on 2 guys garage they put a rear mount turbo on a vette, work on a z?
Old Apr 25, 2006 | 10:30 PM
scottycoyote's Avatar
scottycoyote
Default on 2 guys garage they put a rear mount turbo on a vette, work on a z?
i came in on the very tail end of the show, so i didnt get any of the details but from what i gather it makes pretty good power and its cheap. Just curious if any of you know the deal on the rear mount turbos, cost, ease of installation, and what kind of increase in hp you could get for a z? This might be right up my alley
Old Apr 25, 2006 | 10:38 PM
Three5oZee's Avatar
Three5oZee
now thats interesting.....not sur it would work too well though.
i bet lagg would be an issue if it were possible.
Old Apr 26, 2006 | 04:01 AM
Netko350Z's Avatar
Netko350Z
I thought STS was working on a system for the Z.
Old Apr 26, 2006 | 04:50 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
well i saw this about a year ago on the same show. i thought the idea was pretty cool cause the turbo would be soooooooooooooo much cooler. as far as the lag goes we were thinking about it. there will always be the air in the pipe between turbo and the intake manifold. so as soon as the turbo pressurizes the tube, the air should be forced into the engine as soon as the turbo spools. you would probably lose a bit of psi by the time it reaches the engine.
we figured that the exhaust would work the same way and have pressure in it back to the turbo.
the problem with this setup is that the turbo sits right under the back of the car and would be easily stolen. you could climb right under and take it. not sure if this would happen but we thought about that also....
probably would be less need for a front mount intercooler also...
all just my opinions..
Old Apr 26, 2006 | 08:16 AM
Kolia's Avatar
Kolia
Wow, we have thermodynamics pros here !
Heat = energy
Sooooo...
Less heat = less energy.
You want to run the turbo as hot as it can without melting.
14 feet of intake tubing makes a lot of losses in flow and pressure and tons of lag. Driveability will be horrible.
That system does make hp obiously. But its really getto IMO and not worth the trouble.
Old Apr 26, 2006 | 08:19 AM
sq40's Avatar
sq40
Heat = energy
Sooooo...
Wouldn't the exhaust velocity be higher though?
Also, heat on the Intake Side is Bad, you want dense, cool air and you want it to stay that way. That is why most shops wrap the exhasut side of the turbo.
Old Apr 26, 2006 | 08:20 AM
chimmike's Avatar
chimmike
there have been threads on this.
on the Z, where would you fit that turbo so that it doesn't get destroyed or rust to bits? I'll take my more complicated in-engine setup.
Besides, those two guys garage shatheads endorse the freaking turbonator.
Old Apr 26, 2006 | 09:28 AM
1G''s Avatar
1G'
https://my350z.com/forum/showthread....&highlight=STS
Old Apr 26, 2006 | 09:35 AM
Kolia's Avatar
Kolia
Nope. Contracting (cooling) gases in a fixed section tube will slow down pretty fast. Not counting the internal turbulance from the piping itself. You don't go faster when you loose energy.
Yes, and no.
The exhaust is wrapped to keep the exhaust gases heat IN the exhaust gases and maintain higher turbo speed. It does help keep the engine bay colder, but it doesn't affect the intake air that much. At the speed the air gets in, it's pretty much at ambient air temperature up to the compressor inlet.
You can wrap the intake to keep it cold (silicone hoses and such). But you'll get an intercooler to keep temps under control. The bigger the IC, the cooler the intake charge (good) but the more lag you get (not good).
Old Apr 26, 2006 | 09:51 AM
sentry65's Avatar
sentry65
the burninator
did anyone seriously think that STS turbo sounded any good?
seriously man, it sounded like a turbo civic or something - the piping is so long that you lose any exhaust sound you used to have and all you hear is whistling turbos.
that commercial with the viper and vette - the viper IMO sounds way way meaner than bzzzzzzmmm BZZZZZMMMMMM
otherwise it'd be nice in terms of install and keeping the turbos cooler than having them in the engine bay.
Old Apr 26, 2006 | 10:06 AM
Zilvia's Avatar
Zilvia
Id still say it would own ***.................but all i have to base that on is how much the STS vette kit owns ***
Old Apr 26, 2006 | 10:50 AM
plumpzz's Avatar
plumpzz
Uhh you actually get more power from cooling air then pressurizing it, as a turbocharger is 75-80% adiabtic process (Mr. Thermal guy :-P ).. As long as the mass airflow remains same, which it will regardless of temp, the turbine will spin up to the same RPM.
