turbonetics single turbo
Old Apr 27, 2006 | 02:19 PM
  #41
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Dr.G
Eaton roots blower by the way are used by mercedes benz and jaguar and (it is a fact ) the most reliable FI (Supercharged Book by Corky BELL. The last car i had was Audi S4 i do not think turbos evolved that much ..since ...oh maybe They should take you as a consultant engineer in Nissan because i think they are designing a 350z turbocharged and they need somebody like you.
Ever read Maximum Boost by Corkey Bell? By the way his books were written 10 years ago and most of the info while valid is dated in regards to bearing design. And again since you clearly are not capable of reading..
The difference between aftermarket performance designed turbochargers is vast when compared to factory conventional sleeve bearing turbochargers. To compare a conventional sleeve bearing factory/OEM turbocharger to an aftermarket one is like comparing apples and oranges. If you want a reference for turbochargers you may consider reading some of Mike Kojima's work on turbocharging. BTW he IS an engineer for Nissan. Oh and Mercedes Benz ALSO uses turbochargers in several AMG applications. SL65 I belive use twin turbos. Oh yeah and it makes A LOT more power then the Roots blower model car.
Old Apr 27, 2006 | 02:25 PM
  #42
Dr.G's Avatar
Dr.G
li don't see a place where it says aftermarket turbochargers are more reliable than the antique roots blower...or did i miss anything?..however the oppsite was mentioned by Mr. Bell himself.
Old Apr 27, 2006 | 02:26 PM
  #43
MIAPLAYA's Avatar
MIAPLAYA
10 years ago I'm sure he did. I think that text would change I know Engineers of his caliber and greater already disagree with that statement.
Old Apr 27, 2006 | 02:30 PM
  #44
nateg35's Avatar
nateg35
sorry for hijack this thread a little bit...what are the most reliable TT out of there out of the box...JWT or APS ?...I'm not looking to make over 400whp or anything that big
Old Apr 27, 2006 | 02:31 PM
  #45
MIAPLAYA's Avatar
MIAPLAYA
For a TT kit any of them can be made reliable. Out of box probably JWT or APS. The Greddy is up there with the addition of some parts.
Old Apr 27, 2006 | 03:07 PM
  #46
chimmike's Avatar
chimmike
I've got money willing to say they're more reliable AND will easily and more efficiently make power.
Old Apr 27, 2006 | 03:08 PM
  #47
chimmike's Avatar
chimmike
TN ST or any other turbo kit are great for power, but they are headache.
Once again spouting out your *** without any proof.
I did the install myself, on ramps in my garage. I've not had a single problem yet, and I could wipe the floor with your pathetic PhD ***.
Old Apr 27, 2006 | 03:29 PM
  #48
Peking's Avatar
Peking
Wow, just wow. So you so happen to be vastly knowledgable and have the experience of every single supercharged or turbo'd car from the factory with real world long term testing from all the boosted cars throught auto history.
You know since you can just say "it is a fact"... Muhahahahahhahahhahahahah, I don't know if I should laugh more about how idiotic your post is or laugh at the brashness of your generalizing ignorance.
I don't know about the rest of you guys, but boy did he just teach me a whole lot within one post about the history of the Eaton roots style supercharger
Seriously dude what kind of arguement are you trying to make here? Low boost in either form along with complimenting supporting parts make either one reliable as long as the owner takes car of the car.
Thing is when you want to make the big power. Realistically you will not be able to make the same kind of numbers with a roots charger... Even if it is so huge that you could not use your OEM hood, imagine the strain of trying to turn those screws... I see alot of snapping belts.
It isn't like either design can rival that of a A-Bomb or the design of like a space station here... So trying to push your feelings on how the Eaton design is far beyond a typical turbo coming to reliability doesn't make any sense.
And if you think Nissan is now designing a "turbo car" then even more... Wow... How clueless are you? Turbo'd cars from the factory have been going on for quite some time and Nissan has had many good ones in their stable.
Old Apr 27, 2006 | 03:37 PM
  #49
MIAPLAYA's Avatar
MIAPLAYA
On a side note Nissan was the first company to pioneer ball bearing center sections in the Skyline. Ceramic compressor wheel and plastic like turbine wheels made for EXCELLENT spool up..although the downside was decreased life which is why aftermarket turbos have such a following..
Old Apr 27, 2006 | 03:43 PM
  #50
chimmike's Avatar
chimmike
actually they were plastic compressor wheels on the rb25det's and utilized ceramic turbine wheels, which aided in excellent spoolup....but now turbo design is so good, no need for plastic or ceramic wheels.
the only time those turbos with plastic wheels didn't last is if you upped the boost a bit.
Old Apr 27, 2006 | 03:45 PM
  #51
MIAPLAYA's Avatar
MIAPLAYA
Correct, sorry I reversed them when typing. The other problem with those wheels is if you surged they were easily damaged. Metallic compressor wheels can be damaged too but the plastic compressor wheels in these turbos were far more prone to damage from this.
Old Apr 27, 2006 | 04:37 PM
  #52
VenomZ's Avatar
VenomZ
not that I'm bashing stillen, but there is another very popular thread right now titled "stillen stage 4 , no power gain"
and in my defense, I haven't read it in awhile..but I know that for the cost to go from a stillen stage 3 to a stillen stage 4...I could spend my money on engine components for my turbonetics kit and realize gains w/o having to worry about it.
Old Apr 27, 2006 | 04:51 PM
  #53
Kolia's Avatar
Kolia
Whew ! What happened in the time I drove from work to home !
Don't feed the troll if you want to get rid of one...
Old Apr 27, 2006 | 05:30 PM
  #54
tomcatm's Avatar
tomcatm
Originally Posted by MIAPLAYA
No comment
Ok how about this can you tell me if this announcement will be made anytime before March 07?
Old Apr 27, 2006 | 07:04 PM
  #55
MIAPLAYA's Avatar
MIAPLAYA
Should be...
Old Apr 27, 2006 | 07:13 PM
  #56
Bumble350z's Avatar
Bumble350z
Old Apr 27, 2006 | 09:03 PM
  #57
MI 35th's Avatar
MI 35th
OGPremierMafia
All i have to say is if their is a warranty like the stillen, its all over! I would see no reason anyone would want the APS!
Old Apr 27, 2006 | 10:15 PM
  #58
Dr.G's Avatar
Dr.G
if SC are antique (especially roots Eaton) and Turbos are better, more reliable, more everything , then i find it very odd to see that in their 2006-2007 most expensive cars manufacturers like: Range Rover , Benz, Jaguar, Dodge,...all went back and used that antique blower?????????????
perhaps they made a mistake and they should have asked you smart asses what to do!!!!!
Old Apr 27, 2006 | 10:39 PM
  #59
gatti-man's Avatar
gatti-man
please everyone ignore dr.g please......
Old Apr 27, 2006 | 11:50 PM
  #60
VegasZ35TH's Avatar
VegasZ35TH
Man this thread has gotten real interesting. Got my attention. I have been going back and forth on the idea of going FI. My original choice was going SC but unfortunately can't with the 35th AE 300hp motor. However Turbo is still an option. I have only 8k miles on mine and really leery about adding a turbo at this point. I unloaded some NA mods to be keep it running on the safe side but the gains Turbo is so tempting especially seeing the number of Turbonetic owners out there. I have read several threads on FI and have no problem shelling out more but I can't make up my mind if it's really worth it.
MI 35th - If you decide to go with the install, let me know how your impressions afterwards.
