UTEC with APS?
Old Mar 28, 2006 | 09:19 AM
dirtroad's Avatar
dirtroad
Default UTEC with APS?
I'm considering the UTEC just so I can store different maps and I'll also be able to have it tuned locally. I've got the APS single turbo...
1. Can the unichip and UTEC work together? Or would I have to completely remove the unichip to use the UTEC?
2. Also, would a boost controller be required if I had to remove the unichip?
3. Is there a way to store different maps using the unichip?
Old Mar 28, 2006 | 09:26 AM
westpak's Avatar
westpak
SFZCC
1. No, yes to remove unichip
2. Yes
3. Yes you need the remote switch
Old Mar 28, 2006 | 09:34 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
You wouldnt have to get a boost controller, just a solenoid ($20). The UTEC can control boost via the solenoid.
Old Mar 28, 2006 | 10:00 AM
Gman2004's Avatar
Gman2004
technically he wouldn't have to buy anything. I could have sworn I read a post about MRC taking the solenoid out of the unichip and using it with the UTEC.
Old Mar 28, 2006 | 10:09 AM
Nismo350ZRT's Avatar
Nismo350ZRT
I remember reading the same thing.
Old Mar 28, 2006 | 06:09 PM
NETSHARK's Avatar
NETSHARK
APS ST kit comes with 000-094-500 SOLENOID - WASTEGATE CONTROL and 435-083-200 LOOM - SOLENOID, all you have to get is UTEC and UTEC remote switch it will let you save 5 maps, and all you have to do is to tune it properly
Old Mar 28, 2006 | 06:49 PM
Julian@MRC's Avatar
Julian@MRC
Kind of never got it working properly..The Unichip Selonoid is a big ol' POS IMO..
Old Mar 28, 2006 | 07:19 PM
narkotic's Avatar
narkotic
I've never had any problems with it... it's more of an OEM type I believe made by Bosch (if you look at it, the original manufacturer information is ground down.)
Old Mar 29, 2006 | 10:42 AM
KPierson's Avatar
KPierson
I'm in the process of doing the same thing.
I'm planning on getting a boost controller and scrapping the APS solenoid (which means I have to spend more money, not happy about that!)
Also, it sucks that I can't connect my existing AEM wideband to the Utec. I will be looking for a logging solution so I can at least log my A/F and compare it to my Utec logs. Buying the Utec tuner is out of the question, since I've already spent $400 on the AEM.
Old Mar 29, 2006 | 07:22 PM
Bullitproof's Avatar
Bullitproof
actually the utec has 7 maps. 5 are programmable, one stock, and the last is sort of a kill switch. if my utec comes in this week i'll be installing with scott's cams. we'll probably have a high and lo boost setup on 93 octane and a high boost on c-16 race gas. not sure what i wanna do with the other two maps. maybe hi-lo boost on 100 octane maybe? let you guys know how it turned out at the sema show in philly.
Old Mar 30, 2006 | 11:44 AM
tig488's Avatar
tig488
you might think about some stronger internals bullitproof. be careful.
Old Mar 30, 2006 | 12:34 PM
2slo2bfurious's Avatar
2slo2bfurious
So any generic selenoid would work? any reccommendations?
Old Mar 30, 2006 | 11:05 PM
Bullitproof
yeah, i know your'e right tig, but horsepower is horsepower right? i figure if most tt's can hit 460 plus, why can't a st? either way, i'll still build the motor eventually. i'm a horsepower junkie, ya know?
Old Mar 31, 2006 | 12:46 AM
blackend's Avatar
blackend
2. Yes
3-yes the new version of unichip Q+ got 5 maps
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
