idle problem
Old Jun 25, 2006 | 01:21 PM
  #61
mistaboosta's Avatar
mistaboosta
Originally Posted by Dirty Dave
mistaboosta : from looking at your profile, you do not have a lightened flywheel - new clutch assembly or aftermarket cams at the moment do you ?
no i dont have any of those yet.
Good find up about the 1000 rpm thing but UTEC won't let u bump up the idle.. Actually I don't know how to bump the idle up to 1000 coz my car is a 2004.5
Old Jun 26, 2006 | 02:58 AM
  #62
mistaboosta
Sorry for the double post did you at any time have the stock ecu wires tapped into or cut, because i used to have a blue emanage ? Although I did a dam good job putting all those wires back together soldered and heat wrapped, i even triple checked them.
nope bro, my ecu wires are untouched.
Old Jun 26, 2006 | 01:33 PM
  #63
mistaboosta
i've got some interesting news. Today i installed an oil cooler, new plugs and connected the grounding wire of the utec to the firewall.
When i started the car after everything was installed there was no cel !
I guess the problem might be a grounding problem with utec or something about the oil lines in the block. While installing Dartons the machine shop had made a mistake and cracked some of my oil lines so we had to use copper lines to replace the cracked lines. So i guess this might have effected the pressure on the cam sensor selenoids and dropping the oil pressure by adding the oil cooler might have had the opposite effect on the situation. I know this doesnt sound so logical but it's an idea.
Old Jun 26, 2006 | 03:16 PM
  #64
Dirty Dave's Avatar
Dirty Dave
Yea it definately is an oil pressure issue of some sort. Like i said earlier if I keep the rpm above 900 rpm i do not get the code, and by reving it up more im sure there is more pressure. Also I noticed when i shut the car down with the p0011 code only showing up as a pending code( doesnt actually turn cel on but does recognize the error) and start the car back up after it has cooled down when there is more oil pressure that the light wont come on just stays as a pending code. So maybe it is the type of oil we are using or the amount of oil we are putting in the motor , who knows ??? Please update if the light stays off !
Old Jun 26, 2006 | 11:32 PM
  #65
mistaboosta
i've used three different types of oil but the problem consiststed with all. About the amount of the oil, yes you might be right about it.
Today morning, i started the car and the cel was there grinning at me as always..
Old Jun 27, 2006 | 05:43 AM
  #66
Dirty Dave's Avatar
Dirty Dave
Lol, if seems as though you and service engine soon have developed quiet the relationship. Kinda like herpes, p0011 is gonna be your friend to the end !!!
Old Jun 27, 2006 | 08:08 AM
  #67
mistaboosta
lol, i guess you r 1 step ahead of me
Old Jun 27, 2006 | 03:50 PM
  #68
mchapman's Avatar
mchapman
Have you reflashed your UTEC main or dbw processor recently?
Where were the switches pointing when you did?
Old Jun 27, 2006 | 04:07 PM
  #69
Dirty Dave's Avatar
Dirty Dave
No, just used 3 different utecs, all of which the light stayed on , and had a list of other problems with. Do you think the dbw reflash may solve this problem ?
Old Jun 27, 2006 | 04:17 PM
  #70
mchapman's Avatar
mchapman
Sorry mate I was asking Mistaboosta.
I was asking because the manual had incorrect information about the switches used to select the different processors for flashing, resulting the wrong data being flashed to the wrong processor. Depending on which data file you flashed to which processor the car behaved differently but after one of them the car idled bad, threw codes etc. If you plug in your laptop and try to connect to the UTEC through hyperterminal after the incorrect flash has taken place then you should non standard information displayed.
The UTEC did not come like this so I dont think it matches your problems.
Old Jun 28, 2006 | 06:38 AM
  #71
mistaboosta
nope i didnt reflash utec or dbw.
Old Jun 30, 2006 | 09:23 AM
  #72
z350phille's Avatar
z350phille
I just chaged my sparkplugs and sparkplug for no1 cylinder was totaly black? all other plugs looked good. going for injektors tomorrow.
Old Jul 1, 2006 | 08:35 AM
  #73
Dirty Dave's Avatar
Dirty Dave
Is cylinder number one on the passenger side where the code is refering to ?
Old Jul 2, 2006 | 12:31 AM
  #74
z350phille's Avatar
z350phille
yes. so i hope changing plugs will help me with that code.
going to check injektors also,
Old Jul 2, 2006 | 11:51 PM
  #75
mistaboosta
i hope that helps, i've been checkin on my plugs quite regularly but there is no difference among them.
Old Jul 3, 2006 | 12:29 AM
  #76
z350phille's Avatar
z350phille
A stupid question before i atempt it...
Will Standard injektors fit on the RC upgraded injektorconnectors?
I will probobly change my management system from eManage to Utec soon also. Im a little afraid that the old eManage will blow my coils, and parts are extreemly expencive here in sweden.
thx for all help!
Hopefully il be on the road braking it in soon!
Old Jul 3, 2006 | 05:46 AM
  #77
mistaboosta
i had the APS connectors on my car when i installed RCs so i dunno about the stockers.
Old Jul 12, 2006 | 11:29 AM
  #78
bcarter's Avatar
bcarter
any updates... My car is doing the same thing with Utec and new built motor.
Old Jul 12, 2006 | 11:25 PM
  #79
mistaboosta
Here is some update,
I had already posted another topic about my car sputtering at high rpms (actually after 6000 rpm). It looked like a ignition thing. Yesterday I was on the highway with a friend. He was checking my maps etc. Suddenly while the car was rolling down on the road @ neutral gear, it died. I tried to start it again but it wouldn't. First thing i thought was the engine going bad but there were no smoke or oil on the road behind. So I pulled on the emergency line and tried to start the car a few times. At last the car started and suprisingly the CEL was gone. We started driving again and this time i tried to rev the car to 7200 @ wot. It was reving nicely until 7200 and this only happened after the CEL was gone. I also installed a ATS clutch yesterday and made sure that the new flywheel is installed correctly to eliminate another possibility.
Old Jul 13, 2006 | 05:49 AM
  #80
z350phille's Avatar
z350phille
bcarter:
I have contiuned my search for errors in the installation and checked my sparkplugs and injektors for errors plus i have redone the emanage installation for the 3rd time now no errors there.
I have a Shilded CAS Cable from CJ motorsports im going to install this weekend, just to be on the safe side.
And i fixed a air leak at the lowerplenum.
I have installed a groundning kit mostly becouse it looks good
Il continue to search this weekend and i hope i can find what cousing my problems!
Im proboly going to buy a Utek soon it seems to be a more complete solution then emanage plus i can tear out all those extra cables..
