Hard/Rich Start - 440CC Injectors -Vortech
Old Apr 19, 2006 | 06:23 PM
OldManZ350's Avatar
OldManZ350
Default Hard/Rich Start - 440CC Injectors -Vortech
I've modified the Stock Vortech Fuel System with 440CC Deatschworks Ijectors and a 6 to 1 FMU.
The car runs well, but is a bit hard to start. It starts rich (1-2 seconds) then cleans out and idles good about 700RPM, the AFR fluctuates between 15.1 - 14.5 so I think that the SS box setting in those cells are fine.
Any Educated Ideas.........
Old Apr 19, 2006 | 06:31 PM
booger's Avatar
booger
Has any thing been done to adjust the SS box or your ECU for the bigger injectors ? You can do either of 2 things . Have Techno Sq. or AAM flash the ECU for the 440's or adjust the SS box numbers on the vacuum side . Either way , your gonna have to retune your fuel map
Old Apr 19, 2006 | 06:42 PM
OldManZ350's Avatar
OldManZ350
Hay Booger,
I retuned the SS fuel maps. Idle AFR is 15.1-14.5. Is it possible that it is still to rich, even though AFR is in the correct range?
Thanks
Old Apr 19, 2006 | 06:55 PM
booger's Avatar
booger
You still need to scale the injectors . If you didnt have TN or AAM flash for the 440's . What are your numbers onthe vacuum side of the fuel map ?
Old Apr 19, 2006 | 07:01 PM
OldManZ350's Avatar
OldManZ350
9.4 @ 20 in of vac
Old Apr 19, 2006 | 07:04 PM
OldManZ350's Avatar
OldManZ350
What is the procedure for scaling the Injectors ?
Old Apr 19, 2006 | 07:11 PM
booger's Avatar
booger
9.4 in just about all the cells on the vacuum side ? My guess would be that the [9.4] isnt the correct number . Or your not getting quite enough air .
I had TN flash mine for the 550's and left my vacuum map alone [ all 10's no change ]
Old Apr 19, 2006 | 07:15 PM
OldManZ350's Avatar
OldManZ350
9.4 to 9.6 in vac
Old Apr 20, 2006 | 04:28 AM
booger's Avatar
booger
You can go to SplitSeconds web site and there is a file for down load called.....U-tune . That will show you how to scale them correctly with the R4 . You do need a OBD to look at fuels trims though
sherm
Apr 11, 2020 05:21 PM
