Plenum gasket blew, and I know why...Check this out before you install a fuel system!
Old May 11, 2006 | 09:58 AM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by Quamen
I also noticed that the bolts are not countersunk which makes a difference. I still had to grind some off of my manifold with my CJM rails and 550cc RC injectors. Other than that it was perfrect.
something is not right... there is no grinding needed with the CJM rails if you have the countersunk bolt version.
the hardware does not stick out from the fuel rails.... which would mean the the rails themselves are hitting your manifold, which definatly is not right.
Please send me pictures of your setup so I can evaluate the issue.
Old May 11, 2006 | 11:07 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I have taken my manifold off a half dozen times, and removed and reinstalled the fuel system about 3 times, and have never seen this before. Maybe there are some minor differences in casting. Either way, its a good idea to double check the clearances, and grind down where necessary.
Old May 11, 2006 | 11:27 AM
phunk's Avatar
phunk
CJ Motorsports
its not noticable unless you look for it sharif. next time you have the manifold off take a little peak on the flange, you will see it.
Old May 11, 2006 | 11:29 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
if you need a lower plenum, let me know, i have one sitting here in my garage..
Old May 11, 2006 | 11:37 AM
Sharif@Forged
Forged Performance
I have looked very closely. I even did some clean up porting on the lower plenum, and checked the gasket. I understand where it would hit..just not sure why mine is clear.
sales@czp
Sep 23, 2019 03:30 PM
