Confused about the way the Turbonetics Kit bolts up
Old May 1, 2006 | 11:19 AM
Conceyted's Avatar
Conceyted
Default Confused about the way the Turbonetics Kit bolts up
Okay, So I have been researching on the TN kit. I plan on one in the very near future. However, I notice that the kit appears to come with a single header that bolts up to one side where the turbo sits... but where does the other header output to? I have a stillen true dual exhaust at the moment, and I think, from what i have gathered, i am going to need to get some custom reverse y-pipe done to make the stillen exhuast work with the TN kit? If someone could take a pic or two of underneath their car with the TN kit it would be awesome... I just want to make sure i can do this without needing to get it professionally installed
Also, does the TN kit bolt up to the stock exhaust with no issue? Would it be a better idea to jump back down from the stillen true dual to the stock exhaust when the TN kit goes on?
Thanks
Old May 1, 2006 | 11:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Do a search under my name in this forum, I did an install thread with PLENTY of pics if you want more clarification on what Im about to say. The kit uses stock exhaust manifolds, the pipe runs from the passenger side exhaust manifold under the tranny up to the turbo. Yes you would need a reverse y-pipe made for any true dual to work. The stock exhaust will bolt right up up to you if you want to run it.
Old May 1, 2006 | 12:23 PM
Conceyted's Avatar
Conceyted
cool... found it. But I still dont get it. Does the piping replace the stock ypipe completely? and the rest of the exhaust bolts up to where the stock y would connect to the bpipe?
Old May 1, 2006 | 12:25 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes the 3rd downpipe in the kit replaces all the way to where the stock y-pipe ends.
Old May 1, 2006 | 01:31 PM
Three5oZee's Avatar
Three5oZee
your true duel set up will not work...... you will need to got back to the factory set up so that the TN pipes can line up an give u an exhaust.... well worth it...
Old May 1, 2006 | 01:52 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
maybe this pic will help
Attached Thumbnails Confused about the way the Turbonetics Kit bolts up-tneticsst.jpg
Old May 1, 2006 | 04:47 PM
taurran's Avatar
taurran
Not true... get a reverse y-pipe fabricated and you can split it up to a true dual exhaust. This has been stated 1,000,000 times on this forum. Sometimes I feel like a broken record.
Do a search, there are numerous threads that cover this topic in detail.
Old May 1, 2006 | 06:13 PM
MIAPLAYA's Avatar
MIAPLAYA
+1
Old May 1, 2006 | 07:58 PM
Conceyted's Avatar
Conceyted
THANK YOU! thats exactly what I was looking for! Appreciate that...
AbrasiveRaysive
Sep 20, 2021 02:29 PM
