so much. What was your best e.t. and with how much power?
Old Mar 26, 2006 | 07:37 PM
XBS's Avatar
XBS
Veteran
How high were you revving the motor Sharif?
-George
Old Mar 26, 2006 | 07:49 PM
mraturbo's Avatar
mraturbo
Nice Work Sharif...
M
Old Mar 26, 2006 | 07:53 PM
bigbri's Avatar
bigbri
What up man.....the **** still looks good.... I'm calling you tommorow...
Old Mar 26, 2006 | 08:02 PM
002-M-P's Avatar
002-M-P
Sharif, looking good brother. Can't wait to see the new beast when your done with it (maybe i'll get the money together sometime this summer to do my motor).
As for Rockingham Dragway, I can vouch for their slackness in rules. You're suppose to wear a helmet for 13.99 or less runs. I ran about 6 passes in the mid 12s and noone said anything to me.
Old Mar 26, 2006 | 08:04 PM
nissansource's Avatar
nissansource
Those suckers look primoo
Old Mar 26, 2006 | 09:37 PM
overZealous1's Avatar
overZealous1
it is always a good thing when you don't see bronze on one side of the bearing, lol.
Old Mar 27, 2006 | 09:20 AM
Sharif@Forged
Forged Performance
I assume this means a 4 point rollbar style cage? Or is the full 6-8 point cage required. Any good 4 points that you know of?
I am admittedly a pretty bad drag racer, and the best I mustered was a 2.0 60ft and 11.5@127mph, with roughly 600whp at the wheels.
Most definately a good thing, Scott.
Obadabot
Jun 18, 2023 11:31 PM
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
