ARC Oil Catch Can and AAM Spec Modified ARC Catch Can
Old Apr 13, 2006 | 01:04 PM
zachcrosen's Avatar
zachcrosen
Originally Posted by kevinapex
Mine will be at my door tomarow!! I'll post some picts.
Thannks for your help Dave!!
Post up pix when you get it all installed!
Old Apr 13, 2006 | 06:32 PM
mchapman's Avatar
mchapman
Originally Posted by dirtroad
You guys should go ahead and include the extra lines and connections needed. Make another few bucks on it, and us lazy consumers don't have to do anything extra.
+1
Old Apr 13, 2006 | 07:40 PM
dirtroad's Avatar
dirtroad
So I know there is a decent amount of oil in my system... will this catch can clean up the existing oil? In other words, does the oil move throughout the system, then once it hits the catch can, that's as far as it goes?
Old Apr 15, 2006 | 01:21 PM
kevinapex's Avatar
kevinapex
https://my350z.com/forum/forced-induction/184852-aam-arc-catch-can-install.html
Some Vortech Install picts. above.
Kevin
Old Apr 17, 2006 | 05:56 AM
jpc350z's Avatar
jpc350z
https://my350z.com/forum/showthread.php?t=184852
Kevin
What is the hose by the Blower for.. The air breather hose from the filter?? Seems big!!
Old Apr 17, 2006 | 06:17 AM
zachcrosen's Avatar
zachcrosen
That is the breather hose! It is huge!
Old Apr 17, 2006 | 07:28 AM
jpc350z's Avatar
jpc350z
[QUOTE=zachcrosen]That is the breather hose! It is huge![/QUOT
Where did you tap into for the Vacuum? And does the vac cause the plastic hoses to collapse ?
Old Apr 17, 2006 | 08:23 AM
zachcrosen's Avatar
zachcrosen
[QUOTE=jpc350z]
That is not my car in the pix. I have not installed a catch can yet! I just know that that is the breather hose because I have the Vortech and a huge size hose in the same area.
Old Apr 24, 2006 | 07:23 AM
buzzardmountain's Avatar
buzzardmountain
Bump, to see if a APS/Crawford strut bar can be installed in conjunction with the ARC catch can.
Old Apr 24, 2006 | 07:26 AM
dynamic6er's Avatar
dynamic6er
Yep this will capture the majority of the oil residue in the intake system that exits from the crankcase (bad turbo and supercharger seals cannot be stopped with this system). This is also dependent on how much blow by you have in your motor, but assuming a tip top seal you will see almost zero residue once the can is installed.
Old Apr 24, 2006 | 08:34 AM
dynamic6er's Avatar
dynamic6er
I tried a test fit today with the APS strut bar. It will fit just barely, but the brackets are not 100% lined up. This is becasue the APS bar forces the front of the catch can to tilt down slightly. You would need to make 2 small 90 degree brackets.
Old Apr 24, 2006 | 10:06 AM
buzzardmountain
You didn't take a pic by chance did you?
Old Apr 24, 2006 | 10:27 AM
dynamic6er's Avatar
dynamic6er
Nope, but i'll run out to the shop again and see if I can snap a few.
Old Apr 24, 2006 | 10:31 AM
buzzardmountain
Perfect, thanks.
Old Apr 24, 2006 | 11:27 AM
dynamic6er's Avatar
dynamic6er
Since the can and the strut bar are attached to the chassis its not a huge deal that it touches the strut bar.
Old Apr 24, 2006 | 12:56 PM
buzzardmountain
Thanks for the pics.
Old Apr 24, 2006 | 01:22 PM
dynamic6er's Avatar
dynamic6er
No problem
Old Apr 24, 2006 | 03:11 PM
  #38
NETSHARK's Avatar
NETSHARK
did you guys try it on G35 Coupe ? who knows maybe it will fit :P
Old Apr 24, 2006 | 03:22 PM
  #39
dirtroad's Avatar
dirtroad
my question is would it be ok to put something between the can and the strut bar to prevent rattles? or does that get too hot? i'm thinking like a piece of insulating tape?
Old Apr 24, 2006 | 07:29 PM
  #40
Yancy's Avatar
Yancy
"With a Forced Induction car it helps immensely to utilize intake vacuum (pre-turbo/suprecharger) to evacuate the crankcase of excess pressure created by blow-by and other factors. Ring sealing is better and seals/gaskets are less likely to blow out. At the same time, without a catch can, the atomized oil and carbon will eventually build-up in your intake piping and intercooler causing a loss of efficiency."
Does this come with a fitting whereby a line is connected to the block to eleviate the pressure? I've been told that the VQ engine has several areas on the block (ports I guess) that have plugged fittings that are capable of being tapped into to run a line from the block itself to a breather tank/oil catch can to eleviate the pressure that exists in the block/crank case area. Is that what this is doing? Thanks in advance.
