Greddy TT VS. APS TT- Price of performance
Old May 16, 2006 | 05:40 PM
dozzer1b's Avatar
dozzer1b
Nice numbers there, sucs about those 2 motors blowin, were u able 2 get compensation from those installers???? and do u run 16 daily???
Old May 16, 2006 | 05:45 PM
Gman2004's Avatar
Gman2004
Compensation? Yeah right! I wish!
I don't run 16psi daily. In fact I haven't used 16psi in a while. It seems that folks boosting more than 12psi are seeing headlift, so I have been running 10psi which was about 440whp on the dyno dynamics. I order a overzealos head mod and I am probably going to replace my ARP head studs with the L19head studs. If I didn't have headlift I would be running 16psi daily and as soon as the probablem is fixed I will be running 16psi daily.
If you do build don't go with the ARP standard studs get the L19 studs.
Old May 16, 2006 | 06:01 PM
dozzer1b's Avatar
dozzer1b
Nice, thanks for the heads up.....u got any vids on a dyno, or pics u could post of the motor work????
Old May 16, 2006 | 06:05 PM
Gman2004's Avatar
Gman2004
no dyno vids, but look here for a 10psi and 16psi run.
https://my350z.com/forum/forced-induction/182796-short-vid-of-10-psi-and-16-psi-runs.html
Old May 16, 2006 | 06:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I wouldnt even compare the out-of-the box Greddy kit with anything else out...becuase its a time bomb. $5800 is just the kit and intercooler (I have two kits in stock)...you need a few more components to make it safe and complete.
The comparison should be this vs. everything else out there. I consider this the safe and complete Greddy kit...the way it should have been out of the box: https://my350z.com/forum/showthread.php?t=156630
Old May 17, 2006 | 03:46 PM
thawk408's Avatar
thawk408
Are the APS turbos better at resisting heat during a raodracing course because of the water cooling? Or does it make little to no difference?
Old May 17, 2006 | 07:40 PM
Sharif@Forged
Forged Performance
In theory, yes. In practice, you will be hard pressed to notice any difference in engine bay heat, inlet temps, or oil temps, between the various TT kits out there. As long as you have taken the necessary upgrades, such as a new rad and oil cooler, you should have no issues road racing any of the kits.
Obadabot
Jun 18, 2023 11:31 PM
