copper o-ringed head gaskets
Old Mar 28, 2006 | 08:05 AM
overZealous1's Avatar
overZealous1
Default copper o-ringed head gaskets
well the programming is almost done for making the copper head gaskets. they will also come with stainless steel o-rings to further aid in cylinder sealing.
copper is used because of it's ability to conform to microscopic imperfections in the block and head surfaces. the gaskets are first enealed to aid in softening them to comform to these imperfections. this style of gasket is used in many race motors for it's ability to seal.
the o-ring is just that, a ring that gets sandwiched between the cylinder and the gasket to create a very high pressure seal. there needs to be a groove put around the top of the cylinder to accept the o-ring, but that task is very easy for most any good machine shop to do. these can be used with sleeves also and would be very highly recommended for any high hp effort.
different thicknesses can be offered also. cost is still up in the air abit, but it will very comparable to other aftermarket gaskets.
the current multi-layer ss gaskets are very nice, but the stainless cannot adapt to surface imperfections as effectively. plus if any piece of dirt or anything gets trapped between the layers upon assembly, sealing abilities will be seriously compromised.
my car is so bad now i can't boost past about 8-10psi before i leave a trail of water running down my fender from puking it out the overflow. the first set of these will be going into my own motor.
Old Mar 28, 2006 | 10:14 AM
Nismo350ZRT's Avatar
Nismo350ZRT
Great work OZ. I wonder if this is what Sharif is working on too...
Old Mar 28, 2006 | 01:37 PM
overZealous1
not sure, but i have been meaning to do it for a couple months now. my own car is at the point i need them now though, lol.
Old Mar 28, 2006 | 02:51 PM
failsafe306's Avatar
failsafe306
What whp are you at now Scott?
Also, are you going to be using 1/2 inch head studs this time around?
Old Mar 28, 2006 | 03:46 PM
overZealous1
going to look and see the best route to take for doing 1/2" studs now. the trick is going to see if i can find studs for another motor than can be adapted to the vq. i have a blown block now i can mess around with.
Old Mar 28, 2006 | 05:51 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
sounds good guys..with a stronger clamping force, in addition to a stronger headgasket, the cylinder head lift issue will be a thing of the past!
Old Mar 28, 2006 | 06:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Scott, you're going to want to explore some better stud options for your engine. A copper or even a Cometic MLS headgasket isnt going to help, if the clamping force isnt there to keep the heads on the block. It's also important that your block and head mating surfaces are machined as smooth as possible. After seeing a lot of different engines...including mine, and talking to other shops, I am convinced that headlift, due to insufficient clamping force between the block and head, is the true problem, rather than cylinder wall distortion, or head gasket failure, per se.
Old Mar 28, 2006 | 06:47 PM
G352NV's Avatar
G352NV
From what Ive been told hes addressing that. He picked up my heads and blown block a couple days ago.
Old Mar 28, 2006 | 07:17 PM
Juztin's Avatar
Juztin
nizmo1180 comes to mind with their vq35 block w/ 1/2" head studs already pre-done with the exception of a head that can accept 1/2" arp studs.. least that's a start but i'd be nice for some engine builders to offer a 1/2" head stud long block route in diff stages
Old Mar 28, 2006 | 07:18 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
stay tuned...dun dun dun
Old Mar 28, 2006 | 07:31 PM
overZealous1
ya thats what i had come to the conclusion also. another is the multi-layer gaskets (if not handled properly) can trap things in between the layers before assembly and create improper sealing. so a single layer will eliminate this question by making it easy to clean and inspect. the o-ring will provide superior sealing, but it will all go to heck if the studs are stretching, lol.
the trick is finding an already produced stud that can be adapted to the vq to keep costs down.
did you see any indications of the top of the bore moving? like the black material gone where it seals? i am afraid on mine that the first couple times mine let pressure through, some of this material got trapped in the gasket hurting the seal even worse. could be the carbon black stuff some are seeing in their overflow tank.
Old Mar 29, 2006 | 09:09 AM
Sharif@Forged
Forged Performance
There were a few smudges, but its very possible those were the areas where the combustion gases leaked into the cooling channels.
There is one unname person with a Darton sleeved block, and standard 7/16th ARP studs trqed to 65ft/lbs, that has head lift issues as well, albeit at VERY high whp levels. More clamping force is the key.
Cometic recommends an RA of 50 of less, but I'd look to surface the block and heads to a minimum RA of 25. Smoother the better.
One last thing in regads to copper gaskets, and then I will shut up. Unless the technology has changed in the past 6 months, you MUST retrq the studs....no question about it. Copper is very soft, and with one or two heat cycles, you have to retrq, or headgasket failure will be imminent.
Old Mar 29, 2006 | 09:25 AM
Juztin's Avatar
Juztin
since u mentioned the retorque - from what nizmo1180 mentioned regarding their 1/2" studs - to be retorqued the valvetrain does not have to come out. Which is pretty interesting - i'd like to see a picture of the 1/2" studs w/ the valvetrain all in place to get an idea of why they're different enough to warrant not doing that kinda nightmare of a job that needed to retorq the 7/16th studs. In a way it kinda seems like the cost payed for going 1/2" can possibly be recooped when it comes time to retorque
Old Mar 29, 2006 | 09:34 AM
overZealous1
ya i have found some copper head gasket manufacturers that say no retorqueing is needed with their head gaskets. investigating the quality of copper they are using to help prevent the need for retorqueing.
luckily once the program is finished, any material could be cut on the machine.
Sharif@Forged
Forged Performance
Retrqing with MLS gaskets is not needed. Myself, and other's have confirmed that the ARP heads studs were all tight, when breaking down the engine.
Old Mar 29, 2006 | 12:56 PM
t32gzz's Avatar
t32gzz
Sharif, what signs are you seeing that the studs may be the issue. Did you see evidence of stretched studs?
Old Mar 29, 2006 | 02:35 PM
overZealous1
in a conversation with performance, they tested to 900hp on an engine dyno with sleeves, 1/2" studs, and stock head gasket, and kept blowing the radiator cap off!!!! that was the stop of development on their street motor from what the guy said.
so this head lift issue is going to be a serious hurtle to over come. too bad nissan made the block so short and didn't put more bolts to hold the heads down.
Old Mar 29, 2006 | 02:59 PM
failsafe306
Would cryo-treating the 7/16 studs before assembly be of any benifit?
Old Mar 29, 2006 | 03:11 PM
Nismo350ZRT
This headlifting problem is really putting a damper on my desire for a built block and 600+ whp.
Old Mar 29, 2006 | 03:51 PM
mjedens's Avatar
mjedens
I'll blow out a gallon of coolant (distilled water plus additive) at 21 lbs of boost! It wasn't doing it at 17 lbs last week but I'm thinking it will probably go that direction!
