Anyone using Blitz SBC i-D boost controller?
Old May 27, 2006 | 02:22 AM
taurran's Avatar
taurran
Originally Posted by Gman2004
Is anyone with this boost controller using the Speed Map feature?
- Speed Map - This unique feature allows the SBC i-D to control boost according to the speed of the vehicle (Power Meter i-D required). Speed Map boost control can be set up from a 2 stage to a 4 stage control, which allows the user to set boost according to his driving style. Speed in transfer by infrared between the Power Meter i-D and SBC i-D.
That does sound interesting, but I don't have the power meter installed (it's another Blitz unit entirely). I'm not even sure what it offers as far as functions go, or how much it costs.
Old May 27, 2006 | 07:06 AM
Gman2004's Avatar
Gman2004
Off hopupracing's website.
The Power Meter i-D is a unique monitoring tool that measures and displays horsepower and speed. The Power Meteor i-D is one of the only units in the world that can display both standard and metric measurements. Power output can be display in HP, PS and kW. Speed can be displayed in MPH and km/h. Both power and speed can be displayed in digital and graphical form. The Power Meter id also has a Chassis Dynamo function, which plots Horsepower to Speed in a graph form. Available in both black and silver color.
Power Meter i-D also has the ability time the following
0-50mph (0-100km/h), 0-100mph (0-200km/h), 0-200mph (0-300mph)
0-1/8mile (0-2--m), 0-1/4 mile (0-400m), 0-5/8 mile (0-1km)
The Power Mseter i-D also has the ability to record and data log up to 5 different times.
Features Compact 1/2 din size
Chassis dynamometer (up to 1183hp)
Reads speed in mph or km/h (up to 249 mph or 399kph)
User adjustable brightness and contrast
Easy to read illumi-drive (i-D) white lighting
Easy 3 wire hook up (attaches to stock speed sensor)
Compatible with naturally aspirated and turbo charged vehicles
Availability: Usually ships in 5-7 business days.
15086Regular price: $248.00Sale price: $209.00
Old May 27, 2006 | 07:50 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
had issues with the profec E-01, switched to the blitz...holds boost perfectly, much smoother..very pleased..
not sure if this has been asked in this thread (too lazy to read it all)
anyone get the unit that works with the SBC-ID that allows you to set boost per gear based off a speed and rpm signal?
-TODD
Old May 27, 2006 | 07:54 AM
taurran's Avatar
taurran
-TODD
Read the last two posts
Old May 27, 2006 | 08:46 AM
JoeDirtPharmD's Avatar
JoeDirtPharmD
Just bought this from Rtracing (member); looks great and hoping to have slightly better control over boost over the stock APS BC
Old May 27, 2006 | 09:24 AM
punish_her's Avatar
punish_her
Unfortunately, if what you say is true, then this would be impossible as a 0 limiter setting should regulate boost to the auto or manual boost setting.... I'll play around with it a little more this weekend, but I'm stumped as to what caused it.
The limiter setting at 0 will not limit any boost. All you will get is a blinking red display as you fly past waving good bye if your boost setting is warning. A 99 would ruduce the boost by 99%. Essentialy the Gain and Limmiter settings are oposite.
Gain =increase in boost responce under throttle. (bottom to top)
Limmit = decrease boost after warning.(top to bottom)
Old May 27, 2006 | 09:27 AM
roneski's Avatar
roneski
What set values are you guys using in manual mode?
Old May 27, 2006 | 10:37 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
so, I have to read...can you read them to me?
Old May 27, 2006 | 08:06 PM
punish_her's Avatar
punish_her
I found with a boost leak, which gave the control unit lower boost readings; that 30 gain and and 30% boost you get 15psi. Yeah HOLY CRAP!!! Good thing I datalogged and the defi I was able to get it back down.
Gonna replace all the rubber lines with cilicone because the rubber lines are cracking and releasing boost under pressure. While I'm at it gonna change all my plastic vac fittings with brass.
Old May 29, 2006 | 03:11 PM
mraturbo's Avatar
mraturbo
Originally Posted by Eagle1
I am using a Blitz boost controller, since February on my VRT built motor and JWT TT. So far it has been a solid unit for me, as I have been able to cross check its boost control against my independent boost meter with memory function, and they agree!!!
What I like about the unit is the four preprogram settings. For the street I set it around .7 bar, (around wastegate springs level) which is good for pump gas at California 91 octane. Then I have it set at .8, .9 and 1.0, with the higher levels fueled with 100 octane and blends in between, for the track.
Thanks Ed. Forgot we put this unit in your car...
M
Old May 30, 2006 | 09:58 AM
roneski's Avatar
roneski
Still not getting very consistent results. I'm not sure if my settings are off or if I confused some pressure lines.
I'm running it in manual "set" value is 17 gain is 20. The Blitz unit says that I'm peaking at 8.2 pounds of boost but my Autometer Nexus boost gauge says I'm only peaking at slightly over 7.
I'm not sure if either of the units is inaccurate or if the discrepancy has to do with the different sampling rates. Might have to get it on a dyno and datalog to get a handle on what's really going on.
Old May 30, 2006 | 10:17 AM
MIAPLAYA's Avatar
MIAPLAYA
I have the SBC manual in PDF form but the site won't let me attach it. Anyone want to host?
Old May 30, 2006 | 10:31 AM
roneski's Avatar
roneski
http://www.team3s.com/Blitz%20SBC%20i-D%20manual.pdf
Old May 30, 2006 | 10:33 AM
MIAPLAYA's Avatar
MIAPLAYA
Nevermind looks like you got it...
Old May 30, 2006 | 02:03 PM
SinCity350Z's Avatar
SinCity350Z
Track Whore
I am thinking of putting this unit on my Z as well. Adjusting the boost with a manual boost controller is not accurate and a pain in the azz. I don't really like electronics though and if something were to go wrong with the programming on the boost controller, that could mean a blown engine. On one hand, I look at it as an easy solution to changing between boost levels, but on the other hand, I look at it as another thing that could break and possibly ruin my motor. I drive my car very hard in high heat conditions and I the last thing I need is my boost controller to fail.
Eagle1 likes his, and roneski is having programming issues so I am still in the same place I was at first. If only there was an accurate way to set the boost with the manual controller instead of just guessing what you turn it too and then relying on the boost gauge.
Old May 30, 2006 | 02:28 PM
roneski's Avatar
roneski
I'm sure that once I confirm I am actually hooked to the correct pressure lines I can get the settings to fall into place. I haven't had any engine threatening problems with the unit. And the unit has a pretty cool safety feature (which may actually be the source of my problems now that I think about it). I think that it just needs a little tweaking.
Old May 30, 2006 | 02:32 PM
SinCity350Z
Track Whore
Well hopefully you figure it out on your car so by the time I put it on my car you can help .
Old Feb 2, 2013 | 06:11 PM
  #38
blade3609's Avatar
blade3609
Taurren, Was the problem with the Blitz limiter ever resolved? I came into the exact same issue. Any feedback ?
Old Feb 3, 2013 | 01:01 PM
  #39
str8dum1's Avatar
str8dum1
prolly need a time machine and go back to 2006 to get the answer.
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
