Turbonetics Numbers
Old May 30, 2006 | 06:21 AM
  #41
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by solidsnake
my SES has been on ever since ive had the kit. had it for over 10k now. its annoying but i heard without an engine management the code will continue to throw. i blanked it out with the cyher program a local dealer has but it came back after 50 miles.
The 0300 code will/can come on regardless of what management you run...its an unfortunate side affect of boosting what started as an N/A factory car..
Old May 31, 2006 | 08:05 AM
  #42
Gumpdriver's Avatar
Gumpdriver
Mine comes up and i just do not pay it any attention.
Old Jun 3, 2006 | 02:46 PM
  #43
Gumpdriver's Avatar
Gumpdriver
Default Here are some pics.
Here you go
Attached Thumbnails Turbonetics  Numbers-copy-of-dscn1178.jpg   Turbonetics  Numbers-copy-of-dscn1180.jpg   Turbonetics  Numbers-copy-of-dscn1181.jpg
Old Jul 24, 2006 | 08:24 PM
  #44
QuadCam's Avatar
QuadCam
other people in this trhead mention the falling power curve in the upper rpms.
What can be done to resolve this? Is this due to a poor design (too restrictive) of the exhaust piping to the turbocharger? That would seem to make sense, as all the TN ST cars can't make peak power in the same rpm band as when the car was N/A? If the exhaust and turbo piping is choking the engine's ability to exhale above 6000 rpm, it would cause the hp/tq/ to decline as we are seeing in the typical TN dyno.
does anyone have a cure for this? custom/aftermarket headers, larger piping to the turbine side of the turbo, larger downpipe, etc?
I am just thinking out loud......
Old Jul 25, 2006 | 09:29 AM
  #45
znot's Avatar
znot
sounds like you might be on to something, maybe you can drop an email to Reggie at TN ?
Old Jul 25, 2006 | 11:20 AM
  #46
PumpedVA's Avatar
PumpedVA
sharif with my car what type of ## should I be looking at if I add the TN ST and would I need larger injectors?
Just a reminder of what I am running now:
-complete CNC short block
-Pauter Billet Forged rods
-ARP Rod Bolts
-Arias zero silican AM Extreme duty pistons 9.0.1 .020 overbore
-VQ 12mm studs
-TurboXS UTEC
-HKS supercharger
-JWT cams
-DC sport headers
- AAM test pipes
-AAM 3” max flow true dual exhaust
-AAM version 2 fuel system
-AAM plenum spacer
-440cc RC injectors
Old Jul 25, 2006 | 11:28 AM
  #47
nissansource's Avatar
nissansource
"On any forced induction setup you want to have a fuel return system. If you look at any vehicle that comes from the Factory with a turbcharger they run a return fuel system to ensure proper fuel delivery"
SRT4 does not have Fuel return line
also jwt does without but with a trick
Old Jul 25, 2006 | 05:06 PM
  #48
Oleg's Avatar
Oleg
What trick?
Old Jul 25, 2006 | 05:55 PM
  #49
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
About 500whp give or take. Your block can easily support it, but the turbocharger will probably flow enough air for 500whp maximum. You would need a set of RC550cc injectors to accomplish this.
TN tuner kit is in stock, if you want one. It's sitting comfortably in my inventory cage.
-ARP Rod Bolts
-VQ 12mm studs
-TurboXS UTEC
-HKS supercharger
-JWT cams
-DC sport headers
- AAM test pipes
-AAM plenum spacer
-440cc RC injectors
sales@czp
Sep 23, 2019 03:30 PM
35reilly
Sep 28, 2015 07:42 AM
