vortech with a wastegate
Old Oct 1, 2008 | 05:54 PM
  #61
sajazzman007's Avatar
sajazzman007
DIY'er Unite
Originally Posted by gspot35
Just to set the record straight, I removed the manual boost controller as Booger said. I did not however replace with an electronic boost controller. I simply relied on the 8 psi spring in the wastegate.
Forget what AAM is trying to sell you guys, you can do this all for about $400 + tuning. PM me if you want details. You don't need injectors, or a fuel system upgrade as you are not using any more air than a stock Vortech setup. They can also keep their reflash too. As far as the wastegate before or after the IC, I had mine before the IC and AAM reinstalled my system in someone else's car and put it after the IC. Their stance at the time was that it shouldn't matter. I think it was just the easy way out.
Good luck to importofamerica on your conquest.
PM sent
Old Oct 1, 2008 | 06:15 PM
  #62
Cux350z's Avatar
Cux350z
hatersgonnahate
928 motorsports offers a boost lmiting valve for under 200. You can dial it from 0 to 20psi iirc. PM Quamen for more info or even me, I can put you in contact with them.
Old Oct 1, 2008 | 06:33 PM
  #63
gspot35's Avatar
gspot35
Here's some pics I can't remember if I ever posted.
I think it's great that this got stirred up! Good luck in your hp gains!
Old Oct 1, 2008 | 07:34 PM
  #64
mchapman's Avatar
mchapman
Quoted Quamen in Thread:
https://my350z.com/forum/shop-builds...ld-pics-9.html
"Here is a picture of the intial prototype adjustable pressure relief valve for supercharged applications!"
Old Oct 1, 2008 | 08:00 PM
  #65
str8dum1's Avatar
str8dum1
All that wastegate stuff is too much money. Just use a stretched belt like me
Old Oct 1, 2008 | 08:06 PM
  #66
Cux350z's Avatar
Cux350z
hatersgonnahate
what size pulley are you running? stock cog pulleys?
Old Oct 2, 2008 | 06:32 AM
  #67
sajazzman007
DIY'er Unite
[QUOTE=gspot35;6372904]Here's some pics I can't remember if I ever posted.
This is outstanding. If you look at the overall of the project it seems like the most you will pay for is the weld, the wastegate, the pulley, and a boost controller to keep everything safe. This is all the motivation I need to produce something like this for myself. Gspot you have to hit me up on the pm and let me know how you completely did it we gots to talk! I seen this yesterday in a mustang magazine and it put out some nice power I also wonder if america earlier in the forum used the idea of the HKS racing bypass valve and how did that work?
Old Oct 2, 2008 | 05:12 PM
  #68
mchapman's Avatar
mchapman
[QUOTE=sajazzman007;6374460]
I think its great they got something working for there requirements as well but correct me if im wrong... I think that the guys from 928 Motorsport achieved the goal without the need to go the wastegate path. Wouldnt you rather spend $200 on their product than alot more on a Wastegate and additional hardware?
Old Oct 2, 2008 | 07:12 PM
  #69
mchapman's Avatar
mchapman
Looks like the production one is available. $185.00
http://www.928motorsports.com/parts/...mitervalve.php
Old Oct 2, 2008 | 07:29 PM
  #70
Cux350z's Avatar
Cux350z
hatersgonnahate
If you guys are interested in the BLV, call 928 motorsports at (920) 485-0928 and ask for Gretchen ( she should be the one that answers, tell her Chris in SC sent ya)
Old Oct 2, 2008 | 09:44 PM
  #71
Mr_pharmD's Avatar
Mr_pharmD
Can this thing build boost faster but still keep the same amount of boost til redline? for ex. If I see 15psi at wot now without the thing, can I use this to build boost faster around 2Krpm and still keep the full 15psi at wot or will it drop my psi?
Old Oct 3, 2008 | 03:16 AM
  #72
Cux350z's Avatar
Cux350z
hatersgonnahate
Its a boost limiting valve. Its most useful for those with centrifugal superchargers like ati, vortech, and hks (ie, not stillen). We builed boost linearly with rpms. We only hit peak boost at peak rpm.
What this valve allows us to do is take pulley that builds boost from 1psi to 15psi, and cap it at 10psi by venting the extra air. You still build boost over the same RPM range, it just comes in quicker with the smaller pulley.
A pulley that makes 15psi and is boost limited to 10psi, will make more power at lower rpms then a pulley that makes 10psi at redline and no boost limiting valve.
Old Oct 3, 2008 | 03:53 AM
  #73
str8dum1's Avatar
str8dum1
Mr pharm, Arent u already running a 34/28 2.87 on a non-revup?
unlss u went to a 2.62 puley and a redline of barely 6000 rpms, u wont gain anymore boost.
also how would limitin top end boost increase low end power? your boost is tied directly to rpm. next time you dyno, let off the gas at 8 psi instead of 10. it wont havve any effect on your boost curve.
plus if your making safe power, why would you want to decrease it?
i think the wastegate would only be useful if
1. you are making unsafe hp levels at redline (wont happen without a t-trim)
2. your boost levels are just making hot air with no real increase in power (hp/psi ratio)
Old Oct 3, 2008 | 11:29 AM
  #74
Mr_pharmD's Avatar
Mr_pharmD
right now i'm running 32/28 with the 2.87 pulley on non rev. I'm seeing a little over 15psi but was wondering if there was a way to build boost faster. I was hoping this valve would be the solution to increasing low end pw but I guess not... unless I swap in the 2.62 pulley and cap the boost but that would be too much trouble.
Old Oct 3, 2008 | 11:50 AM
  #75
Quamen's Avatar
Quamen
It sounds like the billet impeller I tested for them would be right up your ally since it would give more boost across the entire rpm range with the same pulley.
Search my threads if your interested in it and I have a full right up on it with boost charts.
Old Oct 6, 2008 | 07:28 AM
  #76
Blck350z's Avatar
Blck350z
Hey guys, I was actually going to do a tt kit but have settled on a T trim w/ race bearings etc for a great price..... I was wondering since I already have the HKS EVC 6 could I just buy the waste gate and be done w/ it????
Thanks John
Old Oct 8, 2008 | 07:41 AM
  #77
Blck350z's Avatar
Blck350z
Anyone?????
Old Oct 8, 2008 | 02:36 PM
  #78
ekelly36's Avatar
ekelly36
How are you seeing 15psi of boost with a 2.87 pulley?
Old Oct 8, 2008 | 05:24 PM
  #79
Mr_pharmD's Avatar
Mr_pharmD
simple upgraded to T trim
Old Oct 9, 2008 | 11:14 AM
  #80
sajazzman007
DIY'er Unite
Thanks John
Good Question well from what the forum is saying you would need, thats basically it. I was looking to the synaspe wastegate, seems like a solid investment when they do the comparrisons to a traditional wastegate.
Jon
