HKS VQ35 twin turbo announced
Old May 3, 2006 | 01:08 PM
Nismo 350z's Avatar
Nismo 350z
Default HKS VQ35 twin turbo announced
Hey guys. I was down at my local Ralphs the other day and started reading Sport Compact Car June 2006 issue. In it they were showing coverage from the 2006 Tokyo Auto Salon and HKS has their TT kit coming. It said it will use their new GT series ball bearing turbos and new dual exhaust. They also have their new F-con IS which has a digital display that will show you info on your Nav screen... very similar to the Motec digital dash display. Can't wait for their TT kit to come out. Maybe Wil Pwr can contribute with pics, info, release date, price?...
Old May 3, 2006 | 02:11 PM
Fairlady_z33's Avatar
Fairlady_z33
Only downside its going to be expensive
Old May 3, 2006 | 02:15 PM
Nismo 350z's Avatar
Nismo 350z
Agreed but it probably will be a kick @$$ kit. Their Supra and Skyline kits were awesome. Could only imagine what this thing can do with a built VQ.
Old May 3, 2006 | 02:58 PM
absolutg's Avatar
absolutg
i wonder if they're going to do one for the sedan...
Old May 3, 2006 | 03:18 PM
barthelb's Avatar
barthelb
Master
Just take it to a competent tuner and they will make it fit.
Old May 3, 2006 | 04:06 PM
rkd350z's Avatar
rkd350z
Want to see it!
Old May 3, 2006 | 04:46 PM
Mahdivr4's Avatar
Mahdivr4
there was a post about it on here or g35driver, and there are pics and a lot of info on there.
Mahdi
Old May 3, 2006 | 04:49 PM
sentry65's Avatar
sentry65
the burninator
anyone have a picture of this thing?
Old May 3, 2006 | 08:28 PM
brooke's Avatar
brooke
bump
Old May 4, 2006 | 12:18 AM
Roadstar's Avatar
Roadstar
nice~~
as mentioned above, the previous kits for skylines are ****ing wicked, just hope that this one will be just as great^
Old May 4, 2006 | 03:14 AM
mistaboosta's Avatar
mistaboosta
i don't think that HKS TT kit will be much more better than the APS TT. I guess HKS will be using the same turbos as APS. In terms of quality, again they shoud be around the same level. In terms of price, Japans overprice their goods.
Old May 4, 2006 | 03:17 AM
mistaboosta
also HKS released their engine internals for VQ35DE (piston and rods)
Old May 4, 2006 | 09:08 AM
bsp's Avatar
bsp
Brainstorm Performance
Someone posted some pics of the HKS kit before I believe. I'll see if I can dig them up.
Old May 4, 2006 | 09:09 AM
bsp's Avatar
bsp
Here it is:
https://my350z.com/forum/exterior-and-interior/164561-evo-r-carbon-fiber-eyelids-at-tas-06-hks-350z.html
Old May 4, 2006 | 09:49 AM
Zexy's Avatar
Zexy
They released the good news, now where's the bad news(price)
Old May 4, 2006 | 10:25 AM
trescincuenta's Avatar
trescincuenta
- HKS VQ35DE Forged Engine Internals and Metal Head Gaskets -
HKS Forged Piston & Connecting Rod Kit and Metal Head Gasket Set are now available for the
Nissan VQ35DE engine. The combination of HKS Pistons, Connecting Rods and Metal Head
Gaskets strengthens the VQ35DE engine substantially and allows the engine to increases revs to
7,200RPM. The HKS Piston & Connecting Rod Kit are engineered for forced induction
applications and specifically designed for the factory crankshaft. The HKS VQ35DE Metal Head
Gaskets are targeted for forced induction and high-horsepower naturally aspirated applications.
The HKS VQ35DE Pistons and Connecting Rods are forged from special alloys for strength and
durability over their factory counterparts. The HKS Pistons lowers the compression ratio to 9.0,
and the HKS Connecting Rods utilize an I-beam structure. The VQ35DE factory connecting rods
have a tapered design which is a weak-point for high-horsepower applications. HKS Connecting
Rods address this weakness by maintaining thickness from end to end. To prevent the need to
perform balancing modifications to the factory crankshaft, HKS Pistons weigh the same as the
factory pistons, and HKS Connecting Rods have the same weight distribution as the factory
connecting rod.
The HKS VQ35DE Metal Head Gaskets are 0.7mm thick and feature a 4-layer stopper-type
structure. The stopper-type structure employs a stopper ring around each combustion chamber
that is molded into the head gasket for a precise and strengthened seal. The factory head gasket
is only made from 3 layers and has a bead-type structure. A bead-type head gasket only uses a
raised bead to seal the combustion chamber.
Part # Description Spec. MSRP
Forged Aluminum Pistons
- Compression Ratio: 9.0:1
- Bore: 95.7mm (OEM 95.5mm)
- Displacement: 3513cc
(OEM 3498cc)
21004-AN007
Forged Connecting Rods
- I-Beam Shape
- Non-Tapered design
- Reinforced Connecting Rod Bolt
Included
$3530.00
23011-AN002 Metal Head Gasket Set
- Right and Left Sides Included
- Thickness = 0.7mm
- 4 Layer
- Stopper-Type Structure
- 97mm Bore
$360.00
Old May 4, 2006 | 11:36 AM
mojo powered's Avatar
mojo powered
that headgasket kit is interesting
Old May 5, 2006 | 07:41 AM
Road Warrior's Avatar
Road Warrior
thats what she said
Old May 5, 2006 | 11:37 AM
turismo's Avatar
turismo
Just talked to HKS, they will not be coming out with the kit for the US market. This is only a prototype and is for Jspec models only.
Old May 5, 2006 | 11:39 AM
Road Warrior
any plans for building a us spec kit?
