Greddy TT SUBSTITUTE???
Old Apr 17, 2006 | 07:23 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by aalzuhair
Very interesting …. Do you know if the 62-1 HiFi is similar to the 60-1 Hifi in terms of external dimensions? I might give Mr. Tyler a call muhahaha
Yes it would be...its essentially machining the 60-1 Hifi housing for a 62-1 wheel. Similar to what SFR offers in their big turbo kit but with even more flow potential.
Old Apr 17, 2006 | 07:28 AM
tvieira24's Avatar
tvieira24
Originally Posted by Metal Heart
A TD05 is a TD05. You could buy a set of EVOIII 16G's from Forced Performance and they'd lower the MAX WHP a little, but spool up faster. Or you could get small 16Gs and the spool would be REALLY quick but again ... less max WHP. Both 18Gs and 16Gs are TD05s so you can fit them on the same manifolds. EVOIIIs 16Gs are like 700 new. 1400 total. Or find em used on a DSM board for like 500ish each.
These days, EVO III 16G's are about $450-$500 each new. They've gone down quite a bit. You can actually fit a 20G into a TD05 housing, but they won't be true td06 20g's. You get a little laggier but more top end, it's pretty common for the dsms. You can also upgrade to td06's, they have the same turbine housing inlet/outlet and will still work with your existing hardware.
Old Apr 17, 2006 | 07:30 AM
MIAPLAYA's Avatar
MIAPLAYA
A 20G/TD06 combo would be hard pressed to make over 1000 WHP in a Z. Sharif is going to try with a 60-1/TD06 combo and he should make 1000 WHP but the TD06 turbine is probably going to run out of breathing room much beyond that.
sales@czp
Sep 23, 2019 03:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
