Does anyone have this set up?
May 14, 2006 | 01:56 PM
- carillo rods
- wiseco pistons
- new Nissan rod & main bearings
- rings
- ARP head & main studs
- cometic headgaskets
- pulley set
- 880cc injectors
- Ultimate e-manage
- Greddy TT
My car is still in the shop after 3 months and they are finally putting the motor back in the car on monday. And i was just wondering if anyone here has this set up and what is there power band like.
May 15, 2006 | 02:28 PM
or anything similar to it??????
May 15, 2006 | 03:02 PM
A lot of people have very similar setups.
May 15, 2006 | 03:11 PM
Thanks. Am a bit worrie, i don't want to get less than what i expect out of it. And there is no good shops that can tune Z's in Jax.
May 15, 2006 | 03:19 PM
those injectors are an over kill.. if the injectors too big you can have problems idling.
May 15, 2006 | 03:28 PM
Can i put 600++ whp with this set up?
May 15, 2006 | 03:42 PM
May 15, 2006 | 03:53 PM
Thanks, i will be the first Z here in jax with those numbers. I know to the west coast thats nothing.
May 15, 2006 | 03:56 PM
Quote:
Originally Posted by z33boi
I don't see why not
He's going to have to flash the ECU and have the injectors scaled to 750's in order to get them to work with the EU.
May 15, 2006 | 03:57 PM
even with the ultimate e-manage?
May 16, 2006 | 10:21 AM
I would just bite the bullet and ship your car to SGP or Sharif.
May 16, 2006 | 12:55 PM
Quote:
Yes because you won't be able to scale such large injectors without flashing the stock injectors.
May 16, 2006 | 04:13 PM
How much does it cost to get it flash and who do you recomend? Thanks!
May 16, 2006 | 05:05 PM
about $600. AAM did my flash. I am running rc750's and my ecu was flashed for 650's.
May 16, 2006 | 06:19 PM
address the head studs: get the L19 from sharif...that will be cheap insurance on not having to pull the motor in a few months and then do it anyway
May 18, 2006 | 05:58 PM
The motor is already built and ready to go in the car. Is the head studs something that i can do without taking the motor out?
May 18, 2006 | 06:10 PM
you can, but not without some work... because the studs are located under the cams...and to get out the cams you must pull the timing cover off...
May 20, 2006 | 08:11 AM
On labor, how many hours will it take?
