boost gauge install
Old May 12, 2006 | 05:13 PM
azmark30's Avatar
azmark30
Default boost gauge install
Does anyone have any links or past threads on how to install boost gauge?
I know which vacuum hose to T into but I dont know how to get it to the middle nav box or what wires i should run the power into..
is there a easy way to get thru the firewall ?
any info would be great..
Mark
Old May 13, 2006 | 08:03 AM
supra crazy's Avatar
supra crazy
bump
Old May 13, 2006 | 12:24 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Run the vaccum line through either the OEM harness grommet, or the hole located next to the brake booster on the driver side. Once the line is inside the cabin, you are good to go. The boost gauge requires switched power and ground, which you can find in a vast number of locations under the dash board. Hope that helps.
codek
Sep 28, 2015 03:03 AM
