Timing
Old Apr 19, 2006 | 12:24 AM
RTracing's Avatar
RTracing
Default Timing
Does timing advance with the Greddy setup according to octane?
Say I have a street setup, will I see more power on 95 octane with my 91 oct boost map, or the same as if I had 91oct in and my 91oct boost map on?
Does the ECU Adapt?
Old Apr 19, 2006 | 01:32 AM
aalzuhair's Avatar
aalzuhair
The ECU might advance timing. You shoud log timing to see the before and after affect to know if ECU did
Old Apr 19, 2006 | 04:40 AM
theking's Avatar
theking
After a friend and I have been doing various logs with the UTEC we are seeing the stock timing not changing much at all. I doubt the ECU will adapt as quick as you are wanting it to. If you ran 95 octane for a few tanks of gas then you would have a chance. Otherwise, it will probably not change the timing at all.
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
