anybody try nitrous with a stillen s/c
Old Apr 24, 2006 | 05:08 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Default anybody try nitrous with a stillen s/c
like the title says,i would think it would cool the intake charge a good amount which seems to be a problem with a roots type s/c.but would the cylinder pressure be through the roof,btw or have anybody tried this on a cent s/c.ps this is not another stillen flaming war ok.
Old Apr 24, 2006 | 05:17 AM
FastSedan's Avatar
FastSedan
Do the methyl and water injection.. No harm to the motor at all... Lasts longer.. Dramatic decrease in intake air temp. When I "WOT" on my SC G-35 I would expect the intake air to rise due to more friction in the air. On my temp gauge the air temp will drop one degree "C" every second until it hits about 16 degrees celcius.
Good luck
Old Apr 24, 2006 | 05:45 AM
superchargedg
Damn Noobs
Good luck
did you notice any power increase,and i also heard that water/meth inj would allow you to run more timing.but i cant figure how you would up the timing since stillen uses a locked split second box.
Old Apr 24, 2006 | 06:24 AM
FastSedan's Avatar
FastSedan
You are always going to notice a power difference w/ cooler air. Obviously its not like a 75 or 100 shot of NOS, but running cooler numbers is a positive all the way around. And yes I notice a power difference when the methyl injection kicks in. I like that you have security that the air will be nice and COOL.
Old Apr 24, 2006 | 09:23 AM
Gman2004's Avatar
Gman2004
you will loose power with WI if you don't tune for it. If you tune for it you loose the safety you are going for because if your WI kit takes a dump on you then you are left with a more aggressive tune and no WI.
Old Apr 24, 2006 | 04:03 PM
chrisle7220's Avatar
chrisle7220
I am actually in the same boat, would like to throw a small shot on top of my procharger. Im running 7psi with the procharger crappy FMU and stock injectors/pump. Would a small 25-30shot be ok?
Old Apr 24, 2006 | 06:36 PM
More Power's Avatar
More Power
The above post articulates exactly what my fear is with water/meth injection. I was hoping to tune for forced induction withOUT depending on the water/meth injection. Then just use the water/meth injection as an extra safety feature to help ensure no detonation. Are you pretty sure using water/meth this way would throw the power and tuning off? If so, I am going to just rely on running the sunoco GT+ 105 octane unleaded at the track for a saftey factor (but tune for the 93 octane gas so I don't have to run the 105 octane all the time on the street).
Old Jun 9, 2006 | 08:20 PM
caucasiancoupe's Avatar
caucasiancoupe
Has anyone run nitrous with their stillen or not? I've been thinking it would be a interesting setup. I bet it would run serious numbers.
Old Jun 10, 2006 | 04:33 AM
superchargedg
Damn Noobs
shortly ill be trying a 50 shot and see what happens.im putting stage 4 on in the next week or two.then in about a month n2o.
Old Jun 11, 2006 | 09:27 AM
TTRANK's Avatar
TTRANK
I have thought about it with mine but it seems too risky since I have stage 4 right now making ~8.5psi on stock internals.
Old Jun 12, 2006 | 07:23 AM
kevinbonds's Avatar
kevinbonds
I dont think you can run water injection in the intake track of a twin screw supercharger. I beleive that the rotors can be damaged by the H2o. I was doing some similiar research on that as well. I would think that the best alternative would be a wet nitrous set up with a custom nossle for like 10hp. although that hp increas may be small it may cool down the intake charge for a little margin of safety. Only problem with that is that nitrous runs out much faster then Met/water. So do some research on weather or not you can run water through roots blower. I think mike from violent racing was experimenting with these set ups. Maybe he will chime in
Old Jun 12, 2006 | 07:32 AM
BoOsTedz33TT's Avatar
BoOsTedz33TT
KABOOM, i dont know any FI car that runs a 50 shot on the street with stock internals. You know you just want the purge kit
Old Jun 12, 2006 | 08:53 AM
superchargedg
Damn Noobs
nah to old to want to look like a neon owner.i been looking and researching here(yes newbs you can use the search it does work) but all the info ive come across say,s yes you can but build the block first.so not going that way yet.
Old Jun 12, 2006 | 08:54 AM
MMC Racing's Avatar
MMC Racing
Running water/meth injection is somewhat common in the Lightning community and it is introduced before the blower. We have a very nice intercooloer setup from the factory, so most guys don't get much benefit from using injection. The Stillen intercooler setup is weak in my opinion, so there may be more benefit running injection than the Lightning guys see.
-Mark
Old Jun 12, 2006 | 10:17 AM
nateg35's Avatar
nateg35
Is any Stillen owner out there running water/meth setup?. I'm thinking of getting Coolingmist kit
Old Jun 12, 2006 | 12:46 PM
BoOsTedz33TT
WI isnt going to really do anything with a SC, maybe lower the AF, turbo is another story
Old Jun 13, 2006 | 07:20 AM
TTRANK's Avatar
TTRANK
I have the coolingmist kit on my Stillen blower. When I went to stage 4 I was starting to ping above 7.5psi (~6k rpm) plus it is 115+ degrees here in the summer so it was for peace of mind.
Old Jul 18, 2006 | 08:25 PM
TTRANK's Avatar
TTRANK
Anyone try nos with the Stillen yet?
Old Jul 19, 2006 | 04:31 AM
superchargedg
Damn Noobs
i was going to untill i checked with a few n2o companies.basically they said with the blower and nitrous the cylinder pressures would be way to high for a stock block.they all said it would run fine a few times and then boom,unless you built the motor to handle the pressure.
Old Jul 20, 2006 | 07:32 AM
TTRANK's Avatar
TTRANK
That's what I figured.
I guess it is time to sell my old nos kit I was keeping around just in case.