Intercooling is far more important and pressurizing. As long as the air remains cool, and is greater than 1 atmosphere, you will have a good increase in power. I only question the boost threshold of the entire system since there is a lot of piping. However, from my understanding, its the same amount of piping as under a hood, which sounds believable..
Old Apr 26, 2006 | 11:05 AM
Audible Mayhem
My350z
thank you...
Old Apr 26, 2006 | 11:26 AM
Kolia's Avatar
Kolia
Really ?
And how adiabatic will be the 6 feet piping between the engine and the turbine ? This setup is basically running the exhaust gases in an intercooler before sending it to the turbo !
No, the turbine will not spool as fast with cool exhaust gases than hot ones. Exhaust gases velocity is what counts.
The whole thing does make power obviously. You do make some boost after all. But nothing like a proper close-to-the-engine setup.
edit: What's missing to comprehend the reason for running hotter gases through the turbo, is that the hot gases density is less than cool gases. Yet, the mass airflow is the same. This explain why the velocity of hot gas is higher. The turbine blades won't turn faster than the speed at wich the gas passes through it...
Intercooling is great, provided you need any...
Old Apr 26, 2006 | 11:33 AM
Audible Mayhem
My350z
With the turbo so far back, don't you get a lot of turbo lag?
No, our turbochargers are sized to operate at this remote location. Just like any turbocharger, once the turbo is up to temperature and in the rpm range for which it was designed to operate. The boost comes on hard and fast. All of our systems will produce full boost below 3000 rpm.
If you were to take a conventional turbo and place it at the rear, you would have lots of lag and consequently, our turbo wouldn't work properly if mounted up front
Old Apr 26, 2006 | 11:34 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
+1 to Kolia
No way, mass flow is not nearly as important as gas velocity.
Old Apr 26, 2006 | 11:35 AM
Audible Mayhem
My350z
Doesn't heat create the velocity in the exhaust gasses to spool the turbo?
No, heat doesn't create velocity. Heat creates volume. If you look at any of the physics laws for gasses, you will find that pressure and volume and heat are related. PV=NRT is a popular one, The V isn't for velocity, it is for Volume.
The turbine housing is what creates the velocity. The scrolling design that reduces the volume of the exhaust chamber as it scrolls around causes the gasses to have to increase in velocity and pressure to maintain the same flow rate.
Hotter gasses have more volume, thus requiring a higher A/R which in effect means that it starts at say 3" and scrolls down to approximately 1". Lower temperature gasses are denser and have less volume, so they require a lower A/R housing which would start at the same 3" volume, as the turbine housings use standard flanges, and scroll down to say 3/4".
Now if you were to reverse the housings in application, the conventional turbo would spool up extremely quick, at say around 1500 rpm but would cause too much backpressure at higher rpms because the higher volume of gas couldn't squeeze through the 3/4" hole without requiring a lot of pressure to force it through. On the reverse side, the remote mounted turbo with its cooler denser gasses, wouldn't spool up till say around 4000 rpms but once spooled up would make efficient power because it doesn't require hardly any backpressure to push the lower volume of gas through the larger 1" hole
Old Apr 26, 2006 | 11:39 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
^^ No one said that the V is for velocity.
The real question as to how fast the turbo spools up is this:
WHAT is the pressure drop before and after the turbine?
High T = high P before the turbo. Then you want low a pressure as possible (no backpressure) AFTER the turbo.
Conversely, if you mount a turbo at the tailpipe, you will have lower T = lower P = slower spool...
Old Apr 26, 2006 | 11:47 AM
ChromeZilver's Avatar
ChromeZilver
This has been the debate with STS every since they came out. And you scholars can debate the details all you want, all ll I know is that it works and works well. The fact that they are still in business and blowing peoples minds and conceptions with the "remote mount" system is more then enough for me. That and my friends turbo'd Camaro SS and Z06 that I have driven and experienced. The power is so sweet it's almost disgusting! They are doing a kit for the 350Z, it's on their website, and it will be out this summer I'm told.
Kolia's Avatar
Kolia
I like how audiblemayhem keeps repeating that the remote turbo will give the same power ONCE THE TURBO GETS TO SPEED
Thats great if the engine is on a test bench and being dynoed!
From the drivers stand point, the enemy of a turbo is LAG. Pretty much any turbo can blow enough air to grenade an engine. It just a question of how long you wait for it to happen. This is why boost is controlled by a waste gate...
So, eventually the remote turbo will make power. Then you shift, and start again to build your boost...
